1. ** Enter to win a $250 gift card! We want to hear from you, please take this survey **
    Take this survey which covers a range of questions about improving the community, the things that interest you and anything else you want to share with us. All responses will remain anonymous.
    Click here to take the survey
    Dismiss Notice
KLR650 Only Thread......
Discussion in 'Thumpers' started by willys, Nov 19, 2011.
  1. Matthew.chizz
    Matthew.chizz Adventurer
    Mar 23, 2018
    52
    Saskatoon Saskatchewan
    Yes it will reset. Only goes up to 9/10 than stops.
  2. HardWorkingDog
    HardWorkingDog Super Ordinary
    Aug 20, 2009
    3,906
    Walnut Crick, Cal.
    Where's the "Ouch" button...Like didn't quite seem right.
    Hannda, thechief86, windplay and 4 others like this.
  3. seldredge
    seldredge Adventurer
    Sep 7, 2017
    58
    La Honda, CA
    I just check the klr s on Craigslist near me. Quite a few. Price you were quoted seems ok. Ones I saw for that $ had 18-25k miles. Worth’s look
  4. sanders446
    sanders446 Been here awhile
    May 17, 2017
    295
    MA
    You may want to get into the cluster and check to make sure one of the gear teeth isn't broken or disengaged for whatever reason. Here is a vid on how to remove the cluster.
    and here is a picture of the worm gear that may be the culprit (pic borrowed from inmate klm4755)
    Yikes! Glad you're gtg.
    Matthew.chizz and Nihon Newbie like this.
  5. Matthew.chizz
    Mar 23, 2018
    52
  6. Dan Diego
    Dan Diego Long timer
    Dec 24, 2010
    2,476
    Tampa Bay
    It likely just came unscrewed from the instrument panel/Speedo. You can reach under and re-connect it. Easy peasy.
  7. Dan Diego
    Dec 24, 2010
    2,476
    Tampa Bay
    Ah, yes...reading comprehension is important!
    I hope he gets it fixed.
  8. Pollack
    Pollack Adventurer
    May 31, 2014
    1,244
    That happened to me once and the long metal piece fell out on the highway.....
    Best regards,
  9. Hannibal-8
    Hannibal-8 Been here awhile
    Mar 31, 2005
    110
    Saratoga Gap
    So I assume you have checked both ends of the speedo cable drive. Did this occur shortly after a front wheel removal? Check the connection (s) on both speedo and front wheel. To be safe remove the wheel end and inspect for a broken or worn drive end. If all fails then you will have to resort to do basic dead reckoning. Time x estimated speed = estimated miles. Maybe time to get a GPS?
    You might want to consider ordering up one of the Vapor products. I have even used a basic Bicycle computer on my GS.
  10. Bobk0
    Bobk0 MacGyver Minded.
    Jan 31, 2014
    1,160
    Around that over there.
    Anyone know which model Pro Taper bars are closest to stock or maybe a few mm taller which will bolt right on the KLR? Or any favorites? I might do bar risers later, but for now im good with stock. I'm about 6'3"
  11. Doppio
    Doppio Adventurer
    Aug 12, 2014
    35
    Washington State USA
    The Pro Taper SE ATV High model is a very close replacement to the stock bar.
    ctb619 likes this.
  12. thechief86
    thechief86 jack of all daniels
    Sep 5, 2015
    1,989
    Bethpage, TN
    Hey folks, a friend of mine is in a bind and needs a KLR 650 head or engine, or needs his head repaired, if anybody has anything for sale or knows anybody.
    The bike used to be mine, is a 2008 oil burner, just trying to save the thing.\
    Thanks. PM works fine if you can help, I check it everyday.
  13. sgroover
    sgroover Been here awhile
    Sep 9, 2012
    297
    Augusta, Ga
    Just put the ATV High on my 14 KLR and love it. Mine are 1-1/8 so had to use adapters (risers is what I used).
    Sammy
    TheHeretic likes this.
  14. Dan Diego
    Dec 24, 2010
    2,476
    Tampa Bay
    Check with Eagle Mike who may have either or both items you need. He has in the past.
    thechief86 likes this.
  15. thechief86
    Sep 5, 2015
    1,989
    Bethpage, TN
    Thanks, I'll give him a shot
  16. Pollack
    Pollack Adventurer
    May 31, 2014
    1,244
  17. Aprilia
    Aprilia Long timer
    Sep 15, 2008
    1,799
    Phoenix, AZ
    thechief86 and ctb619 like this.
  18. Matthew.chizz
    Mar 23, 2018
    52
    This wasn’t the case, had the gauge cluster off. Cleaned everything up, made sure everything was connected and put back on. Will see tomorrow morning when I head South if it works or not.
    Dan Diego likes this.
  19. Matthew.chizz
    Mar 23, 2018
    52
    Yes checked the speedo cable. Looks good on both ends. Occurred over 5,000km after my front and rear tire change. I have a GPS and also have MapsMe and REVER to keep track of distance / time / speed.
  20. thechief86
    Sep 5, 2015
    1,989
    Bethpage, TN
    Pm sent to Aprilia. Thanks guys!
