KTM 1090 Adventure - Chain Lubrication Question
Discussion in 'Ridiculous streetbikes with 6 CPUs and too much HP' started by dwinkawatasaki, Oct 9, 2018.
  1. dwinkawatasaki
    dwinkawatasaki n00b
    May 30, 2017
    8
    San Diego, CA
    Hi All,
    Coming to KTM from BMW R1200 with shaft drive (no lubrication needed) and I have a question regarding chain lubrication. What's the general rule for how often the chain should be lubed? I'll probably be 70/30 street/dirt.
    Any brand preference?
  2. kokos79
    kokos79 Nomad
    Apr 13, 2009
    1,286
    Greece
    KTM 1X90s have a built in chain lubrication warning system. The chain rubbing on the chain slider starts to make a horrible loud noise that sounds like there's gravel in your clutch basket. For me that happens around every 600km, give or take, less when driving in the wet.
    Lewilewi and 2whl-hoop like this.
  3. Ledwardio
    Ledwardio Been here awhile
    Aug 9, 2014
    181
    Bingley, UK
    There isn’t really a guide to the frequency of when to do it as it varies so much depending on the conditions you are riding in.
    Lubing the chain is only one half of the equation too - cleaning it is really important too.
    Basically you can’t do it too often, but you can do it too little LOL
    ScooterNoMore likes this.
  4. microtom
    microtom Been here awhile
    May 25, 2016
    307
    Central Florida
    I clean and lube mine every few hundred miles or after a gnarly dirt/sand/water session.
    Lewilewi and 3rdgeargrndrr like this.
  5. hoss1
    hoss1 Been here awhile Supporter
    Oct 25, 2015
    573
    Ventura, CA
    Enjoy your new bike and welcome to the world of the chain. Here are some thoughts https://advrider.com/f/threads/1290-sa-owners-thread.1042722/page-332#post-29068628
  6. Lewilewi
    Lewilewi Ride it like you stole it......
    Oct 22, 2017
    1,571
    Europe
    Lube Every ride
  7. kaertner
    kaertner Been here awhile
    May 30, 2017
    724
    Europe
    What does it say in the user manual that came with the bike?
  8. nigelj
    nigelj Been here awhile
    Jul 3, 2018
    417
    Cheddington
    Every 2-300 miles, or fit an oiler...I recommend Tutoro, Scottoilers are messy fuckers!
    #8
  9. GCecchetto
    GCecchetto Long timer Supporter
    Jun 29, 2013
    2,923
    Woodside CA
    Dupont Chain Saver is the hot ticket. You can’t go wrong lubing before every ride, assuming you ride at least 100-150 miles when you ride. If you ride less miles than that on road, you can go a couple of rides.
    In the dirt, clean and lube every day, it only takes five minutes. I carry one of these with me on trips. In five minutes I’ve knocked the majority of the crap off the chain and lubed it. The one hitch in the git-a-long for you is that you have a 1090 with no center stand, unless you’ve installed one, which make the chain maintenance a pain in the ass.
    #9
    DirtJack and Smallfry506 like this.
  10. marbee40
    marbee40 Some Fear is Good
    Jan 28, 2007
    1,614
    Awfully close to the Marsing Cemetary
    Lots of products out there to choose from. The most important lube is the one you use....often. Your chain WILL remind you. You'll especially hear it when backing the bike up in the garage or driveway. Click clack clack.
    I commute 2-3 days a week, 30 miles each way. I take it off-road on weekends and on long highway trips. I carry a small can of my favorite stuff in the tank bag. When I lube, I just roll the bike forward as I spray, no center stand required. I carry an old rag and wipe off the excess when I'm done. I clean my bike after every dirt ride and use a chain brush to get the junk out.
    Two most important things to watch are chain maintenance and tire pressure. Look EVERY day. Don't be lazy or either one will bite you hard.
    #10
  11. DirtJack
    DirtJack Adventurer Supporter
    Aug 12, 2007
    3,312
    San Antonio, Texas
    I agree with GCecchetto on using DuPont Chainsaver. A chain will stay clean to the touch if you clean all of the grease off the surface of the chain when new. Spray just the rollers while spinning the rear wheel to distribute the wax/teflon not only on the rollers but also the valley between sprocket teeth. The spray dries in a minute or so and you are ready for another 400 (or so) miles.
    I have never heard the chain noise mentioned above. Maybe it's the Chainsaver or maybe it is because I run my chains a bit on the loose side.
    #11
  12. JdFan
    JdFan Been here awhile
    Jun 13, 2011
    211
    Puget Sound
    Got 22,000 miles out of my last chain oiling it every 500 miles (street miles) If I'm in dirt & sand then every day regardless of miles.
    #12
  13. DR Steve
    DR Steve Been here awhile
    Jan 21, 2012
    800
    Melbourne, Australia
    I too, like the teflon chain lube. We don't get the DuPont stuff here but I'm using a Wurth dry lube product that works really well. I'll never go back to using messy oil type chain lubes.
    #13
  14. kaertner
    May 30, 2017
    724
    Europe
    Teflon is just a brand name of PTFE.
    #14
  15. Jaimoto
    Jaimoto Spaniard in Chile
    Sep 26, 2007
    2,069
    Santiago, Chile
    #15
  16. RCR001
    RCR001 MOTO CHASER Supporter
    Jul 16, 2007
    333
    Planet Cripton
    Is there a place where the Wurth DRY LUBE GREASE can be ordered in North America? ...Had a look with no luck...
    #16
  17. GCecchetto
    Jun 29, 2013
    2,923
    Woodside CA
    I get the DuPont Chain Saver from Amazon.
    #17
  18. JasonK94Z
    JasonK94Z Crash Tester
    Oct 9, 2010
    388
    Denver CO
    I use WD-40 Dry Lube with Teflon. Works well and can be found on the hardware/tools isle in Walmart.
    2003 Kawasaki KLR 650
    2014 KTM 1190 Adventure
    #18
  19. kaertner
    May 30, 2017
    724
    Europe
    Teflon is PTFE
    #19
  20. rubber_band
    rubber_band Adventurer
    Feb 27, 2011
    72
    Portland, Oregon
    I think I heard somewhere that Teflon might be PTFE...not sure ;)
    Anywho, I too have converted to Chain Saver over this past summer dry season. I really like how it sheds a lot of dry dirt and junk. We'll see how it does when we get into the wet again.
    #20
