    Dismiss Notice
KTM 790 Adv accessories, Modifications and Upgrades
Discussion in 'Parallel World (790/890)' started by Migolito, Feb 5, 2019.
  1. Nowwhat
    Nowwhat I'll Go Second... Super Supporter
    Mar 2, 2007
    9,131
    On the Ground Laughing
    What's the perceived advantage to a center stand on a bike this light that warrants all the trouble to get it to even come close to working?
    SEK_Nick, BobcatSig and Subaruvich like this.
  2. TrailTrauma
    TrailTrauma Nemophilist
    Jan 17, 2012
    5,964
    Ontario .. Superior
    Rhetorical:
    (of a question) asked in order to produce an effect or to make a statement rather than to elicit information. :)
    Nowwhat and kzeb like this.
  3. 1coolbanana
    1coolbanana Long timer
    Aug 25, 2009
    6,688
    NW Sydney, Australia
    :lol3
    Nowwhat likes this.
  4. JohnRansom
    JohnRansom Been here awhile
    Apr 22, 2014
    145
    No. UT
  5. ibgary
    ibgary Long timer
    Oct 18, 2013
    1,858
    Colorado
  6. slink
    slink Been here awhile
    Feb 19, 2015
    253
    Estes Park, CO
    Caribou Cases (https://cariboucases.com/ktm-790r/, https://cariboucases.com/ktm-790-adventure/) has various lockable options for side and top cases using Pelican or Storm cases, including DIY options for Harbor Freight or other cases. Also, the Altrider and Perun rear racks are pre-drilled for the hole pattern for mounting.
  7. ramirin
    ramirin Ready to push
    Mar 25, 2008
    1,163
    FIN
    I guess it comes along the idea to have separate (big and heavy) crashbars..
    kzeb, Brilloman and Nowwhat like this.
  8. JCARTER
    JCARTER Chillin
    Nov 23, 2016
    132
    Out West--Utaaaah!
    TrailTrauma-
    I am not quite getting the plastic skid plate! Besides weight why would it be better then Aluminum? I am looking at the SW-Motech skid plate. Why would AXP be better?
    I understand this from the MFR info:
    AXP Racing's Poly Skid Plate for the KTM 790 Adventure features a tough, thick 8mm poly plate that's designed to protect your Engine, Fuel Tanks & your Rear Shock Linkage. AXP's design utilizes aluminum mounting brackets which mount to existing skid plate mounts and frame points, unlike other skid plates that utilize engine mounting points. HDPE is a great material for skid plates because it's lightweight, durable, flexes on impact and slides over obstacles. Unlike Aluminum plates which are heavy, bend and more times than not cause annoying vibration noise caused by metal on metal contact at the mount.
    Features:
    Thick 8mm HDPE Material is incredibly tough and protective
    Design protects Engine and Lower Fuel Tank
    Much lighter than Aluminum Plates
    Slides off obstacles
    Resilient HDPE material flexes instead of denting and distorting
    Includes Debris Shield
    All necessary mounting hardware included
    What I am worried about is fatigue cracks of plastic over time around the bolts.
    And will a hard rock hit cause a split in the plastic... or crack it... Has this type of protection been proven and tested over time somewhere I don't know about?
    Please Advise.
    Thanks,
    JC
    Migolito likes this.
  9. Migolito
    Migolito Prognosticator and MotoYogi
    Nov 6, 2011
    2,719
    S-Cal
    Me too
  10. Rudderfeet
    Rudderfeet Long timer
    Feb 25, 2014
    1,035
    Central Ohio, USA
    Thick plastic plates have been in use on enduro bikes for many years and hold up quite well as long as the attachment points are secure. They're preferred by a lot of riders encountering lots of logs during hare scrambles and technical enduro races because their slippery surfaces let you slide over more readily. They also resist mud caking better than metal. That said, enduro bikes have more narrow frame gaps than the 790 and often riders mount a plastic protector over a modest aluminum guard for more force distribution. I haven't decided which direction I'll go on mine yet, but I don't plan to bash it against things as often as my Beta either.
  11. windblown101
    windblown101 Long timer Supporter
    May 17, 2010
    6,720
    Star Tannery, VA
    Composite skid plates have long been used on dirt bikes. They are lighter, quieter, resist getting deformed, and arguably slide over stuff a bit easier. They do tend to gouge up a bit over time when ridden in rocks.
    As for long term durability they seem to hold up well. However, on heavy bikes I suspect they might deflect enough to cause damage to mounts over time. Moreso than aluminum? I couldn't say with certainty. I went with an Enduro Engineering Aluminum because I feel it will likely hold up as long as a composite plate and costs half as much. I view skidplates as a eventually disposable, if you abuse them enough you may have to replace them.
    JCARTER likes this.
  12. Migolito
    Nov 6, 2011
    2,719
    S-Cal
    Here ya go. Please excuse the mess, I threw the camera back in just for perspective. It's solid as hell and does not vibrate. Easy to remove and I have a charger inside. All told, about $19.00.
    EDIT: Dear Motominded, and other fabricators. Just a thought; make a universal slide rail that would allow this type of 'plastic box' to slide on and off the rear tail bracket and lock simply from the inside with a simple push/pull pin. Or, take a look at the Mosko Moto 'puck' system for thier luggage. Two plates that mate and a pin. It's universal and bomb proof. There ya go, send the first one to me and I'll review.
    Perun and kzeb like this.
  13. Migolito
    Nov 6, 2011
    2,719
    S-Cal
    The whole 'skidplate' thing is a wee bit overwhelwing. My bike will never do terrain where I need to slide over rocks, logs and small children. I have a 500exc that does that to the best of my feable ability. Right now, I have a SW Mo crash bar set up that is working out extremely well for the street. It holds my lights, allows foot placement on those long slabs, and does offer excellent lay down pro (however, I do not like the engine attachements). It's also top quality! However, it's use precludes the bootom pro ive seen so far.
    Having said that, the bike will be doing dirt starting this year...lotsa dirt. BDR dirt, death valley dirt, mountain dirt...but, hopefully no single track dirt. SOOOO, ya, I'd like bottom pro for those things that fly up to meet my soft underbelly, and some lay over pro, and some pro for the crap thats tossed up from the front wheel. When WE started this mod's for our new bike, there wasnt anything available. Now, some of the best and the brightest have stepped up...big time. So, in the next couple of months I'll be prepping the bike (still need to name her) for the dirt...ADV dirt, not racing dirt. It will start with Rallz tires, and Cycra handguards. I also just recieved the Unifilter from AUS. the only major Mod that is up in the air for me is the bottom pro. It appears that none of the bottom pro will allow the SW Mo crash bars, so, along with the Bottom Pro, Ill be looking at new light brackets.
    michaeldorian and JCARTER like this.
  14. JCARTER
    JCARTER Chillin
    Nov 23, 2016
    132
    Out West--Utaaaah!
    Thanks gents for your replies! Helps a lot! Its 70 dollars cheaper for the Poly... SW-Motech is $389.00....so I will give AXP a shot. I do ride on straight aways that have large pool ball size rocks that beat my 1090 skid plate pretty well at a fast pace. So was worried about the poly. I ride through those areas a lot to get to my destination.
    I will be buying my 790 soon...
    Thanks again,
    JC
  15. marchyman
    marchyman barely informed Supporter
    Jun 30, 2005
    13,961
    SF Bay Area
  16. jtriver
    jtriver Adventurer
    Jul 22, 2009
    10
    Nicola Valley, BC
    it provides a nice level platform for a pancake griddle...
    Nowwhat likes this.
  17. HeliCycle
    HeliCycle Adventurer Supporter
    Jan 14, 2018
    14
    Minneapolis
    Got my MotoPumps GPS mount installed today. Great instructions and hardware. I did find that the socket head screws used to mate my Garmin Zumo 595 GPS cradle to the MotoPumps mount were too long for my gear. A quick trip to McMaster-Carr.com had the right length screws in hand.
    Photos below show the supplied socket head screws sticking out too far (preventing full tilt of the cradle), the replacement screws compared to supplied screws, and a couple of angles of the mount, plus the view from the pilot's seat (sitting and standing).
    All in, I think this well work great for my needs. And, the kit and instructions are top notch. I don't hold the screw length against the kit. There are a lot of variations out there, and it would be impossible to supply hardware for every contingency. I do, however, really appreciate Rob's instructions including the specs of all the hardware. Knowing that the included screws were M4x0.7x25 saved me having to dig out my pitch gauges and potentially getting the wrong size. I just measured how much stick-out I had originally, then found the right size at McMaster's. Easy-peasy.
    Also, Rob is super-helpful. I emailed him several times with questions and he always got back to me really quickly. IMG_20200125_124854.jpg IMG_20200125_125008.jpg IMG_20200125_125222.jpg IMG_20200125_132210.jpg IMG_20200125_132622.jpg IMG_20200125_132643.jpg
    TrailTrauma, krussell, CaseyB and 2 others like this.
  18. JohnRansom
    Apr 22, 2014
    145
    No. UT
    Thanks for sharing. You have it mounted further back than I expected. However, I think If I got a similar case, I could make a backrest for the wife, which is the main goal of a hard top case in the first place.
  19. Migolito
    Nov 6, 2011
    2,719
    S-Cal
    When I go Adv riding I mount my Mosko Moto side bags AND a 40L duffle on top. The duffle fits between the little case and me, thereby creating a really nice back rest. I'm really hoping someone creates a 'slider' type mount for small/medium pelican type case like this. IF they used a rail system the box could me easily slide forward or backward to fit specific needs.
    I definately could see mounting a larger 'pelican' type box and adding a back rest...super easy.
    Maybe this: https://www.uscargocontrol.com/shop/Enclosed-Trailer-Accessories/Airline-Straps-Hardware
    and this:https://www.uscargocontrol.com/L-Track-Double-Lug-Threaded-Stud-Fitting
  20. svneko
    svneko What?
    Dec 12, 2011
    179
    . Like the BRE slider system?
