ktm 500 exc?
Discussion in 'Thumpers' started by Visigothic, Apr 27, 2011.
  1. Sparrowhawk
    Sparrowhawk Long timer Supporter
    Sep 26, 2005
    4,855
    Eastern Washington, USA
    The 640 wheel comes in two pieces, the wheel itself and the sprocket carrier, which is separated by the rubber dampers. The sprocket carrier has a single bearing that takes all the load of the chain drive and as far as I've found is only available through KTM and it's not inexpensive.
    Fast1 likes this.
  2. Marco propje
    Marco propje Adventurer
    Mar 19, 2020
    24
    Holland
    Lager 640 Adventure achterwiel €36 = 42$
    Ik heb het gehaald op mijn ktm 500 exc 2019.
    Partnumber 0625032057
    Bitingdog and SR1 like this.
  3. MasterMarine
    MasterMarine Long timer
    Jan 22, 2007
    2,682
    Now serving just Snohomish County
    There are 2 different versions of the hub and carrier from what I can tell. One of them has a single bearing and the other has 2 in it. Both versions look like they will work. There are some threads on here about the KTM cush hubs where you can search up the info. In the threads, riders have found other ways to source the bearings besides the KTM dealer.
  4. Sparrowhawk
    Sep 26, 2005
    4,855
    I had a 2000 640 and went through a couple of the sprocket carrier bearings in the 15 years I owned it so I got curious and looked at various years parts fiche. From the 1996 620 EXC through 2006 640 Adventure, the rear wheel was the same and had the same bearing on the sprocket carrier, #28 in the photo. Part #0625032057, GR. BALL BEARING 3205B-2RSRTNG, $89 US. Several on-line retailers said it was not available from the manufacturer or didn't have an "Add to Cart" option. Not good.
    In 2007 KTM brought out the 690 with a two bearing sprocket carrier, #26 in the photo.
    Fast1 likes this.
  5. Bitingdog
    Bitingdog That's not my dog
    Apr 2, 2015
    19,938
    The bad side of the PNW
    It fits fine with the 640 spacers. The 640 wheel works on a 2020 350xcfw too.
    No rabbit hole!!!
  6. Bitingdog
    Apr 2, 2015
    19,938
    I got one recently from BC bearing, no problem. Brought the old one, and they sold me something Japanese. Easy peasy
    Sparrowhawk, RideFreak and NoelJ like this.
  7. NoelJ
    NoelJ Long timer
    Apr 7, 2016
    2,464
    USA
    Bearings almost always have a cross-reference, although recently a lot of things have gotten hard to find. Bitingdog's method - show up with the old one - has never failed me, although I do hear bad things about John Deere bearings. Can't confirm it though.
    Bitingdog likes this.
  8. SR1
    SR1 Going to America!!!!
    Apr 6, 2006
    7,013
    Knockersville, TN
    My wheel isn't coming with the 640 spacers, wondering if I can still find them, or if my 500 spacers will work (?)
  9. Tortuga353
    Tortuga353 Been here awhile Supporter
    May 2, 2017
    487
    Getting ready for the Smokey Mountain +500+. We’ll see how we do but I have the 500 v8 version if weather or issues make things hairy. Hopefully it will be a nice adventure with some fall colors.
    Buildzall, Themastermike and JP4 like this.
  10. Bitingdog
    Apr 2, 2015
    19,938
    Should be fine
    SR1 likes this.
  11. Colemanfu
    Colemanfu King of all manfu
    Jan 27, 2006
    5,883
    DAYTONA USA
    Pulled the skid this weekend in prep for the MX season down here in Florida. Dang it's taken a proper beating! That's a huge indentation on the center :fpalm
    Also spooned on a new front.
    The machine absolutely flew!
    42 MPH is my sweet spot for the 100 footer. Right at that point of uncomfortably fast.
    And that was my first proper MX front tire. I've always ran a fattie for woods but add the 300 to the garage so now it's strictly MX duty for the 500! I also pulled the bark busters for the first time.:norton
    I've always removed the 3lb head light, kick stand, and rear rack. I bet I've removed 10lb of crap.
    I keep the bigger tank but only run like a gallon of fuel.
    Fast1, Bitingdog, Buildzall and 3 others like this.
  12. irlvnt
    irlvnt Adventurer
    Sep 4, 2015
    58
    Colorado
    I'm sure this has been discussed before but I can't find it in my search.
    What is the fix for the gas cap sticking shut? I have a 2012 450 XCW. Once those locking pins click in I need a channel lock pliers to get it off. I just can't seem to push down the external tab far enough to get it to release.
    I try to not twist it on all the way but sometimes it just goes too far.
    I'm also willing to buy an aftermarket replacement if there is a good solution there.
  13. RideFreak
    RideFreak Torque Junky
    Apr 17, 2009
    16,923
    Out in the NM Dez somewhere
    Google KTM gas cap fix, the fix I saw involved using a razor knife to trim a little bit of the plastic. I don't use a stock tank so I never needed to do it.
    Buildzall likes this.
  14. wheels2
    wheels2 Been here awhile
    May 3, 2014
    149
    Wilmington,Ohio
    Trimming a wee bit off the little tabs on the bottom side of the cap work for me.
  15. Bungholio
    Bungholio Long timer
    Oct 9, 2008
    2,802
    Aberdeen, WA
    Wipe a little grease or Vaseline around the opening, I have little trouble getting the stock cap off.
  16. irlvnt
    irlvnt Adventurer
    Sep 4, 2015
    58
    Colorado
    Done! Thanks for the pointers. I cut off two of the three tabs. Now it's easy to work like it should. I also used a dab of grease on the gasket. I've used grease before and has helped some for a while but always got stuck again.
    Apparently there is quite a but of variability in the fit from the factory. Plenty of folks have had problems with this, and of course they just get called out as weak idiots by those whose caps worked properly.
    Buildzall and wbbnm like this.
  17. TwilightZone
    TwilightZone Long timer Supporter
    Dec 2, 2008
    11,395
    Behind the Redwood Curtain
    Short maint turned into a big maint. 2014 500exc.
    Thought I'd bleed the clutch and brakes. Yeah, why not keep ahead of stuff.
    Couldn't get the clutch to bleed properly. After about 3 hours of attempting to bleed...
    I pulled the inner 'drain' gasket off. Dammit. All kinds of crap was in there.
    Looked at the brake master cylinder.... the inner gasket had bloated and partly disintegrated.
    Probably crappy materials from Brembo. Not resistant to brake fluid.
    Now it's rebuilt master and slave cylinder.
    If you've got a bike of that vintage better check the gaskets/o-rings etc.
    DesertRatliff and Bitingdog like this.
  18. wbbnm
    wbbnm Long timer
    Dec 18, 2007
    6,714
    MN and NM
    I had a problem bleeding the clutch about a year ago. I decided it was a procedure problem in that I probably wasn't moving the lever properly. I ended up back forcing fluid up the line from the bottom with a syringe. It took a few tries, but this finally worked and the clutch works fine now.
    It never occurred to me the inner drain gasket. Mine was a 2013. So where exactly is the inner drain gasket and how do you check it?
    SR1 likes this.
  19. Colemanfu
    Jan 27, 2006
    5,883
    DAYTONA USA
    And the braaap vid from the first day of MX season!
    Bitingdog, dave0 and dwdantzler like this.
  20. TwilightZone
    Dec 2, 2008
    11,395
    Pretty good coverage on rebuilding the master.
    White thing he is prying out. Piece of clutch cover gasket was under it.
    Bitingdog, wbbnm and SR1 like this.
