KTM 790 Adv accessories, Modifications and Upgrades
Discussion in 'Parallel World (790/890)' started by Migolito, Feb 5, 2019.
  1. braaap!
    braaap! Long timer Supporter
    Mar 16, 2005
    4,642
    Here and There
    I'll see what the elves can do :)
  2. Thumper Dumper
    Thumper Dumper Been here awhile
    Apr 13, 2016
    334
    Durban South Africa
    Yes it does sit a bit high but it needs to in order to clear the rear tail piece, they do offer brackets that bring it closer.
    I like Braaap's idea but when tightening the spacers to the tail piece it will be difficult to align the angles to the plate.
    Even though it is a bit high I have only bashed my knee once and now the pain helps me to remember to lift my leg a bit higher. :y0!
    TrailTrauma likes this.
  3. Mike in Roswell
    Mike in Roswell Adventurer
    Apr 17, 2019
    50
    Roswell, GA
    Looks great. Did you run the power directly to the battery or is there a switched connector somewhere?
  4. windblown101
    windblown101 Long timer Supporter
    May 17, 2010
    6,068
    Star Tannery, VA
    Thanks. There are two sets of 10amp accy connectors inside the headlight housing that I used. One is constant on, the other is switched. I prefer constant on for the GPS so used that to power the Garmin and I used the switched power for the grips.
    Allucaneat likes this.
  5. Mike in Roswell
    Apr 17, 2019
    50
    Roswell, GA
    Thanks for the quick reply. So you have to be careful to remove your Garman when your bike will be not in use for periods of time so that you don’t run down the battery right? No big deal as I do that with my 690
  6. windblown101
    May 17, 2010
    6,068
    Star Tannery, VA
    I turn it off with two button presses, one to turn it off, one to shut down the internal battery charging at the end of the day. However if I won't be riding it for several days I pop it out of the cradle just to make certain I don't get a drain on the bikes battery.
    Mike in Roswell likes this.
  7. AdvRonski
    AdvRonski They call me......Ronski
    Feb 4, 2007
    1,383
    Finally made it to Fruita!
    Well, I received my Guglatech fuel pump condom, but the installation didn't go as easily as I'd hoped. It has 3 layers of differing filter material, but the fit of the pump body is so close, that the additional thickness around the pump prevented it from fitting back into bottom of the tank. It just kept bunching up sliding down the pump body. After several tries, I ended up taking a die grinder to the opening, and tried to take a minimum of material off. I'm pretty sure I got all of the debris out of the tank, but I guess that's what the filter is for. One of the problems with the material bunching up at the bottom, is that's where the small hole that feeds the fuel into the pump suction area is. I'm pretty sure there is an inlet at the top of the pump, but when you're down to the last few ounces of fuel, it has to go through the little hole at the bottom of the pump. I will say, that the fuel tank material is pretty tough, as it took some pretty aggressive grinding to remove enough material. IMG_20190619_132530.jpg IMG_20190619_133458.jpg
  8. davorallyfan
    davorallyfan Commonist
    May 2, 2005
    18,437
    Capitalist
  9. Yzlvr
    Yzlvr Been here awhile
    Jul 7, 2008
    933
    Thousand Oaks
    Anyone do some windscreen mods on the R yet?? Post pics please..
    06Z likes this.
  10. Nowwhat
    Nowwhat I'll Go Second... Super Supporter
    Mar 2, 2007
    8,592
    On the Ground Laughing
  11. Yzlvr
    Jul 7, 2008
    933
    Thousand Oaks
    typeamark and Oceandiving954 like this.
  12. Nowwhat
    Mar 2, 2007
    8,592
    give me 4 weeks hahahaha.....Fairing will be here Tuesday....
    Migolito and 06Z like this.
  13. 06Z
    06Z Been here awhile
    Nov 24, 2008
    726
    Temecula, California
    Ok we will give you 4 weeks, BUT we will need lots of pics and a detailed review. Some Specs too!
  14. Migolito
    Migolito Prognosticator and MotoYogi
    Nov 6, 2011
    2,534
    S-Cal
    Not sure if this was posted yet.
  15. MotoMinded
    MotoMinded Rally On Super Supporter
    Feb 19, 2006
    5,427
    COS
    No pics... our Rally Moto Kit (with the 2019 RFR screen) will be on sale this fall. Hope to be able to launch at the KTM ADV Rally in Breck.
  16. Nowwhat
    Mar 2, 2007
    8,592
    Holy shit that is horrible
  17. Migolito
    Nov 6, 2011
    2,534
    S-Cal
    I dunno. Proper tool for the Job. I had something similar (SW Motech) on my CB500X. I didn't dirt mod it as that was not what I intended to do with it. So, many of the disadveantages of a setup for dirt, were not there. For the street, dirt roads, long distance travel, they worked out great. I was able to attach highway pegs, running lites, etc and they offered great pro. As sacriligeous as it may sound, my 790R (some day when it arrives) will be street modded to do long distance slab, dirt, gravel, etc. I've got a 500EXC already for ST.
  18. Migolito
    Nov 6, 2011
    2,534
    S-Cal
    KTM NA and I are on a first name basis. This roll out flies in the face of the incredible job KTM has done in bringing this bike to completion, the marketing and the 'traveling show'. Like I whined before (and it may very well not be true for others) I have a written contract that sets for a May delivery. So, yes, I'll be extracting some orange blood.
    typeamark likes this.
  19. dzrtracin
    dzrtracin возьми
    Sep 28, 2004
    4,103
    the garage
    PLEASE give the DETAILS of the ORANGE EXTRACT, i'm guessing go pound sand!
    You must have a lawyer on retainer correct?
  20. macaw1us
    macaw1us Been here awhile
    Jun 11, 2013
    137
    Very very nice, I've hurt myself a bunch on one of those when I first learned to really ride. ;)
    A 77 was my 1st bike.
    Should make riding a 790R a piece of cake and feel like a 350 to me.
    Thanks for the picture :)
    Thumper Dumper likes this.
