Ktm 500 Husky 501 Oz Adventure bikes
Discussion in 'Australia' started by bigbrad, Jan 2, 2017.
  1. Hoots
    Hoots Long timer
    May 16, 2011
    5,205
    If you're going to adventurise this one, not tempted by the new incarnation of the 690/701 ... ?
    From memory, you were one of the ones happy with the old 690 - that said, does seem to have turned a corner post 2019 ...
  2. bigborett
    bigborett Hipster Supporter
    Nov 29, 2014
    6,757
    Melbourne, Australia
    Quite happy with my old 690.
    Have thought for sometime though if were to upgrade I'd probably go an adventurised 500.
    A bit more separation between mounts.
    Just thoughts at the moment though.
    Hoots likes this.
  3. tileman
    tileman Long timer
    Mar 15, 2007
    2,036
    Melbourne, OZ
    GodSilla likes this.
  4. Grog
    Grog Old Bastard
    Mar 19, 2010
    401
    Perth, Australia
    G,day, anyone out there got the orange paint code for the KTM exc's... thanks.
  5. Grog
    Grog Old Bastard
    Mar 19, 2010
    401
    Perth, Australia
    Got it... RAL 2009 thanks all.
  6. GodSilla
    GodSilla I did that.
    Sep 21, 2006
    13,120
    GodSowncountry Australia
    :clap Found it!
    The flasher relay sits in a recess directly below the instruments on a 2020, a 2-pin affair. There is a square opening in the speedo mount plastic that it fits up into.:thumb
    Kiwirich and nzrian like this.
  7. GodSilla
    Sep 21, 2006
    13,120
    I took a nice ride since the weather is conducive today. Dirt around the back on Polacks Flat Rd to Morans Crossing, a short tar tansport to Buckajo Way, then to Bega, then Reedy Swamp Rd and Goats Knob Trail (aptly named) to Tathra via Mogareeka, where I had a really good hamburger at the takeaway opposite the park there. Home via tar to Doctor George Mountain Rd, a short detour to check out the lovely Murrays Flat Rd and back, then Buckajo to Morans Crossing and 10k tar home.
    I filled up in Bega at 113 ks for 5.2 litres, so roughly 22k per litre with mostly dirt roads.
    Also, I am now running a Mitas C02 StoneKing rear tyre, I can report good grip and bugger-all wear, it should last at least as long as a Dunlop 606 with a lot better grip.:clapIt will easily outlast the other 2 tyres I tried which were dead at 700 k's:pope and the grip is at least as good, it is a proper full knobby, an ex-Trelleborg pattern with strong sidewalls and puncture resistance. I am running it at 12 psi.
    nzrian likes this.
  8. Hoots
    Hoots Long timer
    May 16, 2011
    5,205
    That Stone King is a wild looking tyre - not squirrely at all ... ?
  9. GodSilla
    Sep 21, 2006
    13,120
    No mate, it hooks up better than either of the previous tyres I ran on this bike. Straight-line drive is really good, I'm not so keen to test sliding since the power upgrade and a crash, my toe is healing nicely but my good left knee is suffering from tears somewhere due to that crash and is playing up so I have 2 crook knees now :baldy, so at my age discretion is the better part of valour eh. Running at 12 psi it works really well, I used to run them at 15psi on the XR but that weighed 30 kilos more too. They are a really good hoop. I have an 18 x 120.
    Hoots likes this.
  10. smacka
    smacka Tripper head
    Oct 13, 2005
    60
    Brisbane Bayside
    What really disappoints me is that we're (ie I agree with you!) talking about tyres such as the Stone King & Dunlop 606 as still being the go-to standard.
    For fuck's sake, haven't the rubber gurus made any advances in the last 20+ years?
  11. troy safari carpente
    troy safari carpente Team f5oolery
    Nov 21, 2005
    35,587
    "Swednavia" - f5ederation of Scandwegia
    Surprisingly not really... not as far as real off road oriented rubber goes, anyway...
    Dunlop D606
    MITAS C-02
    Both the C-02 and D606 are street legal, yet aggressive off road application rears.
    The C-02 was my rear tire of choice on the SE 950R when the riding was predominantly (@ 80%) off road and some gravel fire trails etc. Limit the asphalt travel with the C-02... the big tread blocks just wear the lead edge off , and as you can see with a plain eye... the contact patch (on a hard asphalt surface) with the agressive block spacing is really SFA.
    The D606 is probably a better all rounder/compromise if you are looking for road miles longevity (due to the more uniform tread block spacing and profile), and yet still respectable off road and gravel grip...
  12. Hoots
    Hoots Long timer
    May 16, 2011
    5,205
    This is really not true ...
    There's an enormous spectrum of off-road tyres now - in an enormous range of sizes
    Everything from the 'trail' type tyres, to ADV, desert / rally, enduro and the trials hybrids
    The difficulty is knowing where to start - fortunately consumables, so you can work your way around a bit
    That said, D606s are dependable and a known quantity - and pretty cheap - and never a bad option for fire trails etc
    BygDaddee likes this.
  13. troy safari carpente
    Nov 21, 2005
    35,587
    What they are like when new is one thing... but the wear pattern after some miles tells the story...
    C-02
    the side knobs are like new... but middle blocks worn to about half. Translates to; "tip the bike in on a hard asphalt road surface, and it will step out like a 500cc GP two stroke - due to the sudden profile/camber change".
    D606
    ... also side knobs like new... and center blocks about half worn down... but due to the intermediate side treadblock, the transition from vertical to turning is a much more predictable issue on asphalt road surface.
    Which is why I'd give the D606 the nod in a real "dualsport" application, where good asphalt manners are a part of the requirement... which I think is the question @Hoots was asking.
    GodSilla and BygDaddee like this.
  14. troy safari carpente
    Nov 21, 2005
    35,587
    I was referring to smacka's comment specifivally reagarding the C-02 and D606 for off road application...
    The C-02 is a direct descendant/copy of the Trelleborg "Military special" enduro tire that's been around since the mid 70's... that was the "haven't they made any advances in the last 20 years" comment I reacted to.
    ... Trelleborg (the company) acquired the MITAS brand back in 2015... but MITAS have been manufacturing motorcycle tires under the Trelleborg IP and design rights since long prior to that.
  15. troy safari carpente
    Nov 21, 2005
    35,587
    In either case... both of these "hoops" are great choices for a 500/501 Ozventure bike... depending on what and where your ride focus is.
    This little coloring in exercise illustrates what I was referring to earlier - regarding the "contact patch" of the two different tires when cornering. Regardless if we're talking hard pack gravel, or asphalt; here are the tread block patterns in direct comparison - regarding lean angle and the percentage contact area. Same series of three tread blocks on each - taken from real world photos, of real world usage.
    C-02
    D606
  16. BygDaddee
    BygDaddee Where do I get a pie
    Oct 26, 2012
    11,666
    Brisbane Northside, OZ
    And thats why they haven't changed the 606 for what would seem like a decade, the balance of budget/performance/wear results in a tyre you can sell tonnes of
    david61 likes this.
  17. nzrian
    nzrian renegade master Supporter
    Feb 20, 2009
    1,780
    Queenstown , NZ
    Heads up for any ims tank owners, this tank was fine 60 hrs ago.
    Gonna pack the spine pad up a couple mm and see if that helps.
    Also changed the in tank filter, this one has about 60 hrs, bike has a total of 93 hours.
    Kiwirich and GodSilla like this.
  18. anadel
    anadel Been here awhile
    Apr 16, 2006
    221
    Mine looked like that at less than 30 hrs. Completely normal for this bike. One of the reasons why I installed one of the Best Dualsports large filters.I wonder what a T7 filter looks like with time on it?
    Kiwirich likes this.
  19. nzrian
    Feb 20, 2009
    1,780
    Queenstown , NZ
    Yah my 35 hr filter change looked a lot worse than this one.
  20. Blakduk
    Blakduk Don’t be too practical.
    Sep 30, 2007
    3,440
    Cooroy
    Mine at 100 hours was the same colour, but not shrunken much.
    nzrian and Kiwirich like this.
