KTM 790 Adventure
Discussion in 'Parallel World (790/890)' started by 2whlin, Oct 8, 2017.
  1. Some_Dude
    Some_Dude Been here awhile
    Jun 23, 2019
    590
    Edmonton
    There’s a reason electrical gremlins are called electrical gremlins.
  2. TrailTrauma
    TrailTrauma Nemophilist
    Jan 17, 2012
    5,801
    Ontario .. Superior
    No kidding .. I don't mind hunting down an issue, finding it and resolving it but I don't relish riding where I do with what could be a random, rather fast failure.
    I haven't checked the stator yet. The shop manual details the procedure, but fail to mention where the stator harness they're showing is. So the dumb Q of the day is wth is the stator harness? I couldn't get my oil filler cap off (I haven't ground it down yet), but I loosened it as much as I could and it smells fine, so I suspect it's not a burnt stator. I'd still like to check it all over once I locate the harness.
    This one:
    Odd, because in the schematic it shows the stator plugging into the rectifier. Well that connector (at the rectifier) has 5 leads, not 3 as above. Positive, negative and 3 diode leads. I suppose I can unplug the rectifier, and knowing what 3 leads on the plugin are going back to the stator, just use those for testing. I'm not sure what the manual doesn't show the rectifier harness with it's 5 leads.
  3. lowerlattitudes
    lowerlattitudes LowerLattitudes
    Nov 4, 2008
    318
    Surrounded by traffic in Atlanta
    with 14.62 showing at 5K I would not think you reg or stator is damaged. I am now at as much of a loss to explain as you. : (
    TrailTrauma likes this.
  4. TrailTrauma
    Jan 17, 2012
    5,801
    Ontario .. Superior
    On the bright side, at least now I have discovered the damage to the rad (which was hidden), and the cracked lower plastic shroud. I can inquire as to whether the damage is enough to mess up a rad. And I've stitched up the plastic which seems to return some of it's integrity so the rectifier stays secure. I also have those low rectifier readings to discuss with the dealer as well.
  5. justinope
    justinope Long timer
    Oct 28, 2013
    1,865
    Las Vegas, NV
    On a slightly unrelated note, That's kind of a bummer that even with the rally style tanks they are mounted in such a way that the radiator can get messed up. Usually on bikes with portruding tanks that's one of the advantages is a low chance to hurt them in most cases.
    Maybe some upper bars would be worth it after all for the more hardcore dirt goers
  6. chippertheripper
    chippertheripper motorcycle junkie Supporter
    May 30, 2009
    10,869
    s.e. mass
    Nothing is human proof.
    bobnoxious67 and Nowwhat like this.
  7. TrailTrauma
    Jan 17, 2012
    5,801
    Ontario .. Superior
    Funny you should mention protection in that area - I woke up with exactly that thought streaming through my brain - would some modest bars up there have helped in those 4 drops? It's not even that those drops were hard. I simply either stepped off the bike as it went over, or I was walking it in the rocks and lost my balance and the bike went over. The force was multiplied by the rocks. Had they not been there, none of this damage would have occured save the mirror .. it just buried 6" into the dirt and shattered just to be a douche I figure.
    But when I think about that guys bike going up in flames regardless of the reason behind the accident, and also my rad damage in a supremely simple drop onto a large rock, I have to seriously consider the validity of installing armor now.
    These photos show the vulnerable window - you can see the scratched plastic from the hit, and if I run my finger up just slightly out of view on the rad there the dent is in that location. VERY vulnerable.
    I don't know if there is armour yet which protects quite that high. Most, if not all, falls short by a foot.
    This sw-motech product could work, but it's not foolproof:
    Oceandiving954 likes this.
  8. Nowwhat
    Nowwhat I'll Go Second... Super Supporter
    Mar 2, 2007
    8,751
    On the Ground Laughing
    Today's progress shot ... facelift . Have to pull the graphics off the hand guards IMG_2776.jpg
    TarMack, IRLSAS, Falco888 and 11 others like this.
  9. Some_Dude
    Jun 23, 2019
    590
    Edmonton
    It’s kind of a trade off. You can make a bike into a tank, but then it’ll drive like a tank.
  10. TrailTrauma
    Jan 17, 2012
    5,801
    Ontario .. Superior
    Those must be TKC-80's :hide
    Nowwhat likes this.
  11. chippertheripper
    May 30, 2009
    10,869
    s.e. mass
    You gonna get a weight so far before you put it on the truck?
  12. Nowwhat
    Mar 2, 2007
    8,751
    Not a street bike anymore hahahaha
  13. 222k km adv bike
    222k km adv bike Been here awhile
    May 20, 2019
    637
    FRANCE
    Hi, fully agree, it would be a 1250 bmw gsa !
    By the way, I know a swedish tank crew that broke a tank during training sessions. 45mph on big whoops, lost control, went straight in a rock cliff, gun and turret broken... nothing is human proof !
    Noyah, TrailTrauma and Nowwhat like this.
  14. TrailTrauma
    Jan 17, 2012
    5,801
    Ontario .. Superior
    Update: 50km rip today and voltage stayed at 14.7 to 14.8. I flicked on the high beams, and signals and it dipped a tenth. Everything 'seems' fine. The connector to the R/R looked fine, but maybe they're finicky and the jarring pulled it back enough to mess with connectivity while not pulling it off. I'm grasping :dunno
    Wouldn't say the bike was wandering on the ride, but man the front end sure felt loose. Maybe I'll check for loose head bearings...:fpalm
    Edit:...Nope. Bearings are fine. And nice fall away either side. Clutch cable slows it down to the left, but if I hold it away a bit as I check it falls away nicely as well.
  15. Nowwhat
    Mar 2, 2007
    8,751
    I am sure Rottweiler will have his race scales at the Rally.... They have been so incredible in getting everything done last minute....I don't want to pester him by asking.....but damn I want to know....
    Still waiting on an airbox replacement from them....that will save weight and few things still to go....but I think I came up short on the diet....I am guessing 435lbs fully fueled....I think I can pull another 6 to 8 off in a couple weeks....
  16. TrailTrauma
    Jan 17, 2012
    5,801
    Ontario .. Superior
    Couple turdy inchers and you'll be fine :)
    I didn't think I'd like the front end, but seeing it now I love it. Not sure what the youngins say these days .. s1ck? :drif
    Nowwhat likes this.
  17. TrailTrauma
    Jan 17, 2012
    5,801
    Ontario .. Superior
    Thats another thing I came across when hunting down gremlins - my vent hose was swinging in the breeze. curved the hose so as to keep it away from the exhaust, and snapped it into the hole through the protector. Without the chatter on the subject I would never have looked at that hose twice.
  18. TrailTrauma
    Jan 17, 2012
    5,801
    Ontario .. Superior
    I have a request. Can someone with a good vinyl printer design a vinyl piece for the fork guards that is white primarily and has "790" in black or orange with one of those big "R"'s you see guys stick on the windshields. One of the members here has a nice orange R sticker on his screen. I'd like to order the Rally white fork guards but fat chance of that I'd think at this point.
    I'll leave the design up to the artist, but if I like what I see I'll slap money down.
    Might be nicely complemented by the white rear plastics of the S. Just have to print off a smaller "R" to stick below Adventure.
  19. Nowwhat
    Mar 2, 2007
    8,751
  20. a.c.e.
    a.c.e. U Mud, Bro?
    Nov 20, 2018
    463
    Germany
    "R" on the windscreen?!
    I'll attach the little file I've used at our local printshop, it's easy to do a vector off of it.
    kvango, DRglidarn and TrailTrauma like this.
