KTM 525 EXC as an Adventure Bike
Discussion in 'Thumpers' started by Karnage, Jan 31, 2007.
  1. Whodatschrome
    Whodatschrome Long timer
    May 4, 2015
    4,506
    North of North Plains
    No need to soak the filters before you install them. The factory service manual shows that you lay the bike on its side, fill the oil filter reservoirs about halfway, slowly insert the filters, then screw on the caps.
    BaldKnob and cmbthumper like this.
  2. Grreatdog
    Grreatdog Long timer Supporter
    Apr 6, 2007
    39,503
    Annapolis, MD
    I'm scared to torque the filter cover bolts. First time I changed the oil I set my little 1/4 drive torque wrench to whatever my manual said.
    But I was already saying nope before it ever clicked. I was afraid it would strip even at the minimal factory torque. Or maybe my torque wrench is way out of spec.
    cmbthumper likes this.
  3. cmbthumper
    cmbthumper Long timer Supporter
    Sep 29, 2018
    1,389
    Ramona, CA
    Vid 2
    Off the grid and RTWstare like this.
  4. portero72
    portero72 Been here awhile
    Aug 25, 2007
    459
    austin, tx, y'all
    Love it. Dig how the 525 goes from ‘putt putt putt’ to ‘ludicrous speed’ in .0185 seconds.
  5. cmbthumper
    Sep 29, 2018
    1,389
    Ramona, CA
    Thanks. Appreciate you looking. As you can tell i am not a YT or a video editor.
    You nailed it for me 100%. I am a very very lazy rider who likes to look around, "putt" and just enjoy being out. Probably why i like my XR's so much. I'm never in a hurry in real life or on my bikes buuutt when i want to grab a handful, stand to attention and wake up like i just had a redbull that's the bike i wanted and i think i found it.
    enduro16 likes this.
  6. portero72
    Aug 25, 2007
    459
    austin, tx, y'all
    Bingo. I had 2 XRs prior to the 525. I loved the ‘pull you along at idle all day’ feel of the bikes, but the dead spots after midrange always had me looking for more. So I asked another inmate about adding a cam. Turns out the inmate (cough, @shinyribs) was a kool aid pimp and essentially manipulated me into trying orange to get what I was after. :)
    Serendipity! Same chug ability, 6 gears, button, superior suspension, and power after midrange! She’s a keeper.
    enduro16 and cmbthumper like this.
  7. Juddvong
    Juddvong Adventurer
    Jun 2, 2014
    40
    Finally took my bike dual sporting for this first time. Covered almost 400 miles in the Ozark mountains in two days. The bike performed flawlessly but the forks were way too harsh. I was wondering if anyone had some insight on suspension setup for dual sporting. A lot of the information I could find were all for racing.
    The forks were very harsh on the initial hit, it was not absorbing the rocks very well. The rear shock was alright but after 15 years I would like to get it serviced. My bike was bouncing all over the rocks compared to my friends stock crf250l lol.
    Straight or progressive rear spring for dual sporting? Who would you recommend to rebuild and re valve my suspension?
  8. Northwoods Snowman
    Northwoods Snowman Been here awhile
    Apr 30, 2019
    203
    Cloquet, MN
    I've noticed the same thing on my forks. I've already resprung but curious on revalving.
  9. enduro16
    enduro16 Long timer
    May 15, 2012
    1,722
    The woods of northern IL.
    FYI Need to know the year of the forks?
  10. cmbthumper
    Sep 29, 2018
    1,389
    Ramona, CA
    AND bike. The manual is very specific on the 250, 400, 450, 525 and even the six days. These are in my phone so I can making changes this weekend on the trail.
  11. enduro16
    enduro16 Long timer
    May 15, 2012
    1,722
    The year of the bike doesn't matter because on my 2003 I've got 2007 forks, huge improvement
  12. Juddvong
    Juddvong Adventurer
    Jun 2, 2014
    40
    My bike is a 2005 450 EXC. I wasn't aware there wasn't a difference between the years.
  13. shinyribs
    shinyribs Thumpers for life
    Sep 24, 2011
    6,786
    The South
    You are welcome :D
    Stiff initial hit on forks can sometimes just be a case of stiction. Checking fork alignment is an easy thing to do real quick.
  14. Whodatschrome
    May 4, 2015
    4,506
    My suspension guy made me buy a Motion Pro fork alignment tool. I’m glad I listened to him. It’s WAY more accurate than using the “bouncing the forks” method.
    bark sampler, Brtp4 and ItsDoAble like this.
  15. cmbthumper
    Sep 29, 2018
    1,389
    Ramona, CA
    Agreed. After a very minor crash on my 500 I chased down twisted forks for 2 weekends. Said "F" it I will try this snake oil tool. Definitely NOT snake oil and in 5min my forks were smooth as could be.
    Whodatschrome likes this.
  16. Dao1
    Dao1 Long timer
    Mar 17, 2014
    2,198
    Austin TX
    your '05 came w/ a new frame, and a new cast swingarm. with this new swingarm, ktm moved the lower shock mount further towards the rr axle to slant the pds shock more horizontal. in doing so, the rr spring didn't need to be so stiff, and so your valving on the shock in '05 changed quite a bit from the 2002-2004. However, the forks were still of the 2002-2004 design, which was a mess b/c WP didn't know about a particular pressure build up between the slider and fork tube cavity, so those yrs forks 2002-2005 have a midstroke harshness to it. In 2006, wp forks got two holes drilled through the chrome sliders to relieve this pressure build, and cured that problem. but there was one other problem that didn't get fixed until 2007, and once that was implemented, the wp forks finally worked like normal, which is to say it still wasn't all that great compared to kyb and showa, but it was good enough for gov't work.
    BaldKnob and lamotovita like this.
  17. Juddvong
    Juddvong Adventurer
    Jun 2, 2014
    40
    Thanks I just purchased it! Looks like a handy tool and it was cheaper than I thought it would be.
    Thanks for the info. I'll keep an eye out for someone parting out some 07 forks.
  18. shinyribs
    Sep 24, 2011
    6,786
    The South
    Very interesting stuff! Wondering where I can get more info on these vent holes. That's something a fella can fix at home
  19. Grreatdog
    Apr 6, 2007
    39,503
    Annapolis, MD
    Protune suspension did my forks and they came back amazing. For one thing, just having them sprung right for my 200 lb riding weight made a big difference.Whatever Corey did worked. I haven't touched the clickers since installing them.
    Corey's opinion of my 05 shock was that it wasn't worth pouring money into. It is what is - click until it works. Which on mine was a pretty odd setting of way less rebound and a bit more compression than factory settings. That was too help with the over the bars kick it had on hard hits.
    Then Brian at AtomicMoto made me a deal I couldn't refuse on his shock and I had Protune rebuild that. Now both ends are pretty damn good. Still not quite as plush as my 640. But even at 6'2" I could barely touch the ground on that 640. My 525 feels like a minibike by comparison.
    My point being, it's worth having your forks tuned by a pro. That made a huge difference. If you aren't happy at the rear, replacement with a later year or different model shock is likely the best bet. Brian's shock is the bomb. I think he is still kicking himself for selling it to me.
    I don't pimp a lot of vendors, but Protune did a great job: https://www.facebook.com/people/ProTune-Suspension/100063467981907/
  20. Dao1
    Dao1 Long timer
    Mar 17, 2014
    2,198
    Austin TX
    per pic below, the two holes near the end of the tube is existing. the holes to drill is 170mm from the tube's end, per scale shown.
    Brtp4 and shinyribs like this.
