KTM 790 Adv accessories, Modifications and Upgrades
Discussion in 'Parallel World (790/890)' started by Migolito, Feb 5, 2019.
  1. TrailTrauma
    TrailTrauma Nemophilist Supporter
    Jan 17, 2012
    6,555
    Ontario .. Superior
    Man.. heavy metal skid plate, buggy aux lighting, hefty hand guards, large gps, tail rack and a monstrous can? Who's bike is that and what did they do with the real @Nowwhat 's whip?? :photog
    Nowwhat likes this.
  2. rock_bottom
    rock_bottom Been here awhile
    Jan 5, 2016
    114
    Durban South Africa
    The first skill you learn when racing vintage bikes!
    Nowwhat likes this.
  3. Nowwhat
    Nowwhat I'll Go Second... Super Supporter
    Mar 2, 2007
    9,582
    On the Ground Laughing
    Lights got lighter...can got shorter...things like taillights started falling off
  4. SoilSampleDave
    SoilSampleDave Dr. Zaius was right!
    Jan 21, 2005
    11,072
    The Delta Ghetto, GA (aka PTC)
    That's the view from your garage???
    Nowwhat likes this.
  5. slider162
    slider162 Been here awhile
    Feb 12, 2012
    213
    Madison, WI
  6. chippertheripper
    chippertheripper motorcycle junkie Supporter
    May 30, 2009
    12,657
    s.e. mass
    A bunch of people here have had at it with drills and dremels
  7. Tigerkf
    Tigerkf Been here awhile
    Jun 20, 2020
    244
    USA
    I modified my sprocket cover in a similar way and added opposing triangle patterns on the bottom so dirt would have and exit.
  8. slider162
    Feb 12, 2012
    213
    Madison, WI
    Okay, sprocket cover is done.
    So is the Reckless 80 install.
    Fusion 360 designed and 3D printed parts used.
    Strap tie downs bolted to the back of the passenger footpegs (improved design).
    Black:
    Or Orange (Not KTM Orange, but I thought it would be fun anyway.):
    I know these are rackless bags, but I wanted something to support the left side.
    Big chunk of 300mm x150mm carbon fiber to get me some more room.
    EvilSteve, kirill_k, dano619 and 2 others like this.
  9. chippertheripper
    May 30, 2009
    12,657
    s.e. mass
    I was totally under the impression that 3D printed parts were not to be trusted, that they were too brittle or whatever due to their nature.
    Color me surprised.
  10. Dan D.
    Dan D. Long timer
    Mar 13, 2020
    1,300
    Jacksonville, FL
    You should move your reckless kit further back...
    Crazysheep, levain, WB11 and 6 others like this.
  11. slider162
    Feb 12, 2012
    213
    Madison, WI
    For the most part, you are correct. It depends on the material used and how it is printed. The black is PETG and the orange is ABS. I wouldn't trust PLA and I would try nylon if I had some. These are almost solid plastic with 7 perimeters and 30% infill. I am taking a calculated risk by using them as a rackless tie down. I don't think the load will be too great used in this manner. I certainly wouldn't trust them to tie down to a trailer for towing.
  12. SoilSampleDave
    Jan 21, 2005
    11,072
    I remember when carbon fiber was new and people didn’t want to trust it vs a metal part. The engineers said “When you look at how orderly the carbon structures are under a microscope, and then do the same with steel, you’d never trust steel.”
    Crazysheep likes this.
  13. chippertheripper
    May 30, 2009
    12,657
    s.e. mass
    youre really speaking a language I don’t understand. I’ll just go ahead and take your word for it.
    Nowwhat, Dan D. and SoilSampleDave like this.
  14. windblown101
    windblown101 Long timer Supporter
    May 17, 2010
    8,138
    Star Tannery, VA
    My problem with carbon for some uses isn't a lack of strength. It's the rather spectacular way it fails if it fails and the resulting carbon shards. A lot easier to find and pick bits of metal out of ones body compared to carbon.
    kzeb and SoilSampleDave like this.
  15. slider162
    Feb 12, 2012
    213
    Madison, WI
    Ya know, I could probably get another Reckless 80 on there now and have enough room to go around the block.
    Dan D. likes this.
  16. TrailTrauma
    Jan 17, 2012
    6,555
    Ontario .. Superior
    Ha! I was going to say something .. thinking I'd never .. ever .. seen an R80 so far back. Usually on the seat, I thought.
  17. Norduro
    Norduro Thumping
    Nov 30, 2013
    415
    Switzerland
    Why so far back? Thinking of weight distribution your installation looks absolutely terrifying. And I am not surprised that there is not enough lateral support for the bags if you basically mount them behind the rear lights and the license plate. :arg
  18. slider162
    Feb 12, 2012
    213
    Madison, WI
    Not my cross country touring single track setup. This is just the two-up "it is nice out, let's go for a ride" and have somewhere to put the leftovers on the way back home setup with a bonus sissy bar/bag.
    Norduro likes this.
  19. slowkiwi
    slowkiwi Adventurer
    Sep 6, 2020
    76
    new zealand
    yeah, it would make 6th gear wheelies even easier, and allow for up to 2 passengers....
    Dan D. likes this.
  20. slider162
    Feb 12, 2012
    213
    Madison, WI
    I guess when I started out, I didn't see anything different than a pannier setup. Nobody seems to take issue with the hard cases.
    WB11 and comradecasey like this.
