KTM 790 Adv accessories, Modifications and Upgrades
Discussion in 'Parallel World (790/890)' started by Migolito, Feb 5, 2019.
  1. chippertheripper
    chippertheripper motorcycle junkie Supporter
    May 30, 2009
    10,171
    s.e. mass
    Not totally. However, all that extra heat isn’t helping things. I’m sure @Camel ADV will be along at any time to enlighten us, either here or over in the vendor’s section.
  2. SoilSampleDave
    SoilSampleDave Dr. Zaius was right!
    Jan 21, 2005
    9,025
    The Delta Ghetto, GA (aka PTC)
    Exactly. Heat destroys the VI of the shock fluid. There’s no way I’m going to get my shock removed and off to the suspension shop for a fluid change often enough to keep it fresh with it baking over the cat. I think the heat shield is a great idea.
    Camel ADV likes this.
  3. Snowq
    Snowq Been here awhile
    Aug 2, 2012
    331
    SWE
    Thanks Bud! Ordered! :smile6
    kzeb likes this.
  4. kzeb
    kzeb Been here quite some time
    Oct 22, 2006
    179
    Scandinavia
    Or.. a rally style exhaust.. like alot of people dreamt about on their 950/990's and could have given up a arm and a leg for :tb... never heard anyone had those worries on the routing under the swingarm..
  5. SoilSampleDave
    Jan 21, 2005
    9,025
    The key fact there is disposing of the cat. Once you have done that, rally or regular, you’re good. But I’m waiting for a Rottweiler engine management solution before canning the cat.
  6. kzeb
    Oct 22, 2006
    179
    Scandinavia
    Someone must have cut that cat open I really would want to see the magic inside it.
    Please show us c'mon Coober,Rottweiler, Rade Garage, wings, Arrow.. :amazon
    Coober will loose all there credibility for ever if decatted 790's don't end up with the engine failurs they described,
    I'll guess we will se the truth in a year or so when the decated bikes have som miles on them...
    I just don't buy it.
  7. TrailTrauma
    TrailTrauma Nemophilist
    Jan 17, 2012
    4,481
    Ontario .. Superior
    I've heard the cat is an ultra-complex 4-chamber affair with, yes, much that is magical. I was thinking Rottweiler should team up with Doug Henning! ;) Chris Angel works, if it has to be an 'merikan partnership.
    Note: No bunnies will be harmed in this endeavor. Cats, yes .. bunnies, no. So to recap - no cats, a few bunnies (purely for effect), and a half dozen (more) ponies.
    kzeb and CaseyB like this.
  8. factoryphil
    factoryphil Adventurer
    Oct 25, 2010
    90
    prescott valley az
    can someone that bought a sharon exhaust from rage garage please measure the pipe diameter size just before it goes into the silencer
  9. ShaftEd
    ShaftEd Long timer
    Nov 6, 2001
    3,891
    San Diego, CA USA
    Here's a cutout pic of a 790 cat from the Duke forum.
    kzeb likes this.
  10. Camel ADV
    Camel ADV Long timer Supporter
    Mar 4, 2009
    2,326
    Cowtown
    I'm happy to answer questions about the heat shield. I'm not a suspension tech but I believe there are some other issues with the shocks than just the stock set up pumping a huge amount of heat into them. If it were just the heat, the S models would be failing too but they don't seem to be or at least not in the same numbers. I think the R shocks are more susceptible to heat-related failures so keeping as much heat out of them as possible will go along way to keeping them from puking their guts out. R, S or other, it's beneficial to keep a shock cooler that hotter, that's why they have piggyback or remote reservoirs... more fluid = cooler oil = better suspension performance and longer service intervals.
  11. spartanman
    spartanman regret minimizer
    Oct 17, 2009
    2,331
    Land of High Hopes & Low Taxes
    So is the shell surrounding the pipe filled with catalyst material?
  12. SoilSampleDave
    Jan 21, 2005
    9,025
    I’ll bet a spare one of those costs more than a few dollars!
  13. ShaftEd
    ShaftEd Long timer
    Nov 6, 2001
    3,891
    San Diego, CA USA
    I don’t know the story behind the pic but I don’t believe any material has been removed from the housing. It seems the cat itself is the cylindrical pipe bulge. Part of the pipe has a defuser screen to let some of the exhaust into the overall housing. Maybe this is giving the back pressure that coober says is so needed on the 790 engine.
  14. spartanman
    Oct 17, 2009
    2,331
    Interesting. If that’s the case, it doesn’t look to weigh very much and isn’t that restrictive. The perforated section probably acts as a baffle, which explains why it quiets the exhaust note. There may be a plated honeycomb ceramic insert in the large diameter section, I’m guessing. Neat design.
    SoilSampleDave likes this.
  15. 52edub
    52edub Adventurer
    Apr 12, 2009
    81
    Meridian, ID
    Just picked up the seat today from Seat Concepts. There just down the road from me. Will ride tomorrow and provide my review. Just sitting on it in the garage I can tell it's a lot better than the stock seat. Necked down in the front allows me to reach the ground better. I can feel the better foam and don't feel like I'm leaning forward in the seat now.
  16. Nowwhat
    Nowwhat I'll Go Second... Super Supporter
    Mar 2, 2007
    8,224
    On the Ground Laughing
    What makes you think it isnt restrictive? I believe they weigh 6lbs...
  17. TrailTrauma
    Jan 17, 2012
    4,481
    Ontario .. Superior
    Rottweiler must have a few laying around now. They would fully cut into one, to remove this speculation. Hell, make a video on it, and tie that into the drive to want to decat. We all stand to learn a bit; at least I do.
  18. spartanman
    Oct 17, 2009
    2,331
    One main shot through. No torturous bends. 6 lb is light for a cat, though a straight pipe with flanges is probably about a pound.
  19. Thumper Dumper
    Thumper Dumper Been here awhile
    Apr 13, 2016
    293
    Durban South Africa
    Fitted my pannier racks and tool tube. E4DEFCE4-3BF6-4E98-A277-B2A3D9CF545A.jpeg D3FE7CD6-E7F1-43A8-9816-9259E2B4BA6E.jpeg 2A8D342A-D581-44E6-8165-43BB2112179D.jpeg
    scfrank, Cybsal, TrailTrauma and 2 others like this.
  20. Bluetonguejak
    Bluetonguejak Pretend racer
    Sep 16, 2009
    2,597
    Gippsland
    Duke cat
    kzeb and Nowwhat like this.
