ktm 500 exc?
Discussion in 'Thumpers' started by Visigothic, Apr 27, 2011.
  1. Visigothic
    Visigothic Been here awhile
    Aug 13, 2010
    209
    <HR style="BACKGROUND-COLOR: #575757; COLOR: #575757" SIZE=1><!-- / icon and title --><!-- message -->
    2012 KTM 500 EXC gone will be the 530? Yep; new motor,:eek1 look close at it, water pump, clutch cover etc. I'm guessing a single sump, notice how the bottom of the cases are level front to back unlike the xc-4 where the trans is higher than the power section. It still doesn't mean it holds much oil though. Just a hunch:dunnoNew frame from the 350exc also. Still using PDS rear shock. This looks like a lighter weight machine than the current 530. I wonder if it has the Super reliable KTM EFI :bluduh, looks like it might. This is a photo with the "Knighter" who now rides for the factory team. Only a photo no details on speeds or gearing. I thought this needed its own thread.
  2. jparacing
    jparacing Adventurer
    Sep 6, 2008
    45
    I'm wounderring about the bore and the stroke in the new engine ...
    I hope KTM made it short stroke!
    (About 100mm*64mm would be perfect.:deal)
  3. nijkamp
    nijkamp n00b
    Jun 28, 2010
    8
    Netherlands
    I think I see a carb.
  4. Laphroaig
    Laphroaig Adventurer
    Jan 31, 2008
    39
    Scotland
    Better look at the engine.
    Might be EFI
  5. Visigothic
    Aug 13, 2010
    209
    I wonder if this is the adjustable WP shock it will come with? The head looks alot like a 690 LC4 design but not exactly.
    Bvery NICEzz[​IMG]
    However; looks like "THE EVIL EFI" is here to stay.:bluduh
  6. makazica
    makazica Been here awhile
    May 17, 2008
    884
    Zagreb, Croatia
    Somebody said earlier that it has two cams....doesn't look like that to me...
    EFI's here to stay, that's for sure.
    Beautiful bike nevertheless.
    M.
  7. RideFreak
    RideFreak Torque Junky
    Apr 17, 2009
    16,895
    Out in the NM Dez somewhere
    Looks like EFI to me, I don't see a float bowl. Cool bike!
  8. Sparrowhawk
    Sparrowhawk Long timer Supporter
    Sep 26, 2005
    4,852
    Eastern Washington, USA
    EFI & kickstart, a rare combo these days.
    #8
  9. Visigothic
    Aug 13, 2010
    209
    Good point! Maybe we're saved. Although It might be an EFI system like the CRF 450R. I don't see a starter or battery but then again this is the race bike not a U.S. duel sport version.
    #9
  10. retired motoman
    retired motoman LifeIsShort,EnjoyTheRide!
    Mar 27, 2004
    588
    L/C Valley aka Banana Belt
    Looking forward to seeing what in coming. KTM has been late in showing what we will be riding in the future.
    :clap:clap:clap:clap:clap:clap:clap:clap
    Yes, yes, yes
    #10
  11. LukasM
    LukasM Long timer
    Nov 15, 2006
    5,513
    On a RTW ride - currently touring the U.S.
    That is a WP Trax shock, not going to be standard for sure unless you get a factory SXS bike.
    But the stock shocks on all KTM dirt bikes are fully adjustable anyway (even separate low and high speed compression), they just don't have the fancy coatings, polished internals etc.
    #11
  12. yondering
    yondering Long timer
    Apr 6, 2009
    1,101
    NW Wa. state
    Really? My 02 520 EXC doesn't have separate low and high speed compression adjusters, unless I'm missing something. I thought that was only on the SX shock.
    #12
  13. LukasM
    LukasM Long timer
    Nov 15, 2006
    5,513
    Sorry, I meant to say current models. I think they introduced it on the enduro models when they went to the new frames in 2008, SX-F and SX already had it in the RFS generation.
    #13
  14. yondering
    Apr 6, 2009
    1,101
    NW Wa. state
    Gotcha, thanks.
    #14
  15. Bora20
    Bora20 Been here awhile
    May 6, 2007
    855
    Kamloops, BC, CAD
    Knight rides the PDS and can ride anything he want, so I wouldn't bet on the 500EXC coming without linkage...
    #15
  16. gmtcm
    gmtcm KTM RIDER
    Aug 16, 2005
    557
    ALBUQUERQUE, NM
    I'm impressed! Where can I sign up for one?
    gmtcm
    #16
  17. Visigothic
    Aug 13, 2010
    209
    I was wrong about the 690 design, the head is almost the same as the current 530. Further study reveals that the outward apperance of the heads are the same with the addition of a MAP or temp sensor for the EFI just left and below the spark plug, the cases are different as is the trans and clutch aspects one could assume. Possible good news for those wanting the factory 570 kit or other BB kit which would need only drilling and tapping for the MAP sensor.:clap This may be KTM's way of addressing oil transfer issues and the percieved lack of long term durability due to low oil volume on extended rides. Can't wait to get more data. See pics below to compare heads.
    New 500exc: note MAP sensor location.
    current 530 head: note MAP sensor location as a flat area left and below plug.
    #17
  18. makazica
    May 17, 2008
    884
    Zagreb, Croatia
    Which of the features do you consider relevant in the case of long term durability?
    M.
    #18
  19. johnno950
    johnno950 Long timer
    Jul 17, 2010
    2,219
    David Knights right wrist
    #19
  20. gmtcm
    gmtcm KTM RIDER
    Aug 16, 2005
    557
    ALBUQUERQUE, NM
    As far as the percieved oil problem with the 530's, most of my friends that have 08 and 09 450's and 530's have to add oil to them on longer rides. I'm sure hoping that they get rid of the separate engine/tranny oil compartments and increase the capacity of engine oil. It has kept me from buying the 08 or newer 530's, and I have kept my 525.
    gmtcm
    #20
