KTM 790 Adv accessories, Modifications and Upgrades
Discussion in 'Parallel World (790/890)' started by Migolito, Feb 5, 2019.
  1. Mud Bucket
    Mud Bucket 60% of the time I'm right every time
    Aug 9, 2007
    274
    North Vancouver,B.C, Can
    Totally agree.
    Offroad it sounds great, I like ride without earplugs and its like the sound of music in the bush. Highway is another thing. Ear plugs is good, and what ever can help the idiots know your there is good too in my opinion.
  2. marchyman
    marchyman barely informed Supporter
    Jun 30, 2005
    14,122
    SF Bay Area
    You need 1/4" (6.3mm) spade (also called blade) connectors available at any auto supply place. You need the male connectors. This kind.
    Flatroads and fbga like this.
  3. wtrhzrd
    wtrhzrd n00b
    Sep 20, 2020
    1
    Western Washington
    First post but long time reader. Created account to add to this. I just had the exact same issue with the touratech bars. Went down on the right side, slow speed, in about 5 inches of sand. Got home and noticed a dent in my pipe, and i couldn't get the right side tank bolt to line up properly. Just pulled the tank and it looks like my bracket is bent as well. Can't locate the part for sure on parts finder since I'm not sure what it's actually called. Mine isn't damaged, so I might try to bend it back out a little.
    Flatroads likes this.
  4. chippertheripper
    chippertheripper motorcycle junkie Supporter
    May 30, 2009
    11,526
    s.e. mass
    thats anodized ti.
    TrailTrauma likes this.
  5. SoilSampleDave
    SoilSampleDave Dr. Zaius was right!
    Jan 21, 2005
    10,421
    The Delta Ghetto, GA (aka PTC)
    I realize it isn't the ideal place to post it, but does anyone want my stock skid plate? I'm not sure it makes sense to ship it because of the way carriers charge by volume too these days, but I am on the south side of Atlanta if someone wants to pick it up. It's free, so hopefully I won't face the wrath of the mods.
  6. hubilado
    hubilado Motoquiero Super Supporter
    Feb 16, 2004
    822
    New Mexico
    If you don't get any action on that skid plate, there's this. I use that site every once in a while when I've got something I don't need anymore and don't have buyer for it. It reaches a lot of people so maybe a wider audience than this thread.
  7. SoilSampleDave
    Jan 21, 2005
    10,421
    I had forgotten about that; thanks!
  8. MondayDad
    MondayDad Been here awhile
    Jan 22, 2013
    102
    Indiana
    I bought the KTM brand center stand from my dealer ($225), a price that is pretty comparable to aftermarket stands. It went on easily after I downloaded the instructions from:
    www.ktm.com/manuals
    Note that the standard bike manuals (search box "790 Adventure...") are at the top in various languages and the add-on parts "manuals" are available via a separate search box at the bottom of the page after searching for the model. The document id is the same as the part number in the case of the center stand. I found that document id by searching the Powerparts web page.
    I read in here somewhere that an inmate had trouble installing the springs. They may not have had the instructions, as the instructions made it REALLY easy. Just put the springs on the top and bottom carriers (2 rubber-wrapped springs, very taut!), push the center stand up into it's "retracted" position, then install the long bolt with washer through the stand into the lower spring carrier. The threads are barely long enough to reach, but they do. Tighten the bolt into the carrier making sure that the tab on the lower carrier goes into the corresponding groove in the stand. You don't even need a spring puller! I did have to use both a tap and die (M8 x 1.25) to run the threads for the rubber bump stop as the stand had been painted after threads were cut and the paint made installing the bump stop difficult (the rubber spun on the "bolt" as there's no hex to use to turn it with a wrench). The threads on the bump stop itself were also questionable. After cleaning both up, it installed smoothly and was locked by a nylock nut on the top side.
    As for operation, I found it fairly hard to get up on the stand as the lever action is not very long and you have to pull the bike back onto the stand. I am used to lifting the rear of the bike as I deploy the stand (Honda, BMW), but that didn't work well here. I'm betting it would be really hard with packed bags! The rear wheel is not lifted much, definitely not 2", but it's enough to perform chain and rear wheel maintenance. The stand is narrow with nothing sticking out to catch on brush.
  9. mulefan3220
    mulefan3220 Adventurer
    Jun 30, 2017
    64
    Evergreen, CO
    Glad you got it to fit.
    Finally got the fuel tank replaced under warranty last week. Had to go back and forth with KTM a couple times (over a 6 week span) on the photos but they finally took care if it.
    windblown101, BHoward and EvilSteve like this.
  10. Ten Speed
    Ten Speed Adventurer Supporter
    Mar 1, 2008
    36
    Livermore,Ca
    I'm putting Oxford heated grips on my bike, wiring to the headlight connector. Where did you run your wire if you did this too.
    Thank You for any replies.
  11. RJ Str8
    RJ Str8 Adventurer Supporter
    Aug 13, 2018
    41
    Brooklyn, NY
    I installed Koso Apollo heated grips today and wired them to the ACC2 outlet in the headlight. Ran the wires into the trap door under the headlight housing. I removed the front fender (fromR model) and had to fish out the ACC2 connector from a tangle of wires but much easier than removing he headlight assembly. I had to trim the wire on the Apollo quite a bit and put red spades on the ends but pretty simple overall. I then zip tied the cable from the grips to existing cabling from the handlebars to make it all nice and neat.
    SoilSampleDave likes this.
  12. mulefan3220
    Jun 30, 2017
    64
    Evergreen, CO
    Getting to those ACC connectors on my 19 was a pain in the ass. They stuffed 10lbs of crap in a 5lb box inside that headlight assembly. It’s a pinched wire / elec short waiting to happen in there. Would have made way more sense to put those relayed ACC connectors by the battery and just give us a plug a play connector in front of the tank for heated grips. Love / hate relationship with big Orange sometimes.
    JP4 and billiards101 like this.
  13. hubilado
    Feb 16, 2004
    822
    New Mexico
    Those Koso Apollo grips have a fuse in the wiring harness (as I'm sure you know). I found out (not the easy way) that it's a good idea to leave that fuse holder somewhere where it can be accessed without undue stress.
  14. RJ Str8
    Aug 13, 2018
    41
    Brooklyn, NY
    Great point. Fortunately saw that and zip tied the holder to a cable bundle that is readily accessible.
  15. offroadjunky
    offroadjunky Been here awhile
    Oct 7, 2016
    218
    Kelowna,Canada
    I do like the built in temperature control of those grips.
  16. windblown101
    windblown101 Long timer Supporter
    May 17, 2010
    6,906
    Star Tannery, VA
    Had Koso heated grips on my 690 and loved the built in controller design. Sadly I seemed to accidentally bump it often with my thumb.
    Luckily I've never had issues with the discrete controller of the KTM heated grips. Had them on three bikes. In fact I retrofitted the discrete controller onto my 1190 as I absolutely hated having to dive into the multi function contoller/menu system just to turn them on or adjust the heat level. I'm mostly a form follows function type.
  17. offroadjunky
    Oct 7, 2016
    218
    Kelowna,Canada
    I don't find the ktm controller that discrete and I actually liked having the grips control built into my 1190 console.
  18. JP4
    JP4 Thumper Geek
    Mar 22, 2003
    529
    Hood River, OR
    Haha, yes so fun getting into that headlight. As you probably know, there are in fact ACC 1 and ACC 2 connectors on the same circuit under the seat, and it would probably be a lot easier to run wires forward from there. I've had the headlight assembly apart three times now, and while it does get easier, it's still a pain in the ass. To make it all even more cramped in the headlight assembly, in addition to the grip wires, there's the cruise control harness, Garmin transformer for my Zumo, and the relay for my Cyclops Aurora's packed in there.
  19. SEK_Nick
    SEK_Nick Been here awhile
    Nov 4, 2015
    288
    Southeast Kansas
    Be VERY CAREFUL reassembling. The wire bundle going in to the key/immobilizer module on my bike failed (broken wire) and KTM denied the warranty claim, stating that "the wire bundle was not positioned properly after reinstalling the headlight." This ended up costing me $680 to repair, and I'm still trying to get it covered under warranty.
  20. Ten Speed
    Mar 1, 2008
    36
    Livermore,Ca
    I got my heated grips and zumo installed. The headlight was not as bad as I was expecting. I did not shove all the wires in there though. They a zip tied to cables and bracket supports.
