KTM 790 Adv accessories, Modifications and Upgrades
Discussion in 'Parallel World (790/890)' started by Migolito, Feb 5, 2019.
  1. ramirin
    ramirin Ready to push
    Mar 25, 2008
    1,159
    FIN
    Thanks for the advice.
    Is that Hella headlight your product or Rebel X? I'm not interested in big rally towers but rather something smaller than original, super enduro like setup..
  2. Nowwhat
    Nowwhat I'll Go Second... Super Supporter
    Mar 2, 2007
    9,039
    On the Ground Laughing
    Well my warranty was void the second I picked up the bike...soooo....
    Seriously though....if you have a good relationship with your dealer....it is just headlights....
    kzeb likes this.
  3. alongat
    alongat Fesh Fesh
    Jan 20, 2010
    4,968
    Windsor, United Kingdom
    For the 790, rebelX sells the rally kit. We sell the 950 super enduro version
    ramirin likes this.
  4. marchyman
    marchyman barely informed Supporter
    Jun 30, 2005
    13,697
    SF Bay Area
    Finally... dealer called and says the heated grips I ordered are in. I'll pick them up tomorrow and hopefully install them Saturday so I'll have warm hands on the early Sunday morning ride.
    Fabricator and Velociraptor like this.
  5. spartanman
    spartanman regret minimizer
    Oct 17, 2009
    2,531
    Land of High Hopes & Low Taxes
    A bit of a job to access the accessory wiring in the headlight mount but well worth it. They work excellent!
    Rudderfeet, Venturer and marchyman like this.
  6. ibgary
    ibgary Long timer
    Oct 18, 2013
    1,847
    Colorado
    I put the heated grips on this afternoon. Not very hard. At some time over the winter I think I'll pull the headlight off and take it apart inside. I think there is room inside to open up some space in the bottom. The bottom hatch fits so tight I afraid it will break. Anyone opened the light ass up yet?
    Knolff likes this.
  7. spartanman
    Oct 17, 2009
    2,531
    I have, when I installed the heated grips. Yes, it’s tightly packed with wiring. Getting the center support released from the light housing tabs is a little tricky. I used a putty knife to pry in the plastic on one side, then inserted a piece of rubber sheet to hold it while prying the other side. Not a bad job, just takes time.
    Rudderfeet likes this.
  8. ibgary
    ibgary Long timer
    Oct 18, 2013
    1,847
    Colorado
    Cool. Thanks for the tip. Was there room inside to move things around, or is it just jammed full of wires?
  9. spartanman
    Oct 17, 2009
    2,531
    There’s room, but all of the wires and connectors- except those for the headlight -are strapped to a support that attaches to the steering neck. You’re looking at it when you remove the bottom cover. I didn’t try to relocate anything except the ACC1 and ACC2 connectors so they could be accessed through the cover. Not sure if there’s enough slack to move anything else.
  10. Thumper Dumper
    Thumper Dumper Been here awhile
    Apr 13, 2016
    381
    Durban South Africa
    You can get at ACC1 & 2 without opening up the headlight. You just need to loosen off the entire assembly and move it forward to gain access.
    If you do a search for removing the headlight to install cruise control I'm sure you will find it. As for the little hatch under the headlight, I found it best if you remove the centre of those stupid clips/tabs before pulling the entire clip/tab out. They go back in the reverse order.
    Rudderfeet and Migolito like this.
  11. mickd
    mickd crash test dummie
    Apr 10, 2007
    2,502
    sunshine coast,australia
    So whats the difference between acc1 acc2. Sorry to ask but i would like to wire up my gps
  12. alongat
    alongat Fesh Fesh
    Jan 20, 2010
    4,968
    One is a constant powered circuit and the other is ignition switched.
  13. mickd
    Apr 10, 2007
    2,502
    Cc1 being power all the time ?
  14. alongat
    alongat Fesh Fesh
    Jan 20, 2010
    4,968
    I forget but...I do recall acc1 being the constant.
  15. mickd
    Apr 10, 2007
    2,502
    Thank you
    alongat likes this.
  16. kaertner
    kaertner Long timer
    May 30, 2017
    1,492
    Europe, land of Culture & Food
    easy to test, switch bike off and test both connectors for any power.
  17. ibgary
    ibgary Long timer
    Oct 18, 2013
    1,847
    Colorado
    I connected my phone holder/charger to Acc 1, because the holder has a switch and usb port. Convenient for charging intercom or phone while eating lunch. Handgrips are on #2.
    alongat likes this.
  18. Nowwhat
    Mar 2, 2007
    9,039
    My 790 is being used to prototype Rottweiler's air intake solution...dont know a timeline for production but progress is being made...
    Should make up for the skid plate weight gain hahaha
  19. kzeb
    kzeb Been here quite some time
    Oct 22, 2006
    267
    Scandinavia
    This is an available option from Rade/Garage LSK XH1 Led's, 900g for the set and EU approval for low, high beam and position lamp.
    ramirin, TrailTrauma and ibgary like this.
  20. ramirin
    Mar 25, 2008
    1,159
    FIN
    @Nowwhat I'm not afraid of warranty being void just passed over what ktm responded through my dealer when I ask for type of connector in headlamp :lol3 Motokeidas in Finland has been absolutely awesome with any issues I've had with roughly a dozen of Ktms during past decade.
    @kzeb Already in talks with Rade. Making these work with can bus could be a pain though (if needs to be different from 1090 setup) - or so I heard. I suppose one would need to know power consumption of the original and have resistor to compensate if using less watts to fool ecu not to throw error? Manual just says 'LED' for each light, no further info there..
    Nowwhat likes this.
