    Dismiss Notice
KTM 690 Adventure EVO2 Kit
Discussion in 'Thumpers' started by Frontwheel21, Oct 7, 2012.
  1. Scott_PDX
    Scott_PDX Leisure Engineer
    Oct 18, 2010
    6,976
    Portland...the newer one on the left side.
    Not a problem for me, but I added the CJ Designs filler cap, removed the emissions and vent to the atmosphere with no check ball.
  2. muddyrabbit
    muddyrabbit Lost Boy
    Aug 3, 2007
    4,012
    Fugawee Land.
    Drill the check valve.
  3. werner747
    werner747 Adventurer
    Mar 4, 2009
    35
    I had issues of my front tanks overflowing in extreme heat, or after very rough technical sections. Drilled out the ball valve, and no further issues....
  4. TheRobG
    TheRobG Been here awhile
    Feb 25, 2009
    128
    Lafayette, Indiana
    Drilled mine out as well. Just start with a drill bit slightly larger than the hole and work your way up until the ball rolls out. The ball is pretty hard material so if you drill in until the drill stops, you have hit it and can stop and check.
    I also went a little overboard and vented all my tanks through a couple of oiled-foam breather filters. Adds some complexity to the whole thing but as much trouble as people have had with dirt in the tanks, I figured it can't hurt. Using clear ventlines also lets me check on how the things are breathing and watch for water/fuel in the lines after a wet tip-over. I still have slop check valves right after the caps as well.
  5. muddyrabbit
    Aug 3, 2007
    4,012
    Fugawee Land.
    I just finished doing the Evo 2 Twin Headlight Upgrade to Mala B's KTM 690. The quality on this is top notch, and a step (or two) up from the old style twin headlight it replaces. I didn't take any pics as it was rather straight forward, but I am very happy we made the swap. We originally ordered it as we could not get all the bulbs working in the old one due to a broken wire with some sort of resistor on it..., or something? We had originally gotten the complete Evo 2 kit used, and Spaceman Spiff had obviously put a few miles on it. The headlight assembly always seemed like the one component that did not hold up as well as the rest of the kit. The new style seems like it will be MUCH more durable in the long run!
  6. BucketHead
    BucketHead Man-Camel
    Jun 5, 2007
    291
    1 Finger On The Brake
    Hi all-
    I was quite disappointed with the halogen lighting that comes in the Evo 2. Unfortunately, RR wasn't very helpful in providing options and I didn't find much on the web, so I have worked out a solution that works well.
    The low beam stock bulb is an H1 halogen (55w, 1450 lumen). The H1 LED from Cyclops is a direct replacement, boosts up to 2800 lumen and draws only 20w. Current price $65
    http://www.cyclopsadventuresports.com/H1-LED-Headlight-Bulb-2800-lumen_p_133.html
    The high beam on mine was an H3 (55w, 1450 lumen, and not an H5 as shown on RR's website). I slightly bored out the hole in the lens that the bulb slides through, filed down the mounts and removed the low beam deflectors on the Cyclops H4 LED (3800 lumen, 40w) and it fits perfectly. Current price $65.
    http://www.cyclopsadventuresports.com/3800-Lumen-H4-LED-Headlight-bulb-_p_83.html
    I also adapted the wiring harness so that the low beam is now on with the high beam when the high beam is selected.
    Stock low beam: 1450 lumen, 55w
    New low beam: 2800 lumen, 20w
    Stock high beam: 1450 lumen, 55w
    New high beam: 6600 lumen, 60w
    Total cost $130/1 hour
    If anybody wants more details, shoot me a PM.
    And a footnote: Bobby and Daryl at Cyclops were really great - was a pleasure dealing with them, and I would definitely recommend Cyclops for both their service and the quality of their products.
    Cheers,
    Matthew
    640 Armageddon and WillDieSoon like this.
  7. veetwo _tls
    veetwo _tls RENOVATIO:
    Nov 14, 2005
    2,728
    THE MALLEE OUT BUSH IN Sth Oz
  8. muddyrabbit
    Aug 3, 2007
    4,012
    Fugawee Land.
    We made some small mods to the fairing on the wife's 690 today, quite pleased with the result. These side extensions were pennytech, made from a garbage can and 3m double sided tape. Air flow improvement for the wife was surprisingly good. More details are HERE.
  9. cometeus
    cometeus Adventurer
    Aug 28, 2015
    65
    moon
    Hey guys and galls! ^^
    A little information update:
    After riding with my self solution ( as a/m: welding the punctured RR Evo 2 tank) about 4000 miles i have to say that the selfmade welding is still solid. I also ordered after the crash the ugly crashbars from RR which are fine protecting the edges of the tanks. They already had taken a few seriouse hits which proved theyr stability.They bent a bit but still protect the tanks.
    So, if anyone damage his tanks, try to weld them as i did (if the damage is not a total one). It seems lasting!
    Thanks again to the advriders which brought in the idea!:clap
  10. cometeus
    cometeus Adventurer
    Aug 28, 2015
    65
    moon
    A few weeks ago i had a "slide out" with my black beauty with installed RR Evo 2 tanks and RR engine protector:
    But as you can see the Rally Raid engine protector holds up well. In this case, without a protector, the expensive RR Tank would be destroyed. So i recomend everybody who had installed an RR Tank on the 690ty, to invest the money in thos Protectors.
    For more infos about the crash, the damage and the repair (with russian methodes^^) have a look at the link in my signatur.
    mrpincher likes this.
  11. Ed999
    Ed999 n00b
    Oct 5, 2008
    9
    Big D
  12. mrpincher
    mrpincher Life is one long day Supporter
    Oct 9, 2010
    706
    Far northwest Texas
    They work.:thumbup:thumbup:thumbup My crash bars look identical and I'm damn glad to have em.
  13. leighd
    leighd Been here awhile
    Jul 1, 2015
    113
    Florida/Australia
    Hey guys, does anyone have any detailed photos of their wiring routing around the dash area? i seem to have a bit of a mess and want to tidy it up.
    In particular i would like to see how the main cable runs to the speedo computer. I wasn't really happy with mine.
  14. veetwo _tls
    Nov 14, 2005
    2,728
    High Beam
    Low Beam
    Ignition on (no low or high beam on)
    Spyrious and josip01 like this.
  15. Spyrious
    Spyrious Want to go offroad
    Oct 9, 2016
    273
    Greece
    I didn't know where to post this.But i'm looking for a used 690 enduro r,and so i'm considering the rally kit too.Has anyone had experience with Alberto Dottori's Kit?Thanks
  16. leighd
    Jul 1, 2015
    113
    Florida/Australia
    Anyone had experience with 2" Rox risers with the EVO2 fairing? does it work with the cables or are they too short?
  17. Kikemon
    Kikemon Buffoon Emeritus Supporter
    Mar 6, 2009
    966
    Portland, Oregon USA
    Looks like RR doesn't have tanks for the 690 listed on their web site anymore.
  18. JMo (& piglet)
    JMo (& piglet) Unicorn breeder
    Apr 1, 2007
    9,008
    California
    They are currently out of stock as the current production run is all allocated to outstanding orders.
    Jx
    640 Armageddon likes this.
  19. CalGSer
    CalGSer Traveling dude
    Mar 5, 2007
    106
    Left Coast
  20. veetwo _tls
    Nov 14, 2005
    2,728
    There is always the KIT690/701
    josip01, luloadventure and Spyrious like this.
