KTM 450EXC Muffler Rebuild
Discussion in 'Thumpers' started by StmbtDave, Jan 27, 2010.
  1. StmbtDave
    StmbtDave AKA Invisible Dave
    Aug 1, 2005
    4,700
    Montrose, CO
    I finally got fed up with the loud pipe on my '07 450EXC and decided to see if I couldn't do something about it. I removed the muffler from the bike and started the disassembly.
    Notice the hole in the middle of the can. After pulling the end cap and removing the innards, this is what I found.
    Only half the EXC muffler is actually packed for sound deadening. The packing is only wrapped around the smaller perf pipe shown on the right.
    The hole half way down the can holds what appears to be a large perf pipe, seen on the left. This is actually the Krizman spark arrestor. It is nothing more than a hollow pipe with a set of angled vanes welded in the center. Evidently, these vanes cause the exhaust to spin, keeping any sparks from exiting the chamber :dunno.
    Anyway, the arrestor unit has no sound packing except a thin layer between the screen and the outside muffler can. I assume this is simply to keep the outside can cooler.
    The stock EXC muffler can is 18" long but only half of it is actually a muffler :huh. No wonder it's so damn loud. I can see the solution is to ditch the Krizman and pack the entire can.
    I picked up a used 2-smoke muffler with a full length perf pipe from the local KTM dealer. I pulled it apart and removed the perf pipe.
    This perf pipe is 1 3/8" diam, which is smaller than the 1 3/4" diam stock perf pipe, but it matches the diam of the pipe in my end cap. This will solve two problems. It will easily attach to the end cap and it will slide inside the stock perf pipe. This will allow me add a screen type spark arrestor inside my new muffler.
    I cut the smaller perf pipe just long enough so it would extend about 2" inside the larger perf pipe. I welded a small ridge around the smaller pipe which will hold a washer in place. I then wrapped some stainless steel wire mesh around this section of the pipe and slid the washer on to hold it in place. Volla, a spark arrestor :deal.
    When assembled, the mesh slides inside the larger pipe and the washer seals the connection between the two :clap. I then wrapped the entire assembly in the remaining wire mesh from the Moose packing kit.
    This was then wrapped with the fiber packing and slid back into the stock can.
    I have not yet had it measured with a sound meter but this is how a muffler should sound :clap. It's very much quieter and what was a loud braaaap when you twisted the throttle is now a smooth purr. It's not a constricted sound, but rather a well muffled straight pipe sound. It may not be perfect but it's a hell of a lot better :deal.
    Lewilewi likes this.
  2. Yellow Pig
    Yellow Pig Allergic to asphalt! Supporter
    Oct 28, 2004
    9,829
    Thousand Oaks, CA
    Nice!
  3. Hayduke
    Hayduke ///SAFETY THIRD/// Supporter
    Jun 8, 2004
    49,264
    Salida, coloRADo
    That is a great mod, Dave. My stock pipe on my 525 is just too loud... It's ok at idle but has a real bark when you get on the throttle. I need to start looking for a 2 smoke pipe... :deal Thanks!
  4. ChrisC
    ChrisC Amal sex?
    Feb 25, 2003
    6,325
    Prescott, Arizona USA Earth
    Dave,
    I've got a dB meter, if'n you want to test it. We really should have baselined it before you tore into it...
  5. jjustj
    jjustj Long timer
    Jun 14, 2005
    7,442
    Back in Colorado. Cedaredge or delta or.....
    Other than the can on stock being stamped forestry approved spark arrestor.. I want one!!!!! I don't have a shop or garage .
  6. Esteban
    Esteban Banned
    Jun 7, 2004
    5,787
    Above Golden
    Dave,
    What you did is similar to what I have in mind. As you know I now am the proud owner of a SX can and the EXC can my bike came with. On the exterior they are of the same dimensions. However, the ID of the perforated core pipe and the end cap ID is larger on the SX mufler.
    Does anybody know where to buy perforated steel pipe in different lengths and diameters ?
    (The thought of drilling a thousand holes in a steel pipe gives me the chills.)
    When I do mine I think I will try to make a cone of the SS screen and attach it a few inches inboard of the rear outlet. Its going to be a few weeks before I get the time though.
    On a different note... shouldn't this thread be in the Rockies ?
    Steve
  7. Esteban
    Esteban Banned
    Jun 7, 2004
    5,787
    Above Golden
    Chris,
    Want to come over and test the dBs on my SX and EXC sparky cans ?
    I'll be hot to trot in mid Feb.
    SG
  8. mountain eagle
    mountain eagle terrorist
    May 8, 2004
    3,032
    Denver, CO, USA, Terra, Sol, Milkey Way
    Actually... wouldn't that make for nice get together? It would be nice to test the husky too......
    #8
  9. ChrisC
    ChrisC Amal sex?
    Feb 25, 2003
    6,325
    Steve,
    Decibels and beers sounds about right. I have the older style analog meter, but it should work fine. We could use the SAE J1287 test. 20" from the exhaust tip - 45 degrees @ 1/2 max RPM. How will we determine RPM on your tach-less bike(s)? Guess we could estimate it...
    What say y'all? :1drink
    http://www.parks.ca.gov/pages/1140/files/j1287_199807.pdf
    #9
  10. cRAsH
    cRAsH Banned
    Jul 6, 2001
    19,324
    Nicetown, USA
    I can tell you it was RFL.
    Really Frikkin Loud. :huh
    Nice work, Dave!
    #10
  11. cRAsH
    cRAsH Banned
    Jul 6, 2001
    19,324
    Nicetown, USA
    They're so cute when they jump out of the nest... :wink:
    #11
  12. mountain eagle
    May 8, 2004
    3,032
    Sounds good......... where and when?
    #12
  13. Beemer Pat
    Beemer Pat ...
    Feb 15, 2004
    2,722
    rockiesriders.com
    Nice mod Dave. :nod I'm sure all the rockies guys here will want to hear it to see how you have done. :thumb
    #13
  14. StmbtDave
    Aug 1, 2005
    4,700
    Montrose, CO
    It's like riding a Harley, you don't hear the noise when it's behind you :ear. Loud pipes really do save lives as I'm still here to attest :rofl. Actually, the reason it was RFL was when I disassembled the muffler, there wasn't one thread remaining of the packing I put in last year. It had totally burned out :eek1. I have no idea how long I had been running an empty can.
    #14
  15. cRAsH
    cRAsH Banned
    Jul 6, 2001
    19,324
    Nicetown, USA
    Ask Maaaaahk. :lol3
    #15
  16. StmbtDave
    Aug 1, 2005
    4,700
    Montrose, CO
    Steve,
    You're going to have a hard time making that SX pipe quiet because of the large diameter perf pipe. My '07 EXC came from the factory with a piece of pipe welded into the end cap pipe.
    This reduced the diameter of the end pipe from 1 3/8" down to 5/8" :eek1. Less than half the diameter reduced the cross section area from 1.48 sq" down to 0.31 sq", an 80% reduction! This really choked down the exhaust but was necessary to meet the U.S. EPA Noise Emission Requirements Of 80 dBA (so says my sticker :deal). Of course, as we know this was also required since KTM only uses half a muffler :lol3.
    I suspect your SX pipe has a 1 5/8" diam. This gives a cross section area of 2.07 sq" which is almost 7 times larger than my stock EXC that met sound requirements. You can't stuff the can with enough packing to get it "quiet" without choking it down a bit.
    Dave
    #16
  17. ganshert
    ganshert not sleeping
    Mar 1, 2005
    8,094
    Colorado
    yup
    here
    1", 1 1/2", 2", and 2 1/2"
    #17
  18. Hayduke
    Jun 8, 2004
    49,264
    Salida, coloRADo
    So....
    Has anyone found a "fix"?
    I love nearly everything about my 525, except the NOISE! I have a freshly re-packed stock pipe and the bark when you get on it is just terrible.
    Anyone try a turn down tip? Would this have to be fabricated or is there one available?
    #18
  19. cross-country
    cross-country .
    Aug 2, 2005
    1,816
    Grand Junction, CO
    I have a turn down tip on my 08 450, different can but I would imagine it would fit any PMB tip. I know they make a PMB tip for the 525 can. I am not convinced the turndown tip makes it all that more quiet, accept from the rider's perspective.
    On a slightly different note, I have a friend that up until recently raced AMA supercross. When a db rule was first put into effect some of the privateers were caught off guard for the first couple of races until they could get the parts modify their exhausts. One of the cheats these guys would use to pass sound tests on their bikes was to cover the airfilter so as hide any intake noise. The bikes would start and run but just barely. I wonder if sound proofing the airbox cover with a material like dynamat would help? Just a thought......:dunno
    #19
  20. cedric
    cedric Been here awhile
    Nov 7, 2006
    358
    Calgary
    There was a guy on KTM Talk that added a CRF-X tip into his RFS pipe. I never have much luck with their search tool, but I'll see if I can find the thread.
    #20
