KTM 525 EXC as an Adventure Bike
Discussion in 'Thumpers' started by Karnage, Jan 31, 2007.
  1. radmann10
    radmann10 Derf Supporter
    Apr 29, 2014
    1,131
    Phoenix, AZ
    I just changed the oil on my, new to me, 2007 KTM 525, and found the long oil screen is not there. The PO(s) must have removed it. What are the know issues from running without the screen?
  2. Fast1
    Fast1 Twisted Throttle
    Aug 18, 2007
    3,535
    Bridge over Troubled Water
    If you install one and run it 200 miles and then change the oil and find nothing in the screen... seems you lucked out. However if you find all types of fine particles stuck in the screen, you may want to have a conversation with the previous owner.
    SnowMule likes this.
  3. Ned1
    Ned1 Don't be a knuckledragger
    Dec 20, 2005
    1,169
    BC/WA
    If you didn't see anything ugly in that last pan of oil you dropped out of the sump maybe just get a new screen, ride a while and check it after a few hundred miles thing. Lots could go on as a result of no screen but no need to knee jerk and tear the motor apart chasing maybe's and might's.
    Of course all said with zero knowledge of said bike :1drink
    PS let's see it!
  4. SnowMule
    SnowMule still learning what is and isn't edible Super Supporter
    Jul 2, 2009
    23,227
    I LIVE IN A GIANT BUCKET
    That one'll pick up clutch skuzz. I wouldn't run without it. :dunno
  5. Themastermike
    Themastermike Think you caught me in a coma Supporter
    Jan 20, 2011
    3,171
    So Ill
    Will but never does
  6. SnowMule
    Jul 2, 2009
    23,227
    Definitely does for me. More often after new friction discs, but :dunno
  7. radmann10
    Apr 29, 2014
    1,131
    Phoenix, AZ
    Ok, so the large screen picks up clutch crud. What does the small screen catch?
  8. BaldKnob
    BaldKnob I Wanna Ride
    Jun 3, 2013
    1,705
    SENC
    Question for the collective... can the shift shaft be removed without splitting the cases? I broke the bolt off, got most of it out then proceeded to break off a tap as I was cleaning up the threads. This is on a 520 but I’m assuming not much change in the transmission department. Would be nice to just take the clutch out to get to that shaft but...
    Here’s a recent pic of the old girl... looks rough but still lofts the front thru the first 5 gears. 1B8A2A61-6348-48AC-BE0F-34278D901BFD.jpeg
  9. Themastermike
    Jan 20, 2011
    3,171
    So Ill
    Dunno
  10. Themastermike
    Jan 20, 2011
    3,171
    So Ill
    Yup
    Pull the clutch cover and the clutch basket.
    EZ PZ
    BaldKnob likes this.
  11. never been
    never been Adventurer
    May 26, 2016
    41
    Tauranga New Zealand
    Well here is my new to me 07 525 with 240hours...no stealing a low hour one here in NZ. Although one did sell two months ago with 7 hours on from a deceased estate. Got over $9000NZ.
    Mine goes like new compared to my 03 525 that I still need to sell so pretty happy here down under. 20190921_141930.jpg
  12. Northwoods Snowman
    Northwoods Snowman Adventurer
    Apr 30, 2019
    31
    Cloquet, MN
    What do you guys think of these bits? First picture was from my most recent oil change after 15 hrs, and second picture was from the previous oil change where I accidentally ran it about 30 hrs. Steel was stuck to magnet on the drain plug. Pieces break and don't really bend indicating they are hardened. Took the clutch cover off and found zero evidence of anything chipping. Could it be the shift dogs? Engine has 80 hrs on it. 20191019_081624.jpg 20190824_091940.jpg
  13. BaldKnob
    Jun 3, 2013
    1,705
    SENC
    Take the valve cover off and look at the cam/ bearings and rest of the valvetrain.
  14. skibum69
    skibum69 slave to gravity Super Supporter
    May 14, 2006
    12,025
    New Melbourne, Newfoundland
    How much does the MXC tank hold?
  15. RideFreak
    RideFreak Torque Junky
    Apr 17, 2009
    14,057
    Out in the NM Dez somewhere
    If you're talking about the one with the built in wings it's 15L.
  16. lamotovita
    lamotovita DAMN SNOWBIRD!
    Oct 5, 2007
    3,050
    WA/AZ, USA
    Assuming the metal came exclusively from the rear drain plug there's no need to look under the valve cover, if you're looking for steel from the top end better to look under the mag cover. The shrapnel looks like it could be from gear teeth.
  17. Ned1
    Dec 20, 2005
    1,169
    BC/WA
    +1, those long splintered ones come from a gear face.
  18. skibum69
    May 14, 2006
    12,025
    Thank you
  19. Northwoods Snowman
    Apr 30, 2019
    31
    Cloquet, MN
    Being a constant mesh transmission, what is going to shave the tips of the gears off?
  20. thirsty 1
    thirsty 1 Rider Supporter
    Feb 9, 2009
    3,637
    Top Hat - Seattle Wa.
    The ol girl still has all of the power I could ever use. @108 hours she’s a keeper! 05 525
    5601EE19-556E-4500-8661-B948947B885B.jpeg FDBA33DE-62A0-4859-A24E-54F83933BD5E.jpeg
    BaldKnob, Whodatschrome and Ned1 like this.
