KTM 690 enduro/SMC exhaust thread
Discussion in 'Thumpers' started by greengoose, Jul 20, 2008.
  1. tatif1971
    tatif1971 n00b
    Feb 9, 2015
    1
  2. lightfighter
    lightfighter where does this go?
    Dec 23, 2007
    2,304
    Sierra Vista AZ.
    i really doubt it. I cut mine open to get a straight shot at the cat... and it was still a job. going in from the back, you would be attacking it around a corner.
  3. webbiker
    webbiker Been here awhile
    Jul 11, 2010
    268
    Finland
    I suppose one could do it with proper tools. You can see the floor in the "cat removed" picture where the cat is removed. The problem is that while you could probably/maybe pound out the cat from the rear you might end up with a lot of cat bits rattling inside the exhaust. Although... if the bits are small enough you might be able to vacuum them out.
  4. elasio
    elasio Adventurer
    Jul 26, 2014
    86
    Brooklyn,NY
    Stalling problems with a 2014 and an FMF Q4. Need help.
    Hi, I just got myself a 2014 690 R and installed an FMF Q4 exhaust and removed the emission canister. Since then I have had stalling problems every time I pull the clutch and drop the RPM.
    Has anyone here experienced this and is there a fix for it?
    Elasio
  5. fluff34567
    fluff34567 Long timer
    Jul 13, 2010
    1,196
    choco land AKA switzerland
    Have you installed a different map?
  6. elasio
    elasio Adventurer
    Jul 26, 2014
    86
    Brooklyn,NY
    No, I haven't. Do I need to install a specific one for the FMF? And where Can I do this?
    Eilon
  7. fluff34567
    Jul 13, 2010
    1,196
    Dealer or find someone local with tuneecu
  8. MeinMotorrad
    MeinMotorrad Long timer
    Sep 21, 2012
    6,708
    UK for now.
    Twin spark 690s don't talk to TuneECU. You have to go to a dealer for a tune. Try an EVO1 air box lid or drill some holes in your snorkel to let the engine breathe better and get your dealer to install the EVO1 map. That should hopefully cure the stalling.
  9. fluff34567
    Jul 13, 2010
    1,196
    Yep skimmed over the 2014 bit. Dealer and evo1 map will sort it out.
  10. MeinMotorrad
    Sep 21, 2012
    6,708
    UK for now.
  11. VxZeroKnots
    VxZeroKnots Long timer
    Jun 5, 2008
    4,621
    Way late to the party but the letter of the law is to pass the probe test. There is a usfs pdf out there whichexplains it if you search google.
  12. krussell
    krussell Gravel Warrior Supporter
    Nov 19, 2009
    4,451
    Portland, Oregon
    http://www.fs.fed.us/t-d/programs/fire/spark_arrester_guides/_assets/2012_OHV.pdf
    By the letter of the law I read it as the opposite. Probing means nothing, actual approval/qualification is everything. The guide does provide wiggle room though... "Follow your agency's policies when an unqualified spark arrester system is encountered."
    However, everything I've ever heard about actual encounters leads me to believe that surviving a probe is effective.
    FWIW, I got a wings exhaust with a sparky, though not USFS approved. I'm considering that good.
    My favorite national forests say 'must meet the standard' in their forest orders, referencing 36 CRF 261, which says the same.
    With a stamp and unmodified, you're compliant. Without a stamp, one might assume that it's up to them to prove you are not compliant, or one might assume you have to prove it.
  13. VxZeroKnots
    Jun 5, 2008
    4,621
    damn, looks like you are right and I miss-read that.
  14. dogday
    dogday Adventurer
    May 11, 2014
    21
    New Zealand
    Cuombajj, Here's some pics I thought might be of interest to yourself and others, following on from posts here…...
    http://advrider.com/index.php?threads/ktm-690-enduro-smc-exhaust-thread.364511/page-51
    Here's the internal sleeve with plumbing and cat inside, it has a thin layer of exhaust packing between it and the outer can which makes it a tight fit. I'm sure this has been the cause of more than a few skin burns and swearing, better of without this in the can…
    Another of the can where it comes apart and rivets together for repacking. I used a 30mm section cut from here then slid inside the main can and welded in place, the end cap slips over this perfectly and rivets hold it securely. The can ends up 30mm shorter but thats no problem. I have done many km with this setup and it has worked well
  15. Dino-
    Dino- n00b
    Feb 4, 2016
    3
    Palazzolo Acreide (SR)
  16. Dino-
    Dino- n00b
    Feb 4, 2016
    3
    yuk likes this.
  17. cosmickites
    cosmickites Been here awhile
    Mar 9, 2008
    153
    On the Atlantic Ocean
    hello, long term review, how is this exhaust? did you ever need to remap or bike runs fine? thanks
  18. dannydogg
    dannydogg n00b
    Apr 29, 2016
    2
    Oppland
  19. MotoPundit
    MotoPundit MacGyver
    Jul 23, 2009
    3,212
    Ottawa, Canada
    That Leo Vince muffler is LOUD !
    Sent from my iPad using Tapatalk
  20. dannydogg
    dannydogg n00b
    Apr 29, 2016
    2
    Oppland
    I know! :imaposer. Cool bike u have!
