KLX650 riders UNITE
Discussion in 'Thumpers' started by COBAUM, Aug 17, 2006.
  1. ridemtra
    ridemtra single track
    Jul 11, 2009
    63
    missouri
    klx 1.jpg klx 2.jpg What's it worth Runs good but needs tlc
  2. Lesharoturbo
    Lesharoturbo Nerdly Adventurer
    Mar 23, 2009
    3,187
    Austin TX
    Not an expert, but I do know that more info is needed to answer your question.
    Where is it located?
    How many miles?
    Year?
    Model? It looks like an R version, I have a C.
    Ballpark guess it's between $1,000 and $2, 000. But that is not including any regional or COVID-19 related adders or deductions.
  3. Tinter
    Tinter Adventurer
    Feb 13, 2021
    43
    Denmark
    Finally fixed my bike, changed to a 150 main jet, changed the breather hose (13mm at the airbox although 16mm at the engine, but it seems like a 13mm can stretch onto it) and stuffed it with steel wool, changed my chain and changed my front sprocket. Really liking this front sprocket, it seems to make me sit about 500rpm lower at a given speed, or about 10kph faster at a given RPM when in 5th. So that means I can do about 120kph at 5.5k RPM, where before I'd do 110kph at 5.5k RPM.
    Need to ride more to see how my oil drain is going to turn out, but it feels good so far.
    All I want now is a quieter exhaust as I am currently using a Laser Produro, sounds fine when it revs, but it's a bit too loud to drive home in the evening and when I cruise through a town, it sounds like a ride on lawnmower.
    Chris-KH2PM likes this.
  4. ridemtra
    Jul 11, 2009
    63
    missouri
    1993 r version in st.louis,mo. Mileage unknown with a reset odometer only
  5. Lesharoturbo
    Mar 23, 2009
    3,187
    Austin TX
    I paid $1300 for my 94 C in 2008 with 10,000 miles. I could probably get the same for it now if not a little more.
    I still go with between 1 and 2k.
  6. Tinter
    Tinter Adventurer
    Feb 13, 2021
    43
    Denmark
    Alright I went for a proper ride down the highway with my new rear tire, chain, front sprocket, main jet and breather hose. It performed well although it seemed to get fairly hot and once I pulled in at my destination I saw the bike dripping all over. Looks like oil has been dripping out and flowed all kinds of places, like onto the chain, resulting in it getting flung everywhere. I suspect this is due to my breather hose mod. It might be broken, otherwise I don't see how oil would get out. It was quite a scary sight, but I think it looked worse than it really is. At least the oil level hasn't dropped much, it's just really made a mess.
  7. Tinter
    Tinter Adventurer
    Feb 13, 2021
    43
    Denmark
    I found the culprit, the new hose I installed was a bit short and ended up kinked, so no pressure was getting out. I bought a new new hose and redid it and it's a lot better.
    Of course the bike giveth and the bike taketh, so during what was really a simple problem with a simple solution, I ended up losing one of those square nuts for the fairing and I had to spend like an hour grinding down a nut to fit in it's place. Also trying to fill oil, I ended up overfilling it. It was in the middle of the glass, but running the bike for a bit afterwards it was at the top of the glass when on the sidestand. Is the clutch oil it's own reservoir that needs to be pumped into the sump?
    My seat has also lost its left thread, anyone got any good solutions? A helicoil would repair the thread, but I think it's a little small for that. Could I attach a nut on the inside and use that? It would certainly tighten fine, just need a way to hold it in place.
    For reference, it's this bit of thread here.
    I've ridden a bit more on this sprocket, can't say I can feel any torque missing, but the bike feels much nicer when it doesn't have to rev as high, especially on the highway I can save a lot of vibrations like if I'm overtaking a car. If you're still considering it I would say go for it! I've noticed my revs don't seem to go as linearly as they did before, or maybe it's just more noticeable. I'm getting 130kph at what should be 6k, but it's a little under maybe like 5.7k in fifth.
    HighwayChile likes this.
  8. Snypr18
    Snypr18 Adventurer
    Jun 30, 2020
    74
    Arizona
    Sounds like I need to re-gear a bit when I replace my chain eventually.
    As far as the seat threads go, I would likely attempt a repair with a tap, and if that didnt work I would either cut new threads a size larger (such as going from M3 to M4) or smooth it out and use a longer bolt with a nut and washer on the other side.
  9. snowstormaland
    snowstormaland n00b
    Aug 16, 2021
    4
    Aland Islnads, Finland
    "Hello internet, welcome to the channel..."
    New to the KLX scene having only owned my "C" for 4 days. Few starting questions;
    - Does the KLX have lighting in the instruments? My speedo and rev was pitch black riding home last night.
    - Looking to get some spare levers; witch other bikes have compatible levers?
    - Has anyone changed their footpegs for wider ones, if so; witch other bikes have compatible pegs?
    - Would like to get a second set of wheels; what options do I have for wheel hubs?
    //Snowstorm
    and no, I haven't tried searching, and no, I haven't read trough all the posts, I'm only on page 149 atm..
  10. Lesharoturbo
    Mar 23, 2009
    3,187
    Austin TX
    Yes, there are lights in the instruments.
    As for the rest, I do not know
    snowstormaland likes this.
  11. markk53
    markk53 jack of all trades... Super Supporter
    Dec 20, 2007
    23,177
    Delaware Ohio
    KLX250/300 use same foot pegs. You can go big buck or low buck.
    The front wheel has a number of options for the hubs using the KLX650R, KLX250/300 up to 2008, and the KDX200/220 all having the same speedo drive for the mechanical speedo, but the brake rotor is exclusive to the C and to the KLX250/300 SF supermotos. 300mm
    Rear hub has no substitute when it comes to the cush hub. KLX650C was the only one. You can use the solid hub from a lot of other bikes, like the 650R, same as on some MX models and probably, again, all the KLX250/300 models. Just make sure it has the 220mm brake rotor.
  12. Bhamgene
    Bhamgene Adventurer
    Aug 25, 2017
    12
    Been a while since I was able to work on the bike but I have found the following. Originally I bought the bike and it would not start. Someone pointed me in the direction of a stuck valve. I found both intake valves stuck open when I pulled the head and the camshaft journals scored. I will do a better inspection this week but hopefully I can send them to fourstroke works, formerly Jerry Leighton of Stroker Performance in CA, and he can work some magic on it. I'll have him do a vavle job as well. I hope he still works on these bikes...
    Cams were scored as well, especially the intake cam. Anyone have a lead on replacement cams with better performance? Or even stock ones.
    The lower cam chain was pretty stiff as well. The upper one was very flexible. Anyone have this experience on the cam chains?
  13. Storz
    Storz Been here awhile Supporter
    Nov 10, 2011
    152
    Boone, NC
    Anyone have a KLX650 they're looking to sell? Located in Western NC
  14. markk53
    Dec 20, 2007
    23,177
    Delaware Ohio
    I may consider it. PM me and we can discuss it a bit.
  15. snowstormaland
    snowstormaland n00b
    Aug 16, 2021
    4
    "Good evening internet.."
    Meet Valkyria =) My new ride in her current form:
    She's gone through a mid-life crisis and was aspiring to be a SM bad girl but we have decided together that it's much more apropriate for her to dress her age and will be reciving a well deserving makeover during the winter. Fortunately she has just gone trough a really expansive service so on the technical side she is in grate shape!
    She boasts a magnificent Akrapovic exhaust sytem along with jetkit and opened up airbox so there is power-a-plenty!
    She has her own Insta-account, KLX650.Valkyria, if you would like to see what she's up to ;)
    //Snowstorm
    Chris-KH2PM, Snypr18 and cabbage681 like this.
  16. Snypr18
    Snypr18 Adventurer
    Jun 30, 2020
    74
    Arizona
    Id be really interested in some details about that Akrapovic setup.
  17. ridemtra
    Jul 11, 2009
    63
    missouri
  18. Lesharoturbo
    Mar 23, 2009
    3,187
    Austin TX
    Anyone know of pannier racks for the C model?
    I don't do much off road travel. I just need a place to stash my gear while I visit sites that require a lot of walking. I plan on changing from the Tech 3's to something more comfortable.
    I already have a top box that fits my helmet and gloves
  19. snowstormaland
    snowstormaland n00b
    Aug 16, 2021
    4
    Hepco & Becker have a pannier rack system for the KLX. It's about 350€.
  20. Lesharoturbo
    Mar 23, 2009
    3,187
    Austin TX
    Thanks, I also found one from Happy Trails while searching, but no reviews. Not sure if anyone had actually purchased them!
