1. eNewsletter Sign Up
KTM 790 Adv accessories, Modifications and Upgrades
Discussion in 'Parallel World (790/890)' started by Migolito, Feb 5, 2019.
  1. macaw1us
    macaw1us Adventurer
    Jun 11, 2013
    95
    Thumper Dumper likes this.
  2. Thumper Dumper
    Thumper Dumper Been here awhile
    Apr 13, 2016
    325
    Durban South Africa
    Thanx it’s actually a 1980.
  3. windblown101
    windblown101 Long timer Supporter
    May 17, 2010
    5,753
    Star Tannery, VA
    I took a 225 mile spin with Motoz Rallzs mounted front and rear yesterday. Did some paved twisties, some mud, some rocky trails. I think they are going to work well for my wants/needs (Long distance all-roads travel). I dropped down to 20lbs of pressure for the off-road which helped a good bit.
    They certainly aren't a lightweight tire - Front was 2lbs heavier than the Karroo3 and rear was a whopping 4lbs heavier. However the gain in weight also comes with much better traction and a tire built to take more abuse, a worthy trade for me. ;)
  4. dzrtracin
    dzrtracin возьми
    Sep 28, 2004
    4,077
    the garage
    Venturer and Dusty like this.
  5. Fabricator
    Fabricator Hello Moto Supporter
    Sep 7, 2006
    221
    Kent, WA
    Is the full size image the .dxf file that the waterjet cutters are using?
  6. windblown101
    May 17, 2010
    5,753
    Star Tannery, VA
    I'll let you know. I've had similar bad experiences with 3 different varieties of the Motoz fronts on heavy bikes previously. However I ran a RallZ front for a trip on my 800XC and it held up to the abuse of on and off-road fairly well. It did cup severely later in the trip but I suspect that was caused by excess heat build up from a combination of factors (heavy duty tube, hot weather, and long hi-speed run back from Newfounland). Still, I did eek out over 4k miles out of it and liked it well enough to give it another go on this bike. I'm hoping that the lack of a tube, a bit less weight, and watching the street pressures I'm running a bit closer will make for less cupping. If so, it's a winner.
  7. 06Z
    06Z Been here awhile
    Nov 24, 2008
    726
    Temecula, California
    These are the Tractionator Desert H/T tires. I hit some sand, rutted, rocky roads just to test the traction. Very impressed with these tires. I even ran at street pressures. 32 psi rear and 34 psi front. What pressures would you recommend for off-road? 25 psi? These are with tubes. I have a 48t rear sprocket and she cruises at 67 mph at around 4800 rpm. In rally mode she has plenty of hit to lift the front. This bike is awesome! IMG_20190615_174806.jpg IMG_20190610_183817.jpg IMG_20190610_183850.jpg
  8. Migolito
    Migolito Prognosticator and MotoYogi
    Nov 6, 2011
    2,483
    S-Cal
    No one can give you a legitimate PSI for your bike. It's completely based on the total weights, sprung and unsprug, the terrain, your right hand, how you ride, etc. Get out there as you've been doing and start to find the sweet spots (PSI) for you. I'd go lower the PSI 2 psi at a time and see where it gets you. And, the front and back will not necessarily be the same PSI. I had the same rear on my 500EXC and it wears like iron.
    Very nice tires imo!
  9. braaap!
    braaap! Long timer Supporter
    Mar 16, 2005
    4,533
    Here and There
    Yep! But let me confirm hole centres first :)
    Fabricator likes this.
  10. SEK_Nick
    SEK_Nick Been here awhile
    Nov 4, 2015
    195
    Southeast Kansas
  11. Nowwhat
    Nowwhat I'll Go Second... Super Supporter
    Mar 2, 2007
    8,384
    On the Ground Laughing
    28 psi Front and Rear....
    06Z likes this.
  12. tshansen
    tshansen Been here awhile
    Feb 9, 2015
    588
    Norway
    Just mounted my new GPS today! Got the Garmin Zumo 396 LMT-S..... it was on sale here in Norway, so I had to find out if it was any good. And it did not disappoint.
    My last Garmin was a Navigator V...and the 396 are twice as fast in every way. There is no clear "how to" on transferring your rutes from your mobile phone to the GPS unit, so I tried to shine a light on the easy method I use.
  13. TrailTrauma
    TrailTrauma Nemophilist
    Jan 17, 2012
    5,019
    Ontario .. Superior
    Must be the angle on that photo - the Perun plate with the spacers looks like it's hovering well above the level of the seat. Can you snap a shot standing parallel to the bike, and level with the plate/seat? I understand that the plate with the spacers are supposed to be relatively level with each other.
    :beer
  14. braaap!
    Mar 16, 2005
    4,533
    Here and There
    Hey TT, having made my own plate I found that the front spacers need to be approx 42mm tall with the rears at 24mm giving the bottom face of the plate about 3mm clearance over the rear of the plastic mudguard...
    My 6mm thick plate then sits 20mm above the saddle.
    The Perun plate does appear to sit very high(?)
    Fabricator and TrailTrauma like this.
  15. TrailTrauma
    Jan 17, 2012
    5,019
    Ontario .. Superior
    What about a plate which angles parallel with the downslope of the OEM seat? That way the plate would just become a continuation of the seat plane creating one single mounting surface for any manner of bags, particularly for guys like me who will be trying to mount a Mosko Moto BC40 length wise from the end of the seat onwards and onto the plate. If I were mounting a top box then a plate parallel to the 'ground' would matter, but for many other purposes I can see an angled plate rockin.
    Essentially leaving the end of the plate just over the plastic tail, and then angling the rest down to be perfectly in sync with the seat.
    What do you think?
  16. Oceandiving954
    Oceandiving954 Been here awhile Supporter
    Oct 16, 2013
    413
    Florida, USA
    The Perun plate has an optional lowered subplate which I am waiting on. It will bring it level or below the seat which is ideal...the shipping cost as much as the plate lol
    TrailTrauma likes this.
  17. braaap!
    Mar 16, 2005
    4,533
    Here and There
    Yeah, I like your thinkin but unfortunately the front frame mounts are lower than the rears (and the threaded holes are perpendicular with the ground plane - not the seat plane) a plate running parallel with the seat plane (using simple turned / barrel spacers) will cause the CSK screw heads to sit crook in the plate top face rather than flush.
    The only other way is to make spacers which have threaded holes angled 90 degrees to the seat plane... Bleh, I'll post up a sketch :)
  18. braaap!
    Mar 16, 2005
    4,533
    Here and There
    Something like this would permit the rack plate to align with seat plane...
    Many ways to skin a cat...
  19. Yzlvr
    Yzlvr Been here awhile
    Jul 7, 2008
    933
    Thousand Oaks
    I like the prerun plate, but think its too big for the 790 and my needs. 1290 tail is much bigger that it was designed for. If they shrunk it 25% so it scaled to the 790 that would be great..
  20. TrailTrauma
    Jan 17, 2012
    5,019
    Ontario .. Superior
    I think that right there, with the plate parallel to the rear plastic fender, while also being at the perfect level & angle of the seat, would garner attention. :)
    braaap! likes this.
