KTM 790 Adv accessories, Modifications and Upgrades
Discussion in 'Parallel World (790/890)' started by Migolito, Feb 5, 2019.
  1. FireDog45
    FireDog45 Knockin' on retirement's door
    Sep 16, 2006
    1,630
    Central, Ohio
    The handles have been reported (and the pictures seem to confirm) to not be a good tie down point due the open design. They also appear to interfere with throw over style bags as well (think Mosko’s Reckless series)
    #81
  2. SEK_Nick
    SEK_Nick Been here awhile
    Nov 4, 2015
    156
    Southeast Kansas
    So I'm looking at Crap Flaps on ebay, and I'm seeing a number of options. It's probably too soon to say what's "Best", I'm looking mostly at the plastic ones instead of metal.
    Who's bought a crap flap - did you pick metal or plastic, and why? Do you like the one you bought? Is fitment good? Links and pics!
    #82
  3. Thumper Dumper
    Thumper Dumper Been here awhile
    Apr 13, 2016
    307
    Durban South Africa
    5A2A8190-ECE4-4C72-9B59-52D24D7BC434.jpeg 1C6406EF-7814-4568-9A7B-3D4CAECDDAB6.jpeg 6C4DBCF3-E2DD-4B9A-A871-570451B36044.jpeg Removed the catalytic converter. Sounds way better. Will test her out tomorrow.
    #83
    pwh, davyjones, The_Eccentric and 7 others like this.
  4. Oceandiving954
    Oceandiving954 Been here awhile Supporter
    Oct 16, 2013
    408
    Florida, USA
    #84
  5. Oceandiving954
    Oct 16, 2013
    408
    Florida, USA
    #85
  6. Thumper Dumper
    Apr 13, 2016
    307
    Durban South Africa
    I don’t have a scale but I would estimate it to be about 2kg. The decat pipe was made by a local exhaust manufacturer called Stealth.
    #86
    Oceandiving954 likes this.
  7. Norduro
    Norduro Thumping
    Nov 30, 2013
    360
    Switzerland
    This is correct, the sub plate is not needed to remove the handles, but it allows the rack to be mounted in a better position relative to the seat (lower, more in line with the seating surface).
    If you use the sub plate you have to remove the handles. Removing the handles obviously has pros and cons. With the handles gone there are indeed no strapping points available to mount something on the passenger seat. A dedicated luggage rack instead of the rear seat would of course easily solve this problem. I am sure options will start to pop up soon.
    #87
  8. AdamM001
    AdamM001 Been here awhile
    Oct 30, 2015
    209
    Texas (by way of Norway and Nova Scotia, Canada)
    Norduro,
    Which sandstorm tank bag is that? 4H?
    #88
  9. Norduro
    Norduro Thumping
    Nov 30, 2013
    360
    Switzerland
    Yes, it is the Enduristan Sandstorm 4H. The 4H fits the 790’s tank shape better than the 3S I also tried, but it is not expandable. Then again, I have never used this feature on previous tank bags, who wants to have an overly tall tank bag?!
    The 4H does not interfere with the handlebar, the controls and does not get in the way when standing up. Works very well for me.
    #89
    tshansen, cwk and AdamM001 like this.
  10. AdamM001
    Oct 30, 2015
    209
    Shoot... was between that and the 4s (figure the 4E is too big).
    Thought the 4s and 4H would be about the same, except for added expandability ...
    #90
  11. Norduro
    Norduro Thumping
    Nov 30, 2013
    360
    Switzerland
    Well, dimension-wise they are both similar and they both fit the 790 Adventure. The 4H just fits the shape of the tank a bit better because of its flexible underside and sidewalls. So, if you do not need the expandability and the rigidity of the 4S I suggest you take the 4H, otherwise the 4S will most likely work for you too, but there will be a bit more empty air below the tank bag where the fuel cap is. This should not be much of a problem since the bag itself is rigid.
    Here are two fitment pics of the 4S from a German KTM board (not my pictures).
    #91
    davyjones likes this.
  12. braaap!
    braaap! Long timer Supporter
    Mar 16, 2005
    4,470
    Here and There
    Another home-made 'CrapFlap' about to be born :) 2.00mm aluminium waterjet cut - powder coat finish.
    G-iT inspired flap sections to be lightly folded inward or outward to provide air flow but shield what's behind, from any crap flung.
    #92
  13. braaap!
    Mar 16, 2005
    4,470
    Here and There
    Looks like the side plastics have been 'trimmed' out for the aft straps to route down back the frame... :dunno
    #93
  14. tzabcan
    tzabcan Serial Wanderer
    Jun 24, 2012
    43
    Berlin
    Has anyone tried a Mosko Moto Hood tank bag on their 790? Care to share some pics?
    #94
    ibgary likes this.
  15. Yzlvr
    Yzlvr Been here awhile
    Jul 7, 2008
    931
    Thousand Oaks
    Any chance on selling some? Looks nice.
    #95
    braaap! likes this.
  16. Yzlvr
    Jul 7, 2008
    931
    Thousand Oaks
    #96
  17. Thumper Dumper
    Apr 13, 2016
    307
    Durban South Africa
    No fueling changes. Seems to go better with the cat removed and the sound is way better.
    #97
    ibgary, tshansen and braaap! like this.
  18. tshansen
    tshansen Been here awhile
    Feb 9, 2015
    520
    Norway
    What about the mapping? Do you do something with the ECU or do you think the lambda sensors will campensate
    #98
  19. Thumper Dumper
    Apr 13, 2016
    307
    Durban South Africa
    I have left everything stock. I want to see what happens before I make any changes or add ECU's etc. I'm not sure if the lambda sensor can compensate, and in all honesty I know too little about them to even try answer that question. So far I think the bike is going better but that could just be the lovely sound coming from the tailpipe :photogbut she does seem to have more power down low.
    When I bought my 690 I bought just about any mod that came recommended and most where a waste of money so this time I'm going to only change what I think is necessary.
    #99
    tshansen likes this.
  20. NextAdventre
    NextAdventre Been here awhile
    Mar 25, 2013
    160
    Western NC
    Anyone add Rox Risers yet? If so, how was the brake line length?
    ibgary likes this.
