KTM 640 Adventure owners, sign in please...
Discussion in 'Thumpers' started by creeper, Feb 20, 2004.
  1. MCLARDIE
    MCLARDIE Adventurer
    Mar 22, 2005
    65
    scotland
    been a while since i posted a picture in here
    majle, Jorugburn, joe cool and 4 others like this.
  2. meat popsicle
    meat popsicle Ignostic
    Feb 9, 2004
    14,587
    Circumlocution Office of Little Dorrit
    Haven't heard of such a thing. Detonation may not be detectable given the lively percussion of the LC4 when happy. I was told exhaust gas analyzer with NOx is needed to check for poor combustion.
    Any emissions testing station has that. Maybe they could be used cheaply if we knew how to read the results.
  3. Powderfinger
    Powderfinger Been here awhile
    Mar 3, 2013
    120
    SW PA
    What about a bore scope through the spark plug hole before and after a modification?
  4. timeOday
    timeOday Long timer
    Jun 20, 2008
    3,039
    New Mexico
    What I would like is a pressure sensor inside the cylinder. Building pressure is the whole point of the combustion engine, and overpressure is what wrecks them. It would give you a good sense of the engine's health including possible spikes from detonation.
    Oh look, here is a spark plug with a pressure sensor.
    https://www.tfxengine.com/SensorsOverall.html
    Now you would need data processing and display of some sort.
  5. NitroAcres
    NitroAcres MotoBiggots Suck Supporter
    Mar 28, 2010
    1,042
    A ChickenHouse in NorthGeorgia
    Bore/Snake Camera works great..
  6. twqqis
    twqqis Adventurer
    Sep 15, 2010
    86
    Africa
    You mention minor changes there; wouldn't even a different silencer/slip-on be part of a minor change that can cause mentioned issues (req retune)?
  7. twqqis
    twqqis Adventurer
    Sep 15, 2010
    86
    Africa
    That spark plug is interesting.
    Do you want a real-time (on the bike) dashboard display of data? Else: https://www.tfxengine.com/software.html
  8. 2 SPOT
    2 SPOT bring the rape whistle
    Dec 14, 2005
    6,472
    Payson AZ
    exhausting the cylinder is always good, its the filling that causes problems.
    the first thing i do to all my bikes is open the exhaust with a quality slip on,, fueling usually needs to be done not because of the slip on but because the bikes are lean from the factory,,, i almost never change the intake side of things.
  9. timeOday
    timeOday Long timer
    Jun 20, 2008
    3,039
    New Mexico
    A dummy light on a simple automotive knock sensor would ease my mind, when I find myself riding fast in hot weather up a hill or something.
    But it would be neat to get more detailed information to help decide what to repair (time for a top-end job?) or upgrade.
  10. Antti
    Antti Been here awhile Supporter
    Mar 14, 2003
    469
    Finland
    I was thinking the same, sensors can be found from car engines.
  11. timeOday
    timeOday Long timer
    Jun 20, 2008
    3,039
    New Mexico
    I was changing the front tire on my 2003 Adventure this evening and noticed the front wheel spacers and seals look pretty shot. The bearings seem OK.
    I was looking on RMATV and noticed something odd, the EU parts diagram matches my bike (normal spacers right and left), the US diagram has a big funny spacer on the left which is out of production.
    Do any of you guys have the "USA/AUS" setup?
  12. 2 SPOT
    Dec 14, 2005
    6,472
    Payson AZ
    i did not have that big spacer on my 03,,, wierd.
    timeOday likes this.
  13. timeOday
    timeOday Long timer
    Jun 20, 2008
    3,039
    New Mexico
    OK, I just wanted to make sure my bike is normal before ordering the parts, I figure if it's using some alternate setup then what I buy might not fit.
  14. Antti
    Mar 14, 2003
    469
    Finland
    Does it have the speedometer drive there?
  15. timeOday
    timeOday Long timer
    Jun 20, 2008
    3,039
    New Mexico
    Mine does not, it uses the magnet pickup (Hall effect sensor?)
    2 SPOT likes this.
  16. luk.mxtr
    luk.mxtr Adventurer
    Sep 2, 2019
    26
    UK
    Sorry for late reply , I didn't check the forum from a while .
    I don't have experience with the bushing from this eBay Seller .
    I simply suggest you to try this bushing as earlier you was asking for any source or replacement for the discontinued lower shock bearing .
    So ...this one is still available.
    Maybe it is worth to ask directly the seller about longevity of that part ?
    albacore likes this.
  17. luk.mxtr
    luk.mxtr Adventurer
    Sep 2, 2019
    26
    UK
    Could you be so kind and tell me what is better for you for off road riding FCR41MX or FCR39MX ?
    Is the difference noticeable between two of them ? ( Low RPM Torque , fuel consumption , throttle response )
    Would you choose FCR39MX over FCR41MX rather ?
  18. albacore
    albacore Long timer
    Sep 6, 2008
    1,066
    Oregon 89' above sea level
    I bought one for $30 but haven't installed it yet, my initial impression is underwhelming. The steel insert drops in the bronze with slop already, maybe I can get a couple years out of it then have someone make a nicer one up.
    I do appreciate the link though, it's better than what's in it now and it's frustrating/depressing trying to find discontinued parts.
  19. NitroAcres
    Mar 28, 2010
    1,042
    My FCR's are NonMX...not sure it makes much difference..between Non and MX. (I have an FCR41MX new in the box I am saving for a project LC4).
    I like the 39 on the 640ADV as I don't ride it WFO much..riding it here in the SouthEast it works great,
    the 41 on the SXC works perfectly for single track and WFO..a few times I have run it HARD WFO being a total Squidiot..conversely it worked great plodding along singletrack in Colorado..
    As far as fuel mileage two of our riding friends have LC4's with BST40's and fueling is about the same or sometimes better with the FCR (much to their disbelief, some of it is riding style, and I have AutoClutches).
    Throttle response is snappy..but then again, I have never had a "Proper BST", and never wanted one, and no stock exhaust either.
    Antti likes this.
  20. luk.mxtr
    luk.mxtr Adventurer
    Sep 2, 2019
    26
    UK
    Thanks for responds guys !
