KTM 690 Troubleshooting Guide
Discussion in 'Thumpers' started by El Ponkin, Dec 6, 2014.
  1. El Ponkin
    El Ponkin Bloodrunner
    Oct 21, 2006
    3,157
    Brisbane
    Updates to the following:
    Fault table B and C - additional info about the throttle body sensor drive key modification from plastic to metal.
    Fault Table G - Additional info on rockers and latest mods.
    Fault Table H - Additional info about the Rectifier/Regulator following a wiring issue I experienced recently.
    #41
  2. andrewmagas
    andrewmagas n00b
    Nov 20, 2016
    7
    hi i still got no spark and discovering folowing
    if i have spark if i run the tuneecu coil test- does it say that the part from efi to spark plug is ok?
    what should be pulse generator resistance - i read 220
    which reading should i get to check if my side stand is ok as it has 3 vires
    i also have strange thing with starter as i can not run it in the gear with clutch pressed but clutch switch is fine
    gear pos sensor is fine as well showing neutral when neutral
    btw it's US model
    so it has some extra sensor on fuel
    and the bike is standing for a year
    with this issues
    #42
  3. MotoPundit
    MotoPundit MacGyver
    Jul 23, 2009
    3,184
    Ottawa, Canada
    #43
    sprouty115 likes this.
  4. El Ponkin
    Oct 21, 2006
    3,157
    Brisbane
    Additional Fault table N added on Page 1 after recent issues with an inmates 690 which had an Low Oil Pressure light illuminating at idle .
    #44
    MeinMotorrad likes this.
  5. El Ponkin
    Oct 21, 2006
    3,157
    Brisbane
    #45
    a2zworks likes this.
