KTM 790 Adv accessories, Modifications and Upgrades
Discussion in 'Parallel World (790/890)' started by Migolito, Feb 5, 2019.
  1. FireDog45
    FireDog45 Squirrels get enraged when they see me naked
    Sep 16, 2006
    1,810
    Central, Ohio
    Serious question: what’s the motivation to removing the cat? Weight, sound, heat, power...? My concern would be making an already lean engine (my assumption based on previous bikes) more lean. I’m not familiar with Rottweiler or Coober but am I correct in assuming that they dyno test their intakes and exhausts to make sure a retune isn’t needed?
    Again, not judging but seriously interested.
    cwk likes this.
  2. SEK_Nick
    SEK_Nick Been here awhile
    Nov 4, 2015
    275
    Southeast Kansas
    I am waiting for some rigorously tested results before making any changes to the fuel/air system, personally.
    davorallyfan and amschnellsten like this.
  3. dtaski
    dtaski Been here awhile
    Sep 17, 2009
    142
    Harrisburg , PA
  4. Nowwhat
    Nowwhat I'll Go Second... Super Supporter
    Mar 2, 2007
    9,051
    On the Ground Laughing
    Power.....weight ......temps....
    The 790 I rode felt like every other KTM that had its balls cut off by regulations....lose the cat and the air box and the stock lean tune....add a dyno tune, a proper exhaust and a 15t front sprocket ....voila
  5. SoilSampleDave
    SoilSampleDave Dr. Zaius was right!
    Jan 21, 2005
    10,316
    The Delta Ghetto, GA (aka PTC)
    I do not think this bike is like older ktms where the cat was an afterthought and a big performance burden. We’ll see what Rottweiler finds. I’m betting that a tuner/ignition is going to unlock it even with the cat.
  6. Nowwhat
    Mar 2, 2007
    9,051
    All Cats are burdens......Rottweiler has already deleted the cat on their 790 duke....
  7. SoilSampleDave
    Jan 21, 2005
    10,316
    Yes, but if the cam timing is such that you are counting on that back pressure, weird things can happen. I haven’t been following their Duke build, but like I said before, I will take their results as the final word once they work on their 790 Adv.
    cwk, LocuL and Nowwhat like this.
  8. Nowwhat
    Mar 2, 2007
    9,051
    You are only counting on that back pressure for low rpm efficiency...that's where the dyno tune comes in....can't fix the valve overlap.....that's one reason why this bike won't make 150hp hahahaha.....looks like Arrow has added and expansion chamber to their mid pipe and they have made more efficient headers to keep the exhaust velocity in line.....all in all there is 15 percent more power sitting there to be released....
  9. SEK_Nick
    Nov 4, 2015
    275
    Southeast Kansas
    Everybody is different. For me personally there's already so much power, I feel like I really don't need any more.
    Venturer and FireDog45 like this.
  10. MotoMinded
    MotoMinded Rally On Super Supporter
    Feb 19, 2006
    5,456
    COS
    Installed the Motoz Tractionator Rally set today. Can not see how this is not an upgrade to the OEM shoes. Well, for what we'll be riding.
    Now for the :spam
    We also installed the BRP Rubber Mounted Submount, Scotts adjustable damper, Double Take ADV Mirrors, Our Stout Mount and Perfect Squeze phone mount by Hondo Garage.
    If you look close at the 1st picture, you can see our prototype ABS Cable Guide.
  11. FireDog45
    Sep 16, 2006
    1,810
    Central, Ohio
    Pretty much my feelings too. I would actually give up some HP at the top to pick up some tourque at the bottom. I installed new cam sprockets on my GS that moved the peak torque down about 600 RPM at the expense of top end power. Made a huge difference pulling out of corners.
    That will most likely be the biggest adjustment moving to the 790: getting used to the different torque delivery.
  12. Nowwhat
    Mar 2, 2007
    9,051
    Scott's has a kit for this bike already?
  13. JohnnyWaffles
    JohnnyWaffles Been here awhile
    Jul 16, 2012
    849
    San Jose, CA
    econwatch likes this.
  14. Tool.Nerd
    Tool.Nerd An idiot that owns a bike
    Jan 10, 2016
    588
    Southeast TN
    Emailed Givi. They said check back next month, but multiple products are in the works. Exciting.
  15. braaap!
    braaap! Long timer Supporter
    Mar 16, 2005
    4,935
    Melbourne - AU
    Home made works in progress...
    Rear rack plate.
    braaap!CrapFlap :)
    Waiting on some Kreiga hardware to come in next week for the rear plate ;)
  16. Yzlvr
    Yzlvr Been here awhile
    Jul 7, 2008
    935
    Thousand Oaks
    Nice..
  17. 06Z
    06Z Been here awhile
    Nov 24, 2008
    734
    Temecula, California
  18. Yzlvr
    Jul 7, 2008
    935
    Thousand Oaks
    Nice Truck..
    06Z likes this.
  19. braaap!
    Mar 16, 2005
    4,935
    Melbourne - AU
    Cheers!
    Some minor tweaks to be made on the flap dimensions as I can only source M6 spire nuts locally and they're dimensionally larger than what I'd prefer...
    :lurk
  20. braaap!
    Mar 16, 2005
    4,935
    Melbourne - AU
    ^ Nice Truck...
    Yeah, both of them :)
    06Z likes this.
