Ktm 500 Husky 501 Oz Adventure bikes
Discussion in 'Australia' started by bigbrad, Jan 2, 2017.
  1. Blakduk
    Blakduk Don’t be too practical.
    Sep 30, 2007
    3,234
    Cooroy
    These are the ones I've got. I've only just installed the rear two. I can't recommend them yet, but you'll see in the picture they are really bendy. And cheap.
    Just remember not to join the black wire to the black wire. The black on the KTM/Husky is NOT the negative, the brown is (and they don't work if you reverse the polarity, unlike 'normal' blinkers).
    i.e. the blinkers have black and red, the KTM blinker wiring has black and brown.
    Do you know how I know??!!
    I know, I know, I should have tested both polarities before I tidied it all up.
    And page 101 of this thread has a lot of info on good connectors.
    https://www.ebay.com.au/itm/4pcs-Be...-Lamp-Amber-/123901573755?hash=item1cd91bfa7b
    nzrian likes this.
  2. AUSSIEADV
    AUSSIEADV 2wo left foots
    Sep 5, 2006
    11,509
    Ned and Wild’s fight site
    The whole purpose of a diode to prevent reverse flow, light emitting or not.
    Yep, brown is negative.
    The bendy indicators are not only brilliant but cheap. There is a flasher you can get thats plug n play. Alternatively to those huge resisters you can mod the wiring up front otherwise indicators borh sides flash because of the dash indicator. Ill try and find the info.
    https://www.customled.com/blogs/cus...-problem-on-motorcycles-with-led-turn-signals
    These are the indicators i run.
    https://www.ebay.com.au/itm/4-Pcs-Amber-Flowing-Motorcycle-Turn-Signal-Indicator-Light-Motorbike-12-LED/233226249855?_trkparms=ispr=1&hash=item364d5e267f:g:xQoAAOSwKzxc2THO&enc=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&checksum=23322624985588b5d8ce7ac94a14901d99ce332027cc
    These are the diodes you need to implement into the wiring mod. Very simple mod.
    https://www.ebay.com.au/itm/1N4000-IN4000-Series-Rectifier-Diodes-IN4001-IN4007-General-Purpose-DO-41/362735291452?_trkparms=ispr=1&hash=item5474b54c3c:m:mp7fPKNH54lclSbLqZtx_JQ&enc=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&checksum=3627352914527b7ba73b6f3c4fbeb861caa374d81b2e
    Adjustable flash rate flash relay.
    https://www.ebay.com.au/itm/LED-Tur...707471?hash=item1a08bc4b4f:g:w8MAAOSwXXJar0cH
    nzrian likes this.
  3. AUSSIEADV
    Sep 5, 2006
    11,509
    nzrian likes this.
  4. nzrian
    nzrian renegade master Supporter
    Feb 20, 2009
    1,727
    Queenstown , NZ
    thanks guys, i have had a wee spend up on eBay, got the 2 pin adjustable rate flasher relay, a set of 4 bendy indicators and some 1N4001 diodes for the indicators light.
    The motominded package turned up yesterday, so this information regarding the indicators is good timing.
    This is the super mount v2 and their dash.
    Looks to be very well thought out, and we'll made, bit it ain't cheap.
    The dash comes with a double 3.0 amp USB charger with integrated volt meter, and a push button on/ off switch that I will hook up to the heated grips.
    The ktm wiring is a bit of a cluster fuck to be fair.
    I see on the 2020 models they have tidied it up a lot, with plastic guides over the radiator hoses to prevent chaffing of the wiring .
    I am also trying to make a poor man's version of a Baja designs light.
    Early stages yet.
    AUSSIEADV and Blakduk like this.
  5. nzrian
    Feb 20, 2009
    1,727
    Queenstown , NZ
  6. fnatic
    fnatic Been here awhile
    Apr 28, 2013
    244
    VIC, Beechworth
    Looks nice, let us know what it's like....
    Just ordered the V2 mount and the Epic light setup but I didnt get the dash, let me know what you think of it... are you installing an ignition with a key as well?... will let you know how the Epic setup goes.... looks like the mount tidies the loose cluster fuck behind the headlight nicely....
  7. nzrian
    Feb 20, 2009
    1,727
    Queenstown , NZ
    Not using a key switch.
    I will leave that hole vacant for the meantime.
    The epic is out of my price range at the moment, I still have to pay for an IMS tank.
    I will advise on the rack when it arrives.
    fnatic likes this.
  8. Knackers
    Knackers Polishing Turds
    Sep 18, 2006
    9,646
    Lower Eyre Peninsula, South Australia
    So when is a 50mm fork cap not a 50mm fork cap?
    Was swapping over the fork springs in the 500 and being a cheap bastard did not want to buy a fork spanner. Took the forks and springs to the only two MC shops in Port Lincoln. Both had 50mm fork spanners for the caps but neither would fit. Could remove the fork caps with the shifter but couldn't undo the bottom nut as the shifter would have screwed the caps. Luckily my neighbor is a mechanic/auto electrician and had a 50mm socket. Worked a treat.
    The 50mm socket would fit the caps but not a dedicated fork spanner. Anybody have any insight into this?
  9. AUSSIEADV
    Sep 5, 2006
    11,509
  10. Blakduk
    Sep 30, 2007
    3,234
    Cooroy
    Looks neater than the cluster fuck behind my front headlight.
    nzrian likes this.
  11. nzrian
    Feb 20, 2009
    1,727
    Queenstown , NZ
    AUSSIEADV likes this.
  12. AUSSIEADV
    Sep 5, 2006
    11,509
    Not mine Rian. A fella in Europe sent all this to me. If anyone wants the CAD on those let me know and ill send them through.
    Rian, pic of mine below....
    BF2D124A-027A-4B51-8467-7A0A78E7EBBB.jpeg 33815124-5F11-45B5-8AA6-D1C1D73296A2.jpeg
    fnatic and nzrian like this.
  13. AUSSIEADV
    Sep 5, 2006
    11,509
  14. J_B
    J_B Mid-life Crisis
    May 26, 2010
    619
    Cottesloe - Western Australia
    Looking for a 20 acerbiz tank for a 2012 ktm500 - message me if you have one in the shed gathering dust
  15. Blakduk
    Sep 30, 2007
    3,234
    Cooroy
    Not the usual terrain - Hastings Street, Noosa. It’s now the coffee run bike. More agile than the Harley crowd. Only way to be guaranteed a park!
  16. BygDaddee
    BygDaddee Where do I get a pie
    Oct 26, 2012
    10,681
    Brisbane Northside, OZ
    How do you fit your pony tail into your helmet
    Blakduk likes this.
  17. Dukehunt
    Dukehunt Lost in Translation Nev 2.0 Super Moderator
    Feb 20, 2007
    3,569
    Melbourne North
    @Blakduk and @BygDaddee should be motorcycle detailers, neither of them ever look like they see any dirt..:hide
  18. a2zworks
    a2zworks Trust me, I'm Pablo
    Mar 11, 2013
    2,346
    West Hobart
    A bit dodgy in Noosa I see.
  19. Blakduk
    Sep 30, 2007
    3,234
    Cooroy
    Have just heard some interesting info about the fuel filters (in the tank) getting sucked inside themselves with crap. Even with running clean fuel and a tank sock filter.
    Apparently a main cause of the bike losing a bit of mid-range. Where are you guys picking up your fuel pump filters from. I'm trying to find who sells them it's something like Big Bike Adventure tours at Newcastle who supply them at a fraction of the KTM price....anyone have any info or contact link/phone? (It's not the email link google found to a Mark Cockerill is it?)
    (Photos courtesy of Rex Fleiter) upload_2019-10-18_18-31-16.jpeg upload_2019-10-18_18-31-41.jpeg
    nzrian likes this.
  20. nzrian
    Feb 20, 2009
    1,727
    Queenstown , NZ
    Put a cheap eBay screen on ($30)
    https://ebay.us/UlLE7W
    No ride yet, so can't comment on how it works.
    In the middle of sorting this mess out.
    AUSSIEADV and Dukehunt like this.
