KTM 450 - 530 Oil Pump Upgrade! How To Article with Pics
Discussion in 'Thumpers' started by Hodakaguy, Jun 14, 2011.
  1. uncktruck
    uncktruck Adventurer
    Jan 28, 2015
    60
    Valley Center, California
    Once again, you're the voice of reason. Thanks for all your help, I have to run to town for oil, I'll let you know how things work out.
    #81
  2. alongat
    alongat Fesh Fesh
    Jan 20, 2010
    4,968
    Windsor, United Kingdom
    Let me know - good luck. I'm currently in the UK but if you get stuck somehow, text me at 14169307405
    #82
  3. akarob
    akarob Rob
    Apr 8, 2009
    9,384
    Skuncasville, CT
    Does anyone have a picture of the Kickstart idler gear to share? Sounds like a good thing to check. Thanks.
    #83
  4. alongat
    alongat Fesh Fesh
    Jan 20, 2010
    4,968
    #84
    akarob likes this.
  5. uncktruck
    Jan 28, 2015
    60
    Thanks for all the advice and illustrations, bike fixed and time will tell if it holds.
    #85
    JoshMurray likes this.
  6. uncktruck
    Jan 28, 2015
    60
    alongat, thanks for your help! Your advise had a calming effect on this old guy which helped get the bike fixed and back on the road. I only have a few miles on it so far, I'll let you know how things go after a 100 or so miles. Thanks again!
    #86
  7. alongat
    alongat Fesh Fesh
    Jan 20, 2010
    4,968
    Excellent, it's my pleasure - I'm sure it will be fantastic.
    #87
  8. Yedmod
    Yedmod Adventurer
    Dec 7, 2005
    94
    MadJackistanni Ambassador to Iowa
    Don't try to put it together with the roller bearing and the steel bushing in the clutch basket. The easy way is to first slide the steel bushing (#3 in the link below) on the shaft (leave the roller bearing off). Next put the clutch basket on. Without the roller bearing on the bushing the basket can move around a little and it will go right on. After it is on the roller bearing (#2) can be slid into the space between the clutch basket and bushing from the front. Everything falls right together that way.
    http://www.partspitstop.com/oemparts/a/ktm/524b8dc0f8700231ac498c70/clutch
    #88
  9. uncktruck
    Jan 28, 2015
    60
    Hodakaguy and alongat, thanks for the help. The bike is fixed and I think it'll do the 2,000+ mile dirt ride I'm about to undertake. Thanks!
    #89
  10. alongat
    alongat Fesh Fesh
    Jan 20, 2010
    4,968
    Nice - enjoy and be safe.
    #90
  11. uncktruck
    Jan 28, 2015
    60
    Alongat, the bike ran flawlessly during the entire 1907 mile trip. The only hiccup was when I laid it down in a river crossing, had to clean every electrical connector on the bike before it would fire. I've really grown to love this bike.
    #91
    alongat likes this.
  12. mbillens1
    mbillens1 Been here awhile
    Aug 29, 2009
    115
    Thanks for the detailed thread -- I bought a used 530 exc that had most of the upgrades done already, but it was good to open the bike up to check. Also had the kick idler spun bushing problem I needed to fix.
    #92
  13. AusMuppet
    AusMuppet Adventurer
    Feb 5, 2018
    66
    Canberra, Australia
    Thanks for the great write up!
    I've got some Blais racing gears and all the other gear needed on the way for install. After spending the time and money on the SXS big bore kit I decided that spending the extra money on this would be worthwhile protection.
    #93
  14. Ronic
    Ronic n00b
    Dec 15, 2018
    1
    Israel
    Hi Tom , i need to replace also My clutch im using not OEM plates should i remove the 2 x spacers disks ? the one that first installed in the clutch basket. i attached your picture , i also noticed different metal plate that has deep engraving someone know if it should be like that ? ill mention that i have a problem in cold start placing 1st gear and bike turn off . only when it warm up im able to enter 1st gear
    #94
  15. akarob
    akarob Rob
    Apr 8, 2009
    9,384
    Skuncasville, CT
    No, that plate should not be like that. That wear is from the large spring washer that mates up against it. Just swap that plate out with one of the other ones.
    The OEM assembly has two large washers - one is flat and the other is a spring washer.
    #95
  16. Finnyfire
    Finnyfire Jedi Master
    Nov 27, 2013
    369
    Big sky country
    I have a question. I am replacing the oil jet on my 08 to the 125. The fiche shows 2 of the same jets. Where does the other one go? Do I need to worry about upgrading the other one? Thanks.
    #96
