KTM 690 Fuel tank
Discussion in 'Thumpers' started by dandini, Sep 25, 2008.
  1. KC-10ENG
    KC-10ENG Been here awhile
    Aug 19, 2010
    258
    Las Vegas, NV
    Will some with the Rade tank with the foam filter measure the metal tube that came in the kit? I am swapping out the K&N and using a UNI Filter.
    Thanks in advance!!
  2. renogeorge
    renogeorge Let's ride!!
    Apr 7, 2007
    6,467
    Reno
    I'll measure mine. I don't use the metal piece. I have the longer UNI. Need the number for it?
  3. sprouty115
    sprouty115 Long timer Supporter
    May 29, 2012
    7,923
    Providence, RI
    Do you have some dyno runs and AF charts that show that? Because based on what I've experienced and read, after big changes to the intake and exhaust a re-map is recommended. The KTM EVO kits, Akrapovic, Wings, Rottweiler, etc. all suggest remap.
  4. renogeorge
    Apr 7, 2007
    6,467
    Reno
    The Rade metal piece is 62 mm long. I didn't use it. I use the UNI which is longer than the one Rade was providing with his kit for use with the metal sleeve. The number I have "UP-6245AST 2 Stage Pod (angled) 2.5" ID X 6" HGT". I am happy with it. Intake sensor is zip tied to frame next to air filter.
    FWIW
  5. christian
    christian Long timer
    Jul 9, 2004
    2,990
    Redwood City, CA
    Thanks Rade for the support for the sonorarally.com
    Currently training in Parhump NV
  6. imaging
    imaging Adventurer
    Nov 6, 2016
    12
    Slovenia
    I just got Rear tank from rallyraid. I already have Touratech rack mounted and I ordered adapter for it as well. Does anybody have the same setup and can send me some pictures with everything mounted? Just want to install it right but I can't find any pictures on internet.
  7. jacbrown
    jacbrown As old as my tongue, a little older than my teeth
    Jul 24, 2004
    81
    Michigan
    I am in the process of installing the Rade tank. That made me curious about the fuel reserve light on the cluster. For those of you who have already used an auxiliary tank, does the reserve fuel light in the cluster come on at an appropriate time or has it become useless?
    If useless, can you reset the mode back to "trip 1" for example? As you may have guessed, I haven't ridden the bike enough to hit reserve. It's still pretty new to me.
  8. renogeorge
    Apr 7, 2007
    6,467
    Reno
    The fuel light is triggered by level in the main tank. The sender is below the level of the Rade. So with Rade petcock open you will hit reserve 1.5 gallons later than you would without the Rade. I leave Rade petcock normally closed using it as a reserve. That way I get the normal reserve light, open Rade petcock transferring 1.5 gallons to main tank, turning reserve light off.
  9. jacbrown
    Jul 24, 2004
    81
    Michigan
    Thanks George. That's great news. My other bikes are so old that it's all mechanical. This fancy electronic stuff is new to me.
  10. Brown Dog
    Brown Dog North Georgia Dual Sportr
    Nov 16, 2008
    2,346
    Calhoun, GA. USA
    I got a 2008 with stock tank 10k miles.
    It's running terrible & going dead just like its running out of fuel.
    Fuel Pump & Filter is OEM Stock.
    You guys think my filter is stopped up
    Inside tank ?
    Can I get filter out with tank on the bike ?
  11. renogeorge
    Apr 7, 2007
    6,467
    Reno
    Yep. It's easiest if you remove lower tank and swing tank up. But it can be done in place. NAPA for filter. Think about replacing pump and adding inlet Profill filter. Avoid kinking fuel lines when installing. Have you checked for a small trumpet filter at the injector? Problem could be there or at the injector too. I'd still replace in tank filter. FWIW
  12. Brown Dog
    Nov 16, 2008
    2,346
    Calhoun, GA. USA
    I removed fuel tank from bike to access the pump & filter.
    I found the pump housing had came unsnapped & apart.
    This kinked hose was the problem :
    Pickup filter & inline filter were not stopped up :clap
    I removed kinked hose & found tiny spring loaded check valve at pump connection, which I destroyed getting the hose off pump
    Is the check valve needed ?? :ear
  13. hansi
    hansi Teurer Abenteurer Supporter
    Jan 1, 2010
    1,234
    State of Jefferson
    At how many gallon remaining does the low fuel light come on with just the stock tank?
  14. The Letter J
    The Letter J Long timer
    Aug 17, 2010
    1,794
    Santa Maria, CA
    About .6 gallons remaining.
    hansi likes this.
  15. sprouty115
    May 29, 2012
    7,923
    Providence, RI
    I'm going with "yes". I assume it is there to prevent fuel from back-draining from the the line that runs to the pressure regulator.
    640 Armageddon likes this.
  16. imaging
    imaging Adventurer
    Nov 6, 2016
    12
    Slovenia
    I wanted to replace the fuel filter in tank but i couldn't pull out the fuel pump. I tried to pull pretty hard but it looks like the fuel filter or hoses are hooked somewhere. Any ideas how to get it out without damage?
  17. sprouty115
    May 29, 2012
    7,923
    Providence, RI
    First, don't pull hard on anything. Second, try twisting the fuel pump assembly about 90/180 degrees as it starts to pull away from the tank. If I recall correctly, I turned it clockwise and wiggled the hoses and everything came out.
    Third, don't pull hard on anything...
    jacbrown likes this.
  18. MizzouRider
    MizzouRider Long timer
    Jan 22, 2007
    2,911
    Fly over zone
    I had the exact same thing on my 09. I tried epoxy. It seemed fine until I put some weight on the racks, then it was running out all over the place. I finally bought a used tank. Now I've got so much invested in just getting the original tank replaced, I'll just go with a rotopax if I want to carry additional fuel.
    hidsrtktm likes this.
  19. Brown Dog
    Nov 16, 2008
    2,346
    Calhoun, GA. USA
    Gates # 27086 IS submersible fuel hose = 1/4" ID x 12" long.
    Nobody has it though :-(
  20. El Lobo
    El Lobo Been here awhile
    Dec 5, 2015
    161
    West Coast Finland
    Any pictures of the check valve?
