1. eNewsletter Sign Up
KTM 790 Adventure
Discussion in 'Parallel World (790/890)' started by 2whlin, Oct 8, 2017.
  1. Cani41
    Cani41 Adventurer
    Mar 14, 2016
    22
    Nîmes, France
    She is here since two days.
    Already two days of work:
    searching for a indebted:
    Benduro, ibgary, mtntrails and 9 others like this.
  2. Subaruvich
    Subaruvich Been here awhile
    Aug 14, 2018
    228
    EU
    I did have a test ride two month ago. I was surprised how good it was off-road even on street tires.
  3. alonad
    alonad Been here awhile
    Mar 5, 2013
    483
    new york
    hey guys what gauge wires do you use to positap the 12v wire?
  4. [Art]
    [Art] Been here awhile
    Feb 20, 2019
    370
    France
    Don't positap anything please. Use the proper connectors, or install the proper connectors. Positap are convenient, but a source of electrical gremlins.
    The gauge of the wire you need depends on how much current the hardware at the end of the line is going to pull, without knowing this info we can't answer the question.
    angustoyou, Benduro, ibgary and 2 others like this.
  5. Rudderfeet
    Rudderfeet Been here awhile
    Feb 25, 2014
    990
    Central Ohio, USA
    +1. I've used them, but they tend to get shaken loose on motorcycles, especially off-road ones.
  6. tshansen
    tshansen Been here awhile
    Feb 9, 2015
    591
    Norway
  7. Oceandiving954
    Oceandiving954 Been here awhile Supporter
    Oct 16, 2013
    413
    Florida, USA
    you mean "casket" lol
    chippertheripper and tshansen like this.
  8. alonad
    Mar 5, 2013
    483
    new york
    I have a hard top case that I use in the city or if I go two up on slab.
    And soft for real trips
    Tim Cullis and tshansen like this.
  9. alonad
    Mar 5, 2013
    483
    new york
    The heated grips are used for the heated grips
    The 12v I will probably never use so I want to tap into it so I can run my usb and my GPS
  10. alonad
    Mar 5, 2013
    483
    new york
    5amps
  11. AdamM001
    AdamM001 Been here awhile
    Oct 30, 2015
    209
    Texas (by way of Norway and Nova Scotia, Canada)
    Brake light issue (790AdvR).
    Went for a small group ride today and was told my brake light is always on.
    Brakes are NOT always on (all 3 disks relatively cool- it is a switch issue).
    Tried pulling the brake light fuse; the ABS fuses, disconnecting rear Taillight harness - no help.
    I’ve noticed that when I pull the front lever hard and instantly let it go; at the most outward position of the lever for an instant, the light flickers off. (Relieving pressure on the front master cyl piston).
    Removed front lever and pushed piston a few times with a screwdriver - no binding or obstruction. Light stays on with lever removed. (Problem isn’t that it’s partially engaged. )
    I can only figure that it’s the hydraulic sensor; which I guess on these bikes is on the ABS unit. (Before this- I’ve only had my non-ABS 950 for years!)
    I tried opening front master res cover and pumping the lever to ensure no pressure/air bubbles there. All good.
    I can’t find any schematic for the 790 Adv; but if the same as the 790 Duke- it would be item 17 in the below schematic
    Does anyone know what I can do here - short of replacing it?
    It is of course a holiday today; and I’m heading on a 1000 mile road trip this weekend, leaving early tomorrow!
  12. SoilSampleDave
    SoilSampleDave Dr. Zaius was right!
    Jan 21, 2005
    9,426
    The Delta Ghetto, GA (aka PTC)
    Are you not seeing an error code?
  13. AdamM001
    Oct 30, 2015
    209
    ...currently trying to decide if it’s worth pulling the tank just to expose a sensor I’m not sure I can do anything TO!
    Does anyone know of any way at all to reset pressure on an ABS unit brake light switch?
    My only experience with hydraulic brake light switches has always been the non-abs setup; at the rear wheel - which is usually the opposite failure (broken/kinked wire not allowing the switch to sense the increase in pressure to turn light ON...)
  14. Oceandiving954
    Oct 16, 2013
    413
    Florida, USA
    Yes , drive it about 10 minutes and hit both front and rear brakes several times hard ! Turn off motor recycle it a few times , it will resume to normal.
  15. AdamM001
    Oct 30, 2015
    209
    No.. just rear brake light on always - as if the brakes are applied
  16. erey
    erey Been here awhile
    Sep 15, 2013
    387
    Bulle, Switzerland
  17. WillDieSoon
    WillDieSoon Adventurer
    Feb 6, 2010
    97
    Kamloops, BC
    I thought I read that the 790 had a CANBUS electrical system (i could be confused, happens a lot).
  18. AdamM001
    Oct 30, 2015
    209
    I think I DID recall seeing that - but only reading the “a short trip to the dealer will fix this” part.
    I rode 150 miles today with it not going off... but then I guess i didn’t brake HARD at any time.
    Guess I’ll button it back up and give it a try...
  19. Subaruvich
    Aug 14, 2018
    228
    EU
    Bike is finally ready. First ride tomorrow.
    Benduro, enduro16, ibgary and 13 others like this.
  20. Tool.Nerd
    Tool.Nerd An idiot that owns a bike
    Jan 10, 2016
    552
    Southeast TN
    Forgive me for not knowing my dualsport tires by sight now, but which tires are those? TKC80s?
    hgwilliam likes this.
