KTM 790 Adv accessories, Modifications and Upgrades
Discussion in 'Parallel World (790/890)' started by Migolito, Feb 5, 2019.
  1. ShaftEd
    ShaftEd Long timer
    Nov 6, 2001
    4,002
    San Diego, CA USA
    I installed the switch myself also. Not a lot of fun even using the easier pull the complete headlight assembly off method. Anyway, I also noted that the CC would shutdown over bumps. Realized it was my hand on the throttle. The bump moves my hand and then the cc goes off. I tested by having my hand lightly on the bars and then hitting a bunch of bumps and the cc stayed on fine.
    TrailTrauma likes this.
  2. marchyman
    marchyman barely informed Supporter
    Jun 30, 2005
    13,276
    SF Bay Area
    I've only had my CC turn off once. I wasn't sure if it was the bike or if the bump caused my hand to twist the throttle forward. I hope it was my hand. I can do something about that.
  3. AdvRonski
    AdvRonski They call me......Ronski
    Feb 4, 2007
    1,435
    Finally made it to Fruita!
    Well, in my case it wasn't my hand twisting the throttle in either direction. For one thing, it takes a very deliberate effort to roll the throttle forward to disengage the cruise, and opening the throttle does not turn off the cruise. And, in most cases, my hand wasn't on the throttle at all. I'm thinking they have it set to be a little too sensitive to G-forces created by bumps, I suppose to make sure that a rider doesn't fall asleep and run off the road under power.
    TrailTrauma and mlyamkaw like this.
  4. mlyamkaw
    mlyamkaw Drill Baby Drill
    Jul 17, 2004
    845
    Sandpoint, ID
    I agree. I have had it happen to me several times. Don’t think it was me turning the throttle, one time I thought my hand was off the throttle side, but can’t remember for sure. I thought it might have been the traction control shutting the cruise down. Rear wheel goes in air, spins, shuts off cruise?
    ibgary likes this.
  5. braaap!
    braaap! Long timer Supporter
    Mar 16, 2005
    4,777
    Here and There
    ^ That!
    Have had mine shut off several times on (sharp) bumps in the road... Huh? Thought I was imagining it, so I hit a cattlegrid with CC on (approx' 100kph) bike got some air and CC clicked off.
    Tested several times with same result. On the road if the bump is short and sharp (like a jolt) happens too.
    That fraction of rear wheel speed differential.
    ibgary and TrailTrauma like this.
  6. spartanman
    spartanman regret minimizer
    Oct 17, 2009
    2,440
    Land of High Hopes & Low Taxes
    Let the dealers know it's happening. Sounds like a software update is in order.
  7. chippertheripper
    chippertheripper motorcycle junkie Supporter
    May 30, 2009
    10,866
    s.e. mass
    I think that’s as designed.
    ibgary likes this.
  8. AdvRonski
    Feb 4, 2007
    1,435
    Here's an opportunity for some of you guys from Down Under to help out the rest of us 790 riders. If you live in the Brisbane area, kevxtx is an inmate who has developed an effective O2 sensor controller for the 690's and needs a 790 to develop a solution for us. If you can spare your bike for a bit, get in touch with him and set something up.
    Brilloman and braaap! like this.
  9. spartanman
    Oct 17, 2009
    2,440
    Well, maybe so, but it sounds like it needs tweaking. I’ve ridden bikes with cruise and it doesn’t cut out when you hit a bump.
  10. braaap!
    Mar 16, 2005
    4,777
    Here and There
    Will post up on the local 790 facebook page too. I know a couple of guys up there in QLD.
    Hi @kevxtx :thumbup
    AdvRonski likes this.
  11. mlyamkaw
    Jul 17, 2004
    845
    Sandpoint, ID
    Would like to see him do the ABS wheels for the speed sensor like he did on the 1190s. I contacted him, but he seemed on the fence because the speed differential wasn’t as great as it was on the 1190. I am reading 3-4 MPH off against my GPS on my 790. It was dead nuts on with his ABS wheels on my 1190 after being around 5 MPH off stock.
  12. marchyman
    Jun 30, 2005
    13,276
    SF Bay Area
    That's about what I'm seeing but I was using an app on a phone instead of a real GPS. Phone was telling me about 68 while the speedo was bounding between 71 and 72.
    mlyamkaw likes this.
  13. KTM Freak
    KTM Freak Disgruntle Dirt Biker Supporter
    Sep 5, 2010
    86
    The Salad Bowl-Salinas, CA
    I received my Perun Moto Rack today for my 790R. This was my first time ever ordering anything outside the US. Shipping directly from the manufacturer was only a week to the West Coast.
    The item was packaged very nicely with high quality tape and lots of shrink wrap on the rack. The quality of the rack and hardware is outstanding. They even threw in a bunch of stickers with the order. Definitely no corners cut here with this manufacturer.
    I need to look into other accessories they offer :super
    Perun, Mr D Hertz, voyer and 9 others like this.
  14. braaap!
    Mar 16, 2005
    4,777
    Here and There
    I see a 7km/h discrepancy between speedo and Garmin 276Cx...
  15. GodFatherOfChill
    GodFatherOfChill Adventurer
    May 2, 2014
    51
    NorCal
    Anyone put a tool tube on the rear exposed frame yet? I’m looking for some mounting inspiration.
    I use the Mosko Moto Reckless 80. When it’s on the 790 I feel like it fits better if the rear plastics stay on bc they provide some additional stability. However, I don’t like using the rear side plastics for that purpose. Also, the storage inside the rear plastics isn’t large enough for my needs.
    I want to install 1 or 2 tool tubes like this https://www.amazon.com/dp/B07KP1VXPV/ref=cm_sw_r_cp_api_i_oQMEDbDS9C3RQ. They make a couple different sizes. I was thinking about the “big” tube on the left side (hoping to fit a spare 18” tube in it), and the “small” tube on the exhaust side (to hold a spare 21” tube).
    I measured the exposed frame and it looks like the tool tubes may work with the Reckless 80. IMG_1848.jpg IMG_1849.jpg
    Have any 790 owners installed a tool tube yet? Please send me pics!
  16. mlyamkaw
    Jul 17, 2004
    845
    Sandpoint, ID
    E1ED1F9B-F7C4-469E-84EA-CA94AA1223C7.jpeg B5F0AF7B-007C-44D8-BD1A-8DEA364FBB91.jpeg
    I haven’t installed mine yet, but I have a couple I am gonna put on both sides. I have to mount mine with the caps facing forward and down, since I have pannier racks. One has a recovery system, the other will have tools. I have a Bumot tool box that I will also have tools in on the left side pannier rack.
    GodFatherOfChill likes this.
  17. Nowwhat
    Nowwhat I'll Go Second... Super Supporter
    Mar 2, 2007
    8,751
    On the Ground Laughing
    Fyi a 21 inch tube fits inside the stock rear plastics if you pull out the storage box.
  18. chippertheripper
    May 30, 2009
    10,866
    s.e. mass
    EE skidplate showed up just now.
    This is what the inside looks like, along with the “feet” that attach at the rear to the peg mounts.
    It’s certainly well made, I just am not 100% sure I won’t high center slam this thing on a rock hard enough to crack the motor anyways.
    I’ll certainly have to remain alert and aware of my line choices (as one should with a 400lb+ scoot).
    Fabricator and SoilSampleDave like this.
  19. AdvRonski
    Feb 4, 2007
    1,435
    That is a nice looking piece. How much does it weigh?
  20. chippertheripper
    May 30, 2009
    10,866
    s.e. mass
    6.9lbs for the plate pictured as it is above, without hardware.
