KTM 690 Enduro replacement tank bolts – complete subframe reinforcement kit
Discussion in 'Vendors' started by Perun, Feb 15, 2014.
  1. Spartan
    Spartan It's All Attitude
    Nov 14, 2007
    234
    Loomis, CA
    Received parts in only 14 days. All parts easily replaced without any issues.
    Thanks for the great product and quick shipping!
    #41
  2. Perun
    Perun Been here awhile Super Supporter
    Mar 3, 2011
    727
    Belgrade, Serbia
    New batch ready!
    I also started small web shop - www.perunmoto.com. Really small, just one item for now. :) Different payment options available - PayPal and credit cards.
    #42
  3. itnanti
    itnanti aka "cautious cotta"
    Nov 29, 2012
    1,014
    Pismo Beach
    Got everything in install was pretty straight forward. I have a 2014 690 and I can't seem to get the air box to seat. None of the screws are lining up. The rubber boot doesn't look even all the way around. Anybody have any tricks for a noob 690er
    #43
  4. itnanti
    Nov 29, 2012
    1,014
    Pismo Beach
    Not sure if the oem tank bushings are supposed to have ridges. They are almost octagon shaped around.This is after 2000 miles on my 14 690. Glad I didn't wait any longer to change these out. Perun's tank bolt kit was very nice quality and easy to install.
    #44
  5. Perun
    Mar 3, 2011
    727
    Belgrade, Serbia
    Hi, glad installation went ok. :)
    Just apply some grease on rubber boot edges and align it well. It should slide in. Don't use unnecessary force.
    #45
  6. 12Bong13
    12Bong13 Been here awhile
    Jan 7, 2010
    235
    Rouyn-Noranda, Qc
    Hi Perun,
    Why do you suggest using the M6 washer?
    This makes the bolt head protrude the bolt hole. It is not flush or below the side plastics.
    #46
  7. Perun
    Mar 3, 2011
    727
    Belgrade, Serbia
    I made head of bolt cap as low profile as it can be, so plastic fairing is not sticking out. Because of that, bolt cap is 29 mm high. There is a hole all the way through bolt cap - two threads, one M8 - 20 mm deep and one M6 - 9 mm deep.
    Upper bolts that I provide (zinc coated 10.9 M8x25) are entering into the bolt cap as much as they can - around 15 mm, so that leaves 14 mm for M6 bolt (the one used from outside) to come in bolt cap. OEM bolt is M6x16.
    I recommend using that washer just to ensure there is enough clearance between M8 and M6 bolt (inside the bolt cap) once they are bolted all the way in. It may not be necessary, but its "safer" to use it.
    I hope I managed to explain it. If not, I will draw it. :)
    #47
  8. 12Bong13
    Jan 7, 2010
    235
    Rouyn-Noranda, Qc
    OK got it.
    On my 2010, the spacing is ok. I manage not to use the supplied washer and the bolt head is snug like OEM for the plastics.
    Christian
    #48
  9. Eureka690
    Eureka690 Urban Adventurer
    Apr 21, 2014
    69
    San Diego
    I thought your answer was good....except: what are you worried would happen? Plastics could be loose?
    Other than that I don't really see a bad reason for the outer bolt (M6x16mm) to touch the inner bolt (M8x25mm).
    #49
  10. Perun
    Mar 3, 2011
    727
    Belgrade, Serbia
    Yup, just that, nothing more...
    #50
  11. Perun
    Mar 3, 2011
    727
    Belgrade, Serbia
    I made some improvements to this kit.
    I used to make threaded rod for lower mounting spot. I chose to make threaded rod instead of just buying bolts because:
    1. its hard to find M8x140 (for 2008-2013) or M8x160 (for 2014) bolts in 10.9 or better quality on the market. Ofc, 8.8 bolts would do too, but I like additional strength of 10.9 bolts.
    2. even if I found ones, those bolts are too long, IMO, so they would stick out more then I like. Not that it could do any damage, I just didnt like that.
    I recently had some business with bolt factory, so I asked them to make custom bolts, according to my specs. Here are results:
    [​IMG]Untitled by MaletaBG, on Flickr
    Length of the bolts is 137 and 156 mm, quality is 10.9 and they are zinc coated.
    From now on I will provide these bolts instead of threaded rods I used to make. Strength is same, but this is more "elegant" solution.
    #51
  12. Perun
    Mar 3, 2011
    727
    Belgrade, Serbia
    #52
  13. northsoutheastwest
    northsoutheastwest Alaskaless....for now.
    Oct 10, 2007
    447
    in my shoes
    Is the price the same with these new bolts?
    #53
  14. Perun
    Mar 3, 2011
    727
    Belgrade, Serbia
    Yes, +/- 1$, depending on the exchange rate. You can check it on www.perunmoto.com.
    Currently out of stock, but will be available after the weekend.
    #54
  15. Perun
    Mar 3, 2011
    727
    Belgrade, Serbia
    New batch is available, check www.perunmoto.com if interested!
    And upper bolts are also available as separate item now.
    #55
  16. Perun
    Mar 3, 2011
    727
    Belgrade, Serbia
    I will be away from home from October 10th till October 17th, so I am able to ship items before and after that dates.
    #56
  17. Perun
    Mar 3, 2011
    727
    Belgrade, Serbia
    New batch is ready!
    #57
  18. Perun
    Mar 3, 2011
    727
    Belgrade, Serbia
    Perun moto is essentially one-man-shop. So, when that one man goes to the mountains to ski, shop will be closed. Since its internet shop and I made reasonably sized stock, it wont be literally closed, but I wont be able to ship items from December 27th to January 13th.
    I will be checking e-mails regularly, so if you have any questions - feel free to ask!
    #58
  19. In2TheWild
    In2TheWild Adventurer
    Apr 22, 2015
    18
    Coquitlam, BC, Canada
    I know you mention on your website that you do make this for the 2015 model, I am curious how necessary this is. You make great product no doubt and I will be ordering the luggage rack. I find it odd that KTM would not resolve this known weakness over this many years.
    #59
  20. sieg
    sieg Wearing out tires......2 at a time, day after day. Supporter
    Jul 9, 2008
    7,279
    Southern Illinois USA
    yes
    #60
