KLX650 riders UNITE
Discussion in 'Thumpers' started by COBAUM, Aug 17, 2006.
  1. Chopperpilot
    Chopperpilot Adventurer
    Dec 17, 2019
    19
    Fairbanks, AK
    https://advrider.com/f/threads/stators-demystified.189734/
    Read through this thread and gained some insight on stator power output. Looks like compared to most ‘dirt bikes’, especially older ones, ours are pretty high on power output. At least judging by the pictures of stators I’ve seen and how all of our poles are already wound.
    RunninRanger likes this.
  2. RowBust
    RowBust Long timer
    Sep 6, 2013
    1,051
    Ready for adventure or whatever comes my way 20200911_101712.jpg 20200911_101937.jpg 20200911_101937.jpg 20200911_101712.jpg 20200911_101937.jpg
    RunninRanger and Myway like this.
  3. Chopperpilot
    Dec 17, 2019
    19
    Fairbanks, AK
    That, my friend is a cool looking ride. Can we get more pics from the side/back end?
  4. RowBust
    RowBust Long timer
    Sep 6, 2013
    1,051
    Ok
  5. RowBust
    RowBust Long timer
    Sep 6, 2013
    1,051
  6. Kawibunga
    Kawibunga Adventurer
    Mar 7, 2019
    19
    Calgary, AB.
    You've spent some time on that, parts chromed, metal side panel, shortened seat, custom gauge set mounted, 17" supermoto wheels, leather cover on the tank,.......... wild! Maybe not the direction I'd go, but I love the creativity. Great job thinking outside the box!
  7. green meanie
    green meanie Adventurer
    May 29, 2020
    19
    Wooster Ohio
    Sweet job RowBust Love the blacked out look. What kind of paint did you use for the motor & forks & swing arm That was going to be my winter project to paint my C this way
  8. RowBust
    RowBust Long timer
    Sep 6, 2013
    1,051
    Frame s/arm powder coated, forks enamel, engine HR engine enamel
  9. Snypr18
    Snypr18 Adventurer
    Jun 30, 2020
    24
    Kansas
    Wow, looks like you put some serious time into this bike. Super clean. Is that a JNS Engineering LED headlight? Did you mount it in a cowling from another cycle or custom make one?
  10. RowBust
    RowBust Long timer
    Sep 6, 2013
    1,051
    Don't know the brand, off ebay, used part of the stock one and made a bracket to adapt it
    RunninRanger and Snypr18 like this.
  11. Snypr18
    Snypr18 Adventurer
    Jun 30, 2020
    24
    Kansas
    Im curious, what interval do you guys use for oil changes? Everyone here use OEM oil filters? Any arguments for or against synthetic / conventional oil?
  12. Kawibunga
    Mar 7, 2019
    19
    Calgary, AB.
    Lots of schools of thought here. I pick up what ever filter I can find. Not too fussy there. Do every 10 hours off road trail riding or so. If I had the bike tagged and rode it on the street as well, I'd probably bump that up to 15 - 20 hours....... Your standard 450F moto bike is 5 hours, many guys do oil after every ride, filter after every few rides........
  13. Myway
    Myway Long timer
    Jan 2, 2007
    7,221
    Knobby country
    klx650C owners manual every 10000km oil and filter
  14. Snypr18
    Snypr18 Adventurer
    Jun 30, 2020
    24
    Kansas
    Anyone have any recommendations for passenger footpegs on the R?
  15. nejauks
    nejauks Been here awhile
    Dec 6, 2010
    183
    Latvia
    My KLX650R cylinder. A thin sleeve was inserted. Still warm.))
    The crankshaft has also been restored. Rollers were replaced at the big end of the connecting rod (Ø 5 mm x 19 pcs.).
    Chris-KH2PM, knudln and jjxtrider like this.
  16. Snypr18
    Snypr18 Adventurer
    Jun 30, 2020
    24
    Kansas
    Installed one of Mark's manual cam chain tensioners, everything went smoothly and seems good. Thank you, Mark.
    Chris-KH2PM likes this.
  17. markk53
    markk53 jack of all trades... Super Supporter
    Dec 20, 2007
    20,163
    Delaware Ohio
    No problem, good to keep another KLX on the road.
    Snypr18 likes this.
  18. MillienialPig
    MillienialPig Adventurer
    Jan 1, 2020
    12
    Austin, TX
    Has anyone tried to put the kickstart from the R model onto the C model? I see a lot of references to it, but I tried it, I'm running into an issue where the mainshaft and corresponding clutch baskets is different sizes on either bike. Neither of the sleeves fit the (R) clutch basket (with kickstarter gear) on the (C) mainshaft. It means the basket has wiggle room and seems too low, so the kickstarter is binding against the clutch basket. I could get some pieces machined but I'd like to explore any other options first.
    Any help? This is a '96 R kickstarter onto a '93 C.
  19. Kawibunga
    Mar 7, 2019
    19
    Calgary, AB.
    I don't think there is a straight swap solution from what I've read and seen. Ideally you'd want to be able to do this without splitting the cases either. You may need to hit the machine shop is my guess. Fogo a ways back in this thread did the electric start on an R model, but it was not straight forward either. That's all I got! :)
  20. MillienialPig
    Jan 1, 2020
    12
    Austin, TX
    Sure, makes sense. Good to know I'm not crazy.
    Yeah, the electric start transfer would be awful, pretty sure that means splitting cases. Jeez. I was looking at this build and it just breezed over that part, even though you can see that the clutch baskets have different diameter channels
    https://klx650.forumotion.com/t10p75-klx-650-c-conversion-to-rally-rig
