    Dismiss Notice
KLR650 Only Thread......
Discussion in 'Thumpers' started by willys, Nov 19, 2011.
  1. XDragRacer
    XDragRacer Long timer Supporter
    Mar 25, 2009
    5,216
    Well, at least, they didn't get the right and the left halves mixed up with any other engine's! :lol2
  2. Munmi4
    Munmi4 Munmi
    Jan 8, 2014
    51
    Munising, Michigan
    Stock air filter. When I removed it, I could that is was loaded so I took extra care in removing it. When I saw the mess of the screen, I went back to inspect the filter. I could see not any areas that may have been compromised or damaged. My current plan, when I can get back to working on the bike, is to remove carb then clean the screen with a spray cleaner and compressed air.
    Bakfarht and ZachM1 like this.
  3. CliffElam
    CliffElam OldN00b
    Jan 24, 2020
    172
    Naples, FL
    Why is that so clean? I thought removing dirt broke these things?
  4. Munmi4
    Munmi4 Munmi
    Jan 8, 2014
    51
    Munising, Michigan
    All electrics work fine. The engine runs, seems to idle OK but roll on the throttle and all sputter and burp. At first I thought I had miscalculated my mileage and need to switch to reserve. That didn't help so turned petcock back to run....no change.
    Hoping to get some shop time Monday and dig a little deeper. Thanks for the list of troubleshooting steps.
  5. XDragRacer
    Mar 25, 2009
    5,216
    Carburetor diaphragm intact (no holes), properly mounted? Diaphragm air leak can cause symptoms described.
    baldman1 and ZachM1 like this.
  6. Pollack
    Pollack Adventurer
    May 31, 2014
    1,207
    Mine did the same thing for a good while. I thought it was electrical at first, and I fixed the side stand bypass & clutch switch. I needed to replace the fuel line and at the same time I put in a slightly larger pilot jet and I put in a smaller main jet. The main jet was for mpg and the pilot jet was for a 17 T CS and intermittent stumbles. I cleaned the carb and inspected the diaphragm. I probably need to replace it as it looked worn and didn't seat just right. The stumbles became less prevalent and after a couple days of being run hard it went away. Just my experience, ymmv.....
  7. buckthedog
    buckthedog Eastbound and down
    Oct 21, 2011
    810
    South Mississippi
    Those little holes in the jet can get clogged and its VERY hard to see...at least for my eyeballs. I've found guitar string is awesome at cleaning it out.
    I'd listen to any advice XDragRacer says. I've learned a lot from that guy and some others here. They've mentored me and never even knew it!!!
    BTW, as the great Bob Dylan said..."The times, they are a changin' " I've listed my 03 in the flea market. It's really been/is a great bike, and I've put on about 500 miles this week, but reality dictates that my riding is more sport-tour-y and less adventure-y, and with Covid (my wife and I are both RN's so we've been full out for a while now) 2 kids in college and more new grandkids (not from the college kids:-)) I need something faster, smoother and more comfy for 2 up. I dearly miss my old Bandit 1250. So for all you lurkers, here's your chance to be "one of us."
  8. Bakfarht
    Bakfarht Been here awhile
    Nov 13, 2018
    156
    Calgary
    Ya these carburated thumpers needs their air flow. Biggest things I've found that affect performed are good air flow, a clean carb, and top her up with T4.
    patrkbukly and buckthedog like this.
  9. Bakfarht
    Nov 13, 2018
    156
    Calgary
  10. lonegunm4n
    lonegunm4n Been here awhile
    Jun 2, 2017
    249
    Texas!
    Factory paint markings during assembly. My '07 has a bunch of them too. All the KLRs have had them at some point in time, but most have either faded away or been washed away (be it by soap and water or mud/creek baths).
  11. lonegunm4n
    Jun 2, 2017
    249
    Texas!
    I finally replaced the front tube on my KLR. Stock Dunlop tire.
    I was surprised at how easy it was. I've replaced tires/tubes on my CT90 before, which was a bitch and a half. I've heard KLR tires can be a pain as well, and wasn't looking forward to it.
    A little corn starch on the tube, a little lube on the tire, and with 2 motion pro tire irons and my left knee, it practically slipped right on. I've got it aired up now, I am going to let it set until the morning to make sure it's going to hold air. I will probably invest in a bead buddy or a third tire iron to make it easier for trail side repairs.
  12. Bakfarht
    Nov 13, 2018
    156
    Calgary
    I had no problem changing the front either, the problem I had was getting it seated properly and rolling smooth. I have a bead buddy, I'd say it's a useful tool but nothing magical. It is small and light though, easy to pack.
    I'd be interested to know, does your front have a bead lock? It looks like mine did, but was removed at some point.
  13. KPfromCT
    KPfromCT Adventurer
    Aug 21, 2020
    17
    Connecticut
    My 2008 has similar markings on the bottom of the case halves and I've owned it since day 1. I have no clue what they mean.
  14. Bigger Al
    Bigger Al Still a stupid tire guy Supporter
    Oct 12, 2004
    9,989
    Auburn, CA
    Get a pair of those really small vice grips. Not only will they hold the tire, they could come in handy for other repairs.
    https://www.amazon.com/VISE-GRIP-Or...eywords=mini+vice+grips&qid=1601321742&sr=8-3
    merc16 likes this.
  15. BigFatAl
    BigFatAl Long timer
    Aug 24, 2016
    1,779
    I’ve carried and used 2 pairs of the smallest vice grips for years to change tires but lately I’ve been carrying 2 of these.They work just as good PLUS you can use them to break the bead and they don’t tear up the rim.
    ZachM1 and merc16 like this.
  16. lonegunm4n
    Jun 2, 2017
    249
    Texas!
    No bead lock. Mine was never taken off road before it came to me. It had 5k miles on it, and was used as a once a year ride for a servicemember in North Carolina.
  17. lonegunm4n
    Jun 2, 2017
    249
    Texas!
    Bigger Al likes this.
  18. HardWorkingDog
    HardWorkingDog Super Ordinary
    Aug 20, 2009
    3,837
    Walnut Crick, Cal.
    Yeah, the Motion Pro Bead Buddy is worth whatever it costs. (Your amazon listing shows amazon at its worst...Please support the company that invented, perfected and manufactures the real thing. Or not. Just my thing...)
    flexiflyer, merc16, FAW3 and 5 others like this.
  19. Bigger Al
    Oct 12, 2004
    9,989
    Auburn, CA
    Just double up a rag and use that to protect the rim.
    RunninRanger likes this.
  20. FlatlandKSBrett
    FlatlandKSBrett Been here awhile
    Nov 25, 2014
    659
    Salina, ks
    I'll just leave this here...
