    Dismiss Notice
KLR650 Only Thread......
Discussion in 'Thumpers' started by willys, Nov 19, 2011.
  1. Windborne11
    Windborne11 Been here awhile
    Aug 23, 2018
    465
    East of the West Coast
    Anybody fit a 1989 countershaft sprocket onto a 1997+ KLR? Is the spline the same? 1987- 1996 used 2- 6mm bolts and a plate to attach the sprocket, where 1997+ use the big nut. Reason is I can get a 17T sprocket for 1989 model, but not later bikes. I want to try one.
  2. sanders446
    sanders446 Been here awhile
    May 17, 2017
    271
    MA
    Eagle mike sells 17 tooth cs sprockets for the 1996+ big nut bikes and the spacer. Says it may require modification to the plastic cover though.
    https://www.eaglemike.com/Countershaft-sprocket-CSS.htm
    ZachM1 likes this.
  3. Windborne11
    Aug 23, 2018
    465
    OK good to see. That's what he is selling is the old style 17T, to fit the 2nd Gen. Thanks.
  4. Tsotsie
    Tsotsie Semi-reformed Tsotsi Supporter
    Nov 12, 2007
    2,714
    South Texas
    Try E Mike for used motors too.
    Dan Diego likes this.
  5. Aprilia
    Aprilia Long timer
    Sep 15, 2008
    1,799
    Phoenix, AZ
    I have a 2009 engine I pulled from a wreck. 8200 miles. I can install a 685 kit from eaglemike if you want...I keep them in stock. Gen2 to gen1 swap is easy.
  6. Scooter Addict
    Scooter Addict Been here awhile
    Aug 2, 2008
    236
    Joplin,MO
    I need an opinion on the KLRdash or Happy Trails rallye windshield system. Supposedly the KLRdash you can adjust the cant of the windshield.
    Is one better than the other for wind protection?
    ScooterAddict
  7. scout68
    scout68 Been here awhile
    Jan 1, 2018
    454
    Germantown TN
    I can’t comment on Happy Trails product as I only have used the KLR Dash. I’m sure the Happy Trails is well-thought through and a solid piece of kit.....because all there stuff seems to be. I love my KLr dash. I have the upper and lower on my ‘15. The windshield mount brackets can be adjusted, and I personally really like the largest of the zero gravity screens to go with it. I pushed mine to the highest setting and it’s nearly vertical. Almost zero turbulence on my face.
    And it saved west Tennessee and the surrounding area from the almost certain environmental hazard associated from me trying to wire any damn thing in the world. Voltage and I do t get along real wel yet. Two water proof cig plugs, voltmeter. Boom.
  8. Bobk0
    Bobk0 MacGyver Minded.
    Jan 31, 2014
    1,130
    Around that over there.
    Got back on the KLR repair+improve boat today. The agenda included the following:
    1) Replacement of the reservoir/horn bracket/stay. Hard to tell in the pic but this one is pristine with no bends.
    2) E.M. AIS blockoff plate and deletion. great fit. Thanks Mike.
    4) Thermo-Bob install and fitment. The hoses were the hardest part to make absolutely perfect, but great kit.
    Thanks Watt-man for figuring this s*** out.
    Scooter Addict, Dan Diego and scout68 like this.
  9. Bobk0
    Jan 31, 2014
    1,130
    Next was the damage to the left shroud....Started out broken:
    Added a piece of good reliable wood dow rod.
    One screw on the side and one on the base.
    Then JB Weld to fill it's soul.
  10. Bobk0
    Jan 31, 2014
    1,130
    Then deleted all of this stuff except that panel to the lower left. Just still need all of the rubber nipples to seal the deal.
    Next up: Damned Doo-hickey, DirtRacks crash bars, and then everything else is luxury.
  11. AteamNM
    AteamNM Wonna Be ADVrider Supporter
    Mar 3, 2010
    5,307
    Sandia Mountains New Mexico
    KLR led some big bikes around in the Pecos National Forest Saturday. 20191005_174346.jpg
  12. seldredge
    seldredge Adventurer
    Sep 7, 2017
    57
    La Honda, CA
    I changed to 14/43 gearing for off road and riding loaded and found I like it better all the time. Gearing matches the power curve better and cruising around 5000 rpm is very smooth. When I change sprockets next I'm going to oem 15T and 45 rear. The rubber on the oem sprocket definitely does something. When I tried CS sprockets without I notice slightly more vibration.
    scout68 likes this.
  13. lonegunm4n
    lonegunm4n Been here awhile
    Jun 2, 2017
    249
    Texas!
    https://www.tjs-cycle.com/inventory/-10282342i
    I'm going to look at that KLR in a few days. MC dealer, not a private sale.
    2007 KLR650, 4k original miles. Priced at $3k. Minor scratches on the right rear panel, and the headlight shroud is cracked on the right side as well.
    Price feels a little high to me, whats everyone's thoughts?
  14. seldredge
    Sep 7, 2017
    57
    La Honda, CA
    I believe 2008s had major oil burning issues . I don't know if that also applied to 2007. I expect someone with experience will chime in on this. And plastic body parts are expensive, although you could likely find a used one if you want to replace the headlight shroud. Is there any information on the maintenance of the bike? (Was doohickey done?) And I've seen newer bikes for not much more ($3500) in my area (SF Bay), but private party, which are generally less than dealers.
  15. HardWorkingDog
    HardWorkingDog Super Ordinary
    Aug 20, 2009
    3,837
    Walnut Crick, Cal.
    Maybe a little high, but if it fits what you want, you're not going to care if you spent $500 more than what somebody else thinks it's worth. A good looking ride that'll take you where you want to go...hard to beat for $3000.
    scout68 and XDragRacer like this.
  16. Dread
    Dread Putt-Putt Adventurer
    Sep 17, 2006
    657
    Boise, ID
    Even with only 4k miles that seems a bit high, but what do I know. My dealer had a 2007 with 7k miles for around the same price and it got snapped up. 07 doesn't have an inherent oil burning issue, but it is still a Gen 1 and has the other Gen 1 issues, all fixable. Hemisphere offroad makes replacement plastic for Gen 1 bikes, only in black though.
  17. EnduroRdr
    EnduroRdr Woods Racer & D/S Rider
    Feb 15, 2008
    2,722
    Formerly BR-LA, LR-AR, Houston-Tx, now South MS
    That’s a fair price for 4K miles.
    I ride one exactly like it. So maybe I’m partial. And I got out of a 08 into an 07. I found I’m really more a gen 1 kinda dude.
    Hard to find a 12 yo bike with low mileage like that. If you look hard enough, You can find one for less but likely will have tons more miles.
    I say do it!
    thechief86, FAW3, XDragRacer and 2 others like this.
  18. XDragRacer
    XDragRacer Long timer Supporter
    Mar 25, 2009
    5,216
    No worms in the '07 model year; "Last of the Mohicans (Generation 1s)." Red . . . becomes PINK quite easily, unless garaged/covered, in my observation. A matter merely of aesthetic taste, surely! Color doesn't rise to the level of deal-breaker in my book; YMMV!
  19. Matthew.chizz
    Matthew.chizz Adventurer
    Mar 23, 2018
    51
    Saskatoon Saskatchewan
    Hey guys,
    I have an 05’ KLR. I am currently in Baja California, almost in Cabo. Anyways, yesterday while I was on the road my odometer randomly quit working. Speedometer, tachometer and engine temperature gauge still works. Only my odometer and trip odometer quit working.
    As all you KLR guys know, since we don’t have a fuel gauge the odometer is our fuel gage.
    Any suggestion or ideas on what could be wrong? Easy fix? New gauge cluster??
    TIA
  20. Dread
    Sep 17, 2006
    657
    Boise, ID
    +1 to this. I love the old school Gen 1.
