KTM 790 Adv accessories, Modifications and Upgrades
Discussion in 'Parallel World (790/890)' started by Migolito, Feb 5, 2019.
  1. marchyman
    marchyman barely informed Supporter
    Jun 30, 2005
    13,133
    SF Bay Area
    When I was looking at the KTM My Ride app for phone the reviews turned me off. Lots of reports of connection errors and intermittent operation. I decided I can do without it.
  2. 1coolbanana
    1coolbanana Long timer
    Aug 25, 2009
    6,587
    NW Sydney, Australia
    I heard the same, I just wanted to have a play with it and found it disabled.
    Ill probably end up frustrated with it and not use it anyway but want to have a fiddle since Ive got so much time on my hands at the moment?
  3. sluagh
    sluagh not fade away
    Dec 7, 2019
    244
    USA
    And besides that, mine wants to pair with my phone every time I turn the key on. I uninstalled the app from my phone but can't figure out a way to stop the bike from wanting to pair with it.
  4. Orfeas
    Orfeas Been here awhile
    Sep 7, 2014
    230
    You can navigate to KTM My Ride pairing menu in the TFT and then you will see an option to delete pairing!
    sluagh and 1coolbanana like this.
  5. sluagh
    Dec 7, 2019
    244
    USA
    Thanks. I must have overlooked that.
  6. Thumper Dumper
    Thumper Dumper Been here awhile
    Apr 13, 2016
    335
    Durban South Africa
    You can simply turn off Bluetooth in the bikes menu. I leave mine on because I let it connect to my phone and helmet com set. That way I can control my music through the handlebar switch. I don’t have my comms set and phone paired.
    I don’t use the navigation often but have found that if you turn the bike on and let it connect to your phone first and then turn on the comms set it works fine.
  7. sluagh
    Dec 7, 2019
    244
    USA
    TT, I think you've suggested the Booster Plug before for the problem I have so I'm hoping you are knowledgeable about the Booster Plug. My 790 surges/stumbles when just coasting with a low load on the engine when it's running from 3.5k to 5k rpm, like it's starved for fuel. It only does it when the ambient temp is >65f and the engine is completely warmed up. It idles fine and accelerates smoothly always. I looked at the Booster Plug website and if I understand the explanation correctly it doesn't seem like it will help this situation for a closed loop fueling system (which I assume the 790 has). According to the explanation, in a closed loop system the ECU uses the lambda sensor feedback to change the A/F ratio back to the target value if it senses a variation so the booster only works in a transient condition, like accelerating. So, if you're operating at a fixed throttle position and steady rpm, the booster will try to fool the ECU into increasing the A/F ratio but it will respond to the lambda feedback and drive the A/F back to a lean condition.
    I suppose that the first step probably should be to take it to the dealer but the only one around here I had any confidence in (See See KTM) closed up "for remodeling" and didn't reopen when they said they would March 1 and now with the virus thing who knows if they will ever reopen. So, I'm hoping for a modestly priced solution to at least try before I let somebody of questionable competence try to fix it.
    I'm wondering if you have any thoughts on the Booster Plug as possible fix, given the discussion above.
    thanks.
  8. EvilSteve
    EvilSteve Not so evil, not so Steve.
    Jun 30, 2008
    546
    SoCal
  9. windblown101
    windblown101 Long timer Supporter
    May 17, 2010
    6,102
    Star Tannery, VA
    I'm warming up to the idea of using this plate as a prefilter. It's dead easy to get to the main filter on this bike but the intakes are in a bad spot for sucking in airborne dirt and a prefilter as Rottwieller has done it looks to be less hassle than squeezing prefilters into the intake tubes and likely breathes a bit better as well. Not ready to make the jump yet but certainly intrigued.
    BobcatSig and nibby like this.
  10. nibby
    nibby Been here awhile
    Feb 22, 2009
    478
    U.K. - Liverpool
    Same here. I'm liking the idea, should keep things a bit cleaner and added bonus of a bit more storage under the seat.
  11. windblown101
    May 17, 2010
    6,102
    Star Tannery, VA
    Yes and no on the underseat storage. You gain some behind the seat latch brace but loose the deeper space in front of it since that will have to be left open to avoid blocking or damaging the prefilter. In my case I'm not sure the alarm pictured on the stock intake lid will fit in the space behind the seat latch.
    nibby likes this.
  12. Beeners
    Beeners Adventurer
    Apr 14, 2014
    66
    Placitas, NM
  13. blackSP
    blackSP Love the Pussy Wagon
    Feb 4, 2008
    1,011
    Amsterdam
    Look what finally arrived, after 3 months of waiting! Plus a super nice Vanasche front sprocket protector. Stuff to do tomorrow ;}
    BobcatSig, EvilSteve and Beeners like this.
  14. matrix17
    matrix17 n00b
    Dec 14, 2019
    3
    Okanagan, BC
    hey.....after looking through 250+ pages here, i have been given an amazing amount of insight on my bike - thanks! i am still, however, trying to figure out what skid plate Bamboo Baby (pg 205) has on his bike. Can anyone comment?[​IMG]
  15. EvilSteve
    Jun 30, 2008
    546
    SoCal
    I already ordered one. I'm buying it because I want to protect my motor not because I want to gain under seat storage. ¯\_(ツ)_/¯
  16. BobcatSig
    BobcatSig They call me... Huckajawea
    Aug 15, 2014
    3,268
    Protestlandia, OR
    I hate to break it to you but See See KTM is no more, at least as we know it. Despite their notice of 'remodeling' was really a guise for their sale. Word is that they've sold to Beaverton Honda Yamaha, and they are looking for a new location. A bummer because the idiots at Beaverton can go pound sand. When I bought my Beta, it was easily the worst bike purchase experience.
    Your option for service is Gresham KTM, Motorsport Hillsboro or Power Motorsports down in Sublimit.
  17. Thumper Dumper
    Apr 13, 2016
    335
    Durban South Africa
    Its a
    TrTec Rugged 790 Adventure Bashplate
  18. JP4
    JP4 Thumper Geek
    Mar 22, 2003
    339
    Hood River, OR
    I was impressed by Nathan at Gresham. He seemed very knowledgeable and did good work. Even cleaned my bike!
    krussell and BobcatSig like this.
  19. Lill-Erik
    Lill-Erik Adventurer
    Jul 22, 2019
    50
    Sweden
    Ok so this is my final version of the improved rear mudguard.
    I still use the mudguard from the old lc4 models part nr 54606010000.
    But instead of making a bracket to mount it to where the passenger pegs usualy mounts i used rivet nuts to bolt it straight to the airbox. The rivnuts are still outside of the filter so noting should get in from there, i will still put some sealant on it just to make shure.
    I have this idea that someone with good contact with Rottweiler Performance could have them integrate this mounting solution into the airbox they are developing, would be realy sweet.
    leaf001, 990s, ramirin and 6 others like this.
  20. Rudderfeet
    Rudderfeet Long timer
    Feb 25, 2014
    1,013
    Central Ohio, USA
    Very cool mod, just keep an eye out for wear marks on the swingarm. I have a Beta 350RR and the mudguard on Beta's 4Ts tend to wear away the coating into the swingarm's metal, so one trick is to lash a large zip tie around the center of the "yoke" to move the wear spot to the smooth zip tie surface.
    ramirin and EvilSteve like this.
