KLX110, what have i gotten myself into...
Discussion in 'Some Assembly Required' started by Toadady, Aug 25, 2018.
  1. Toadady
    Toadady Push'n parts Supporter
    Dec 15, 2003
    6,135
    Southern Missouri
    years and years ago we had a really nice DRZ110 stolen from us, since then I've wanted another one just because, but i didn't need it, kids had grown and such. Well a guy I know puts one up on FB for $200, when I asked him about it he said "It's a turd". Well why not,
    I should have ran, but NOOOO , now I've got it all torn apart and the list is long
    piston says 50 on the top,and it looks like the cam chain or something has grenaded in the past, but it's been repaired , by how the case bolts look like it's had the cases split, so we'll see, things like chain adjusters, and rear wheel spacers have been farmed out to big nuts, among other little crap that shouldn't be missing or hacked up, the most aggervating is the rear brake lever has lost it's bolt, and they put a spot of weld to keep it from falling off
    plan so far is to make it look as close as show room new as possible, I've got a really short daughter, and a couple grand kids that I'm sure will enjoy it.
  2. Toadady
    Dec 15, 2003
    6,135
    Southern Missouri
    anyone see something wrong in this pic?
    little closer
    that's the boss where the kick start shaft would go, someone's half assed it,
    soo soon as I get the stator off, friend of mine is going to put it into his mill, find the center of that boss, then fill it with weld and remachine it back out,
  3. Toadady
    Dec 15, 2003
    6,135
    Southern Missouri
    In the mill
    I wont be there for the welding and machining. Hopefully by Thursday he'll have it done
    FR700, invisa-bill and r60man like this.
  4. r60man
    r60man Long timer
    Mar 14, 2013
    1,567
    Robesonia PA
    It is nice to have friends with the right tools, when you don't. Good start!
  5. Toadady
    Dec 15, 2003
    6,135
    Southern Missouri
    One more step closer. The other little spot is from someone ham fisting too long of a bolt into the case and busting it out,
  6. Toadady
    Dec 15, 2003
    6,135
    Southern Missouri
    little bit closer
    needed a little bit weld material on the side, but we're going to stop there,
    XR4EVER and FR700 like this.
  7. jake28
    jake28 Riding to the horizon.
    Mar 4, 2007
    471
    Bay Area, CA
    To play devil's advocate, why not cut your losses and get a new lifan 125 motor, or another 110 motor from someone who has already done the swap?
  8. Toadady
    Dec 15, 2003
    6,135
    Southern Missouri
    ya but what fun would that be?
    #8
    XR4EVER and Fast Idle like this.
  9. tntmo
    tntmo Oops, I did it again.
    Jan 31, 2012
    1,042
    San Diego, CA
    If I remember correctly these had another gear or two built into them, you just needed to swap a few parts around. Look into it!
    #9
  10. Toadady
    Dec 15, 2003
    6,135
    Southern Missouri
    yes, I got a new shift drum that uses 4th gear
    #10
