KTM 690 enduro/SMC exhaust thread
Discussion in 'Thumpers' started by greengoose, Jul 20, 2008.
  1. dogday
    dogday Adventurer
    May 11, 2014
    21
    New Zealand
    I see what you mean, looking at the OEM part list I see there has been a change to just one mount hole/bolt for the 14' can. If KTM think is is good enough to have just one bolt then you should try to use one of the two holes in the older can to mount it. It may not be a perfect match on the sleeve over the header pipe and you might need to pack any gaps where the can mounts to the frame with washers or bushes , preferably rubber, as the mounting method on all years including yours have rubber isolation bushes. Best to just have a play around and see what works with what you have. If the existing hole position is just too far out to be practical, I would look at drilling new holes on the can mount tabs that will line up better. If needed you can extend the tabs a bit by welding a extra pieces in where you need the new holes. It is stainless but can be mig welded using mild steel if you have a mate with a mig welder.
    Let us know how it goes, great blog by the way, really enjoyed reading what you have done.
  2. webbiker
    webbiker Been here awhile
    Jul 11, 2010
    302
    Finland
    Sure and thanks.
    690enduror.blogspot.fi
  3. MAXVERT
    MAXVERT O.G. on da O.C.
    Jan 19, 2004
    2,800
    Baja Arizona
    I just picked up a '14 Enduro.
    I don't seem to be able to find a source in the U.S. for the Wings
    exhaust slip on.
    Can anyone help ?
    Let the farkeling begin :D
    GO!!!!!!! Max
  4. desmocourtney
    desmocourtney No falls, no balls.
    Jul 12, 2009
    145
  5. MAXVERT
    Jan 19, 2004
    2,800
    Baja Arizona
    Thanks, I'm still waiting for a reply form Wings.
    Max
  6. MAXVERT
    Jan 19, 2004
    2,800
    Baja Arizona
    Got the Wings and installed it .
    Fast shipping and great price.
    Top quality.
    Forget about the pos FMF crap.
    Sounds great with the large baffle.
    Wings says there is no need to reprogram
    with the large baffle installed, unless you are
    installing a freer flowing air filter.
    I'll have a twin air and the RR rally style filters,
    so I'll get the dealer to install the Akro map and see
    how it runs.
    GO!!!!!!! Max
  7. webbiker
    Jul 11, 2010
    302
    Finland
    Comparison between a decatted pipe and an unmodified one. Details under the sig if you are interested.
    <IFRAME height=480 src="//www.youtube.com/embed/yBbSzjiGAh4" frameBorder=0 width=640 allowfullscreen=""></IFRAME>
  8. DirtJack
    DirtJack Adventurer Supporter
    Aug 12, 2007
    3,328
    395 miles South East of Orla, Texas
    Wonder what all the smoke is after de-cat?
  9. lightfighter
    lightfighter where does this go?
    Dec 23, 2007
    2,308
    Sierra Vista AZ.
    Nice demo. Very similar to my experience with the same process. Mine sounded a little more "tinny" though, and I put the Leo Vince back on.
    I may cut it open again and try something else.
    That looks like cold weather exhuast vapor to me?
  10. webbiker
    Jul 11, 2010
    302
    Finland
    Most likely. I don't see what else it could really be. The modified exhaust shouldn't have any sort of residue that would produce smoke. Unless the welder greased it up from the inside or something...
  11. panhndl
    panhndl Been here awhile
    May 16, 2014
    114
    Akrapovic sells a titanium exhaust header that could shed more weight off the stock set up on the 690. Anyone know if this would fit with the Wings or how much weight it would cut?
  12. dogday
    dogday Adventurer
    May 11, 2014
    21
    New Zealand
    I have had the header off mine while I modded the muffler (see posts a couple of pages back) The stock header is already very very light, any weight saving will be small but expensive. The stock muffler is a different story of course.
  13. Albie
    Albie Kool Aid poisoner
    Mar 31, 2004
    16,260
    NWA
    The stock header is titanium, so yeah, you won't see hardly any weight savings going to the Akra.
  14. bstavrev
    bstavrev Supermoto User
    Jan 26, 2015
    5
    Europe
    Hello guys,
    Thanks for the great thread and knowledge base. I have a 2015 SMC R (enduro r's cousin). I have also (like many of you did) mounted the Wings exhaust and have some information to share for those who are interested:
    There is a small link pipe that should be also added to the Wings weight (it weighs no more than 150-200 gr.)
    So the Stock exhaust is 2,5 kg. heavier than the Wings (which is a 0,5 kg. difference from what is stated on the Wings site)
    And here is how it sounds:
    https://www.youtube.com/watch?v=O-GSdJeNDFA
    I am still in the breaking in period, so I will run it with the large dB killer. I plan on buying the bigger (Evo1) air filter box and remapping with Evo 1 map for 2014 bike after I break in the engine.
    johnd.211 likes this.
  15. MeinMotorrad
    MeinMotorrad Long timer
    Sep 21, 2012
    6,727
    UK for now.
    Could you repost those pics in a smaller size please, maybe 1000px wide.
    TBH none of this is really unknown info on here.
  16. bstavrev
    Jan 26, 2015
    5
    Europe
    Sorry, the last 10 pages or so I saw approximates on how much does either can weigh and how much it saves but no exact figures. With the pictures above I am giving exact numbers + sound test. If you don't find this information useful have the administrators delete my post or just skip it.
    Cheers,
  17. MeinMotorrad
    Sep 21, 2012
    6,727
    UK for now.
    I'd just be happy if you could resize your pics.
    There is no bigger air box available unless there are new options available for 2015 bikes? You could mod the oem snorkel or get the evo1 air box lid in combination with the re-map. There is more info on the snorkel mod on the 690 tuneecu thread.
  18. bstavrev
    Jan 26, 2015
    5
    Europe
    Thanks for the correction, that's what I meant, the Evo 1 air box lid.
    I decided to share this information in order to clarify the real weight savings because I saw posts in this thread like the one below, several pages back:
    "New exhaust in on the 2014. Wings.
    Sounds good, looks good, 10 lbs lighter.
    Fits great."
    The Wings exhaust isn't 10 lbs lighter...so Mr. MeinMotorrad "TBH none of this is really unknown info on here.", maybe there are some people here that don't know the facts. Next time, before picking on someone, you should scroll through the thread.
  19. MeinMotorrad
    Sep 21, 2012
    6,727
    UK for now.
  20. bstavrev
    Jan 26, 2015
    5
    Europe
    Please stop with the stupid/pointless posts. You can see the real numbers: the actual save is not -3 kg. vs. the stock muffler but -2.5 kg. (Wings exhaust with link pipe weighs 2 kg. vs. 4.5 kg. for the stocker do the math). I read through the thread and saw that some users (not as advanced as you are) had wrong information, so I decided to share. I don't see where is the problem.
    P.S. Are you the local troll? As i PM'd you if you have any problem with my post report to admin but please stop trolling.
