KTM 690 Fuel tank
Discussion in 'Thumpers' started by dandini, Sep 25, 2008.
  1. JustBob
    JustBob Uh...who me? Supporter
    Dec 30, 2004
    1,078
    Young Harris, GA
    $364 ready to roll? Put me down for one.
  2. DirtJack
    DirtJack Adventurer Supporter
    Aug 12, 2007
    3,326
    395 miles South East of Orla, Texas
    Bike will have to be re-mapped because of air filter flow differences. Perhaps one of the EVO maps will work. How is the intake noise with this air filter?
  3. jm65
    jm65 Been here awhile
    Jan 30, 2011
    307
    Alpes-France
    hi Rade
    Very nice works
    in your futur project , why not reflect to realease the same tank :wink::wink:
  4. rade
    rade Adventure enthusiast
    Dec 29, 2008
    215
    Prague
    This is very nice piece! Who produce it???
    No this is no my way, because:
    - in my case the change is very simple and even "non-technical" people will be able to change it
    - you dont have to change anything else on the bike - like eg. the seat in this case
    - the form/mould would be extremelly expencive and thus the tank too
    My final model says 6,5 liters capacity - so in reality it will be 6 liters :-)
  5. schotterfahrer
    schotterfahrer Adventurer
    Jan 24, 2014
    21
    AT
    Hi rade,
    your tank looks great. how much fuel can it store?
    With your system, is it possible to use the stock filter setup (airbox).
  6. LukasM
    LukasM Long timer
    Nov 15, 2006
    5,513
    On a RTW ride - currently touring the U.S.
    One line above you it says 6 liters, and obviously this tank is replacing the stock airbox....
  7. jm65
    Jan 30, 2011
    307
    Alpes-France
    Ktm = 690 Baja
  8. schotterfahrer
    Jan 24, 2014
    21
    AT
    Sorry wanted to ask in my last post jm65
    @jm65
    With your system, is it possible to use the stock filter setup (airbox). The picture shows a different filter setup.
  9. LukasM
    LukasM Long timer
    Nov 15, 2006
    5,513
    That is not JM's bike, it is a KTM 690 Baja, 1 of 4 in the world. The tank holds 19 liters, and it only works with the Rally air filter as pictured, and with a carburetor.
    However, you can't buy it anywhere so I would look at your other options, like Rade's new tank, or the Rally Raid tanks, or the OEM KTM 450/690 Rally tanks.
  10. jm65
    Jan 30, 2011
    307
    Alpes-France
  11. Dotbond
    Dotbond Africa, Africa
    Jun 18, 2006
    896
    Dunedin. New Zealand
    Can you actually use all the 14ltrs in the Safari tank, or is there some fuel that is left in the tank for any reason? i.e. fuel taps too high?
  12. MeinMotorrad
    MeinMotorrad Long timer
    Sep 21, 2012
    6,520
    UK for now.
    Having fuel taps a cm or so above the lowest point of the tank lets any crap thats got in the tank settle in the bottom and helps stop it getting to the pump etc.
  13. StepOnIt
    StepOnIt Assitoner
    Jan 19, 2010
    1,085
    Huntsville ON.
    I never ran down both tanks so not sure, but the taps are low enough and there is a cross over between both lower parts of the tank. So they drain evenly or you can drain one side if you feel like it, not sure why though. Just have to make sure when filling both front and rear tanks to turn off the tap for the front tank, it will over flow the rear. Then after 100km (60miles) you can open the front tank to drain into the rear, or drain the rear first then open the front you call. Great tank easy to install and adds a lot of extra fuel. One person i know when doing trips with gear only fill the front because it is a pain to get to the rear tank.
  14. ramjet
    ramjet Long timer
    Jul 8, 2004
    3,024
    Super F'd Up N. California
    rade,
    I thought of doing a similar airbox but one that would have the center incorporate the airbox that would allow fitting the uni twin pod filter and so allow the tank to extend further back. Did you give any thought to this type of design?
  15. Dotbond
    Jun 18, 2006
    896
    Good points guys, thanks for the replies.
  16. EdGear
    EdGear Edventurer
    Oct 31, 2008
    674
    Bay Area, CA
    +1 on this idea, the K&N filters are a deal killer for me
  17. OneEffinName
    OneEffinName Been here awhile
    Nov 2, 2010
    512
    VanIsle, BC
    I am not a fan of the K&N as well, but with a foam pre-filter it will work fine for me. I'd even make one from the bulk uni-filter material from motorcycle superstore.
  18. FinnDuro
    FinnDuro Winter wonderlanding
    Aug 15, 2007
    460
    Finland
    Any progress in this tank project..?
  19. MiGSel
    MiGSel GaStronaut
    Jan 29, 2003
    399
    Belgium
    Very nice, keep up the good work!
  20. DrtSqtr
    DrtSqtr Been here awhile
    Apr 11, 2008
    230
    Ponchatoula,LA
