KLR650 Only Thread......
Discussion in 'Thumpers' started by willys, Nov 19, 2011.
  1. KPfromCT
    KPfromCT Been here awhile
    Aug 21, 2020
    225
    Connecticut
    The regular/rectifier is going to get hot when there is no electrical load (especially without a headlight).
    EMFL likes this.
  2. EMFL
    EMFL It's an adventure if nobody died Supporter
    Nov 7, 2018
    151
    SF Bay
    KPfromCT, thanks for the info. Makes sense. We are back on the road, hopefully no more issues until Bend
  3. Bob just Bob
    Bob just Bob Adventurer Supporter
    Apr 2, 2021
    20
    Lometa Texas
    I'm confused here. Did you find a good product and if so share what it is. Or are you asking for one?
  4. Bob just Bob
    Apr 2, 2021
    20
    Lometa Texas
    Bend as in Bend Texas? The little Itty bitty town that I live next to. Let's ride brother.
  5. EMFL
    Nov 7, 2018
    151
    SF Bay
    Bend, OR , I should have clarified. If we were near Bend, Tx , I would be taking you up on the offer!
    After some finer electrical diagnostics, found a garage that would let us borrow a multimeter, we traced the issue back to a faulty Regulator/ Rectifier. We had to eventually disconnect the rectifier, since it kept blowing the 20A main fuse, and rode a good 90 miles to pickup a R/R. We disconnected the headlight as well, to save the battery. All seems good now.
  6. Bob just Bob
    Apr 2, 2021
    20
    Lometa Texas
    Well those if you ask me make for the best trips. Helps the feeling of accomplishment to know you did it on the go and on a bike.
    I've been to bend Oregon as well. High desert not a fan myself lol but I love the western side of Oregon. Happy trails friend.
    EMFL likes this.
  7. XDragRacer
    XDragRacer Long timer Supporter
    Mar 25, 2009
    5,404
    As you suggested, Dno:
    One zip-tie (especially a wide one) probably works; two narrow zip-ties are shown, one on either side of the center hole.
    Thanks for the kink, eliminating the heartbreak of trying to spear and thread those insufferable, un-cooperative battery connection nuts!
  8. Dno
    Dno Been here awhile
    Mar 30, 2021
    750
    Nc
    Holy cow double ziptie hats off too ya on a nutty idea
  9. Grinnin
    Grinnin Forever N00b Supporter
    Dec 10, 2005
    8,199
    Maine, USA
    I've always used a folded piece of rubber cut off an old inner tube.
  10. Dno
    Mar 30, 2021
    750
    Nc
    Feel free to use anything to help the batt connection except something that conducts. Ive hooked plenty of batts and even prefer composit ratchets when I can. Wrapped plenty wreches, socket, extensions, and ratchets with tape or foam tape and shrink tube on extensions. Dead short can blow a piece of metal out of something. Not cool.
    ZachM1 likes this.
  11. Windborne11
    Windborne11 Been here awhile
    Aug 23, 2018
    544
    East of the West Coast
    Wow!!!
    Dno likes this.
  12. Dno
    Mar 30, 2021
    750
    Nc
    I wish I knew the ziptie trick before I installed 300 battery tenders on 2007 harleys. Oh well agony driven ideas when you stop and think
  13. InspectorJim
    InspectorJim Long time rider
    Feb 3, 2017
    94
    Ligonier, Pa
    Shorai battery gives you these.
    Dno and XDragRacer like this.
  14. Bruce curtis
    Bruce curtis Indi scot
    Oct 21, 2015
    71
    Scotland
    I think he has discovered that bug splatter is the perfect product.
    Tricky bit is identifying the individual bug, or rather the species, as there didn’t look to be much left of the insect.
    Happy hunting.
  15. kf7ja
    kf7ja Adventurer
    Jun 23, 2015
    99
    Washington State
    My 2 cents worth on the spacers for battery nuts, I use square cm of green Scotch pads. They can also be used to clean the contacts.
    gepeze and Dno like this.
  16. Dno
    Mar 30, 2021
    750
    Nc
    The zip tie trick has some reach to it and is easily removed after tightening. I think the bug guts and what ever was on the rag made a form of shellac
  17. TheHeretic
    TheHeretic Been here awhile
    Jun 7, 2005
    594
    RI
    Or a piece of fuel line.
    Dno and Grinnin like this.
  18. F150
    F150 Been here awhile
    Nov 6, 2016
    375
    Nashville
    Bob, Bruce is correct. Something of or from the gut of (insert critter here) works wonders on aged KLR plastics. Will report back if I find something definitive.
  19. Dno
    Mar 30, 2021
    750
    Nc
    Bugs got me researching shellac. I had no idea it can be sprayed it on food to make it shiny. Never thought of using shellac on plastics till now. Ill stick to plastics for research.
  20. Dno
    Mar 30, 2021
    750
    Nc
    PME Edible Glaze might be the ticket for plastics. It is food grade shellac in aerosol can.
