KTM 790 Adventure
Discussion in 'Parallel World (790/890)' started by 2whlin, Oct 8, 2017.
  1. JP4
    JP4 Thumper Geek
    Mar 22, 2003
    215
    Hood River, OR
    My 390 Duke with the same display had that problem as did many of the little Dukes. Replaced under warranty and the second one had the same problem, though not quite as bad. That display had never been exposed to water. Never washed, never in the rain.
    My theory is that the displays are assembled in a high humidity environment, trapping moisture which then condenses when exposed to cool temperatures.
    Yihaaa, tshansen and TrailTrauma like this.
  2. Salzig
    Salzig Long timer
    Oct 17, 2008
    1,370
    Cremona, Italy
    That's what was happening to my cheap chinese tyre pressure monitor. I opened it and heated it up with a hair dryer (which I have no use for anymore...). No more fogging since.
    Is the 790 display openable?
    Rudderfeet and JP4 like this.
  3. ramirin
    ramirin Ready to push
    Mar 25, 2008
    518
    FIN
    Update on too tight front axle: I tested indepandently to wheel (perfect) and left fork (perfect) and right (too tight). So the thicker part of axle was too big for the fork. I took pictures of scratches it made to axle when removing (will ask if dealer want's to get me a new axle) then sanded paint away from that part and now it slides right in & out like it should.
    About xplor pro suspension, I asked many times from dealer that please make sure it comes 270mm as I read that it exists also in 240mm. I wish dealers had more aknowledgement of what they are representing. Places like Rottweiler and Conflict sound awesome but are unfortunaltely situated too far from here.
    @Subaruvich Do you happen to know what parts are needed for stretch?
  4. r1d3rg652gs
    r1d3rg652gs DesertSleder
    Oct 22, 2012
    586
    Greece
    What front brake master cylinder are you using? It looks it has a brake fluid reservoir...did it come with the rebel x sports kit?
    It looks like brembo...is it the RCS 17mm? the simple one or corta corta?
  5. ramirin
    Mar 25, 2008
    518
    FIN
    @r1d3rg652gs As I just asked this (conversion to single disc) from Rottweiler, here goes:
    We are currently using the Brembo M50 caliper paired to a Brembo 15mm RCS master cylinder (links below).
    http://www.rottweilerperformance.com/brembo-m50-monoblock-left-front-brake-caliper/
    http://www.rottweilerperformance.com/brembo-14mm-rcs-radial-front-master-cylinder/
    We do not list the 15mm RCS master cylinder for sale on our website as of now but plan on releasing it with options to make this brake swap plug and play.
    TrailTrauma likes this.
  6. Rodooo
    Rodooo Been here awhile
    Mar 31, 2013
    241
    IRELAND
    im on my 4th display...they all fog up...last one was fitted n it fogged up 10 mins after leaving dealers..apparently there will be a updated part soon
    JP4, TrailTrauma and chippertheripper like this.
  7. Rodooo
    Mar 31, 2013
    241
    IRELAND
    im on number4...…..dealer will fit a 5th but I cant see the point..at the minute nofix but apparently are working on it....hes been told to just keep replacing them and finally the factory will get the hint and sort it out
  8. r1d3rg652gs
    Oct 22, 2012
    586
    Greece
    15mm RCS is for dual disc or single? 790R has dual disc in front. You want to make the installation plug and play for the 790R? What is the difference between the 15mm and the 17mm? I think rottweiler have the 17mm in their website for the 790 R.
  9. chippertheripper
    chippertheripper motorcycle junkie Supporter
    May 30, 2009
    10,160
    s.e. mass
    15 is for the single disk conversion. If you watched the video Chris says they'll have a kit available at some point.
    SoilSampleDave and TrailTrauma like this.
  10. r1d3rg652gs
    Oct 22, 2012
    586
    Greece
    So the 17mm is for the dual disc set up?
  11. ramirin
    Mar 25, 2008
    518
    FIN
    Probably so.. Are you planning on updating dual disc?
  12. SEK_Nick
    SEK_Nick Been here awhile
    Nov 4, 2015
    142
    Southeast Kansas
    Directions to starbucks unclear. Found gypsum hills instead. 20191012_112205.jpg
    IRLSAS and SoilSampleDave like this.
  13. coloktmGS
    coloktmGS Been here awhile
    Jul 11, 2005
    445
    SW MO
    Anybody’s dealer stock WP Pro Components Or are these special order only?
  14. CaseyB
    CaseyB Adventually Supporter
    Mar 16, 2011
    1,221
    The Garden State
    Where is it fogging up for you? Same spot all four times?
    I get it occasionally in the upper right, but it goes away.
  15. Rodooo
    Mar 31, 2013
    241
    IRELAND
    current dash is misting at the sides but does get bad enough to not be able to read it...only bout a inch in middle not misted up...and that was straight from dealers,bike never was wet...3rd set was even worse they misted up totally.and was getting weird key failure warnings come up n bike wouldn't start
  16. PomInOz_
    PomInOz_ Adventurer
    Apr 11, 2016
    55
    Sydney
    What settings are people using when offroad when struggling for traction?
    I've been using offroad ride mode with abs off and this has been really good for me especially on firetrack type roads. I found the tc really helping to the point where I was being a aggressive on the throttle kicking the rear out a bit in corners as could feel the tc control it.
    However I hit a steep hill climb / series of steps today and struggled getting up. I hit the climb running for the momentum but over the first section the engine just bogged as traction control killed the power so ended up stopping not at the best spot. After stopping I remembered one of the KTM promotional videos where they said to turn it to rally mode and set tc to 7. I did this and set throttle to offroad but still struggled to get going with the Karoos just spinning out from under me looking for traction but once moving made it up the rest of the steps with a lot of effort.
    ibgary likes this.
  17. tshansen
    tshansen Been here awhile
    Feb 9, 2015
    469
    Norway
    When i go offroad, or even 50/50 on my trips i keep it in rally mode. And adjust the traction on the fly. normal dry gravel i keep the slip on 5, if its wet and muddy i often need to go up to 8 or 9 to go anywhere. In loose sand or the really loose gravel i go down to 1 on the slip. just need to try it out, its hard to tell what to use, you need to feel it for yourself with the way you drive and the tires you use. One tip, get rid of the karoo3's.... made a huge difference for me
    IRLSAS, Cybsal, Rudderfeet and 2 others like this.
  18. ibgary
    ibgary Long timer
    Oct 18, 2013
    1,593
    Colorado
    Usually off-road mode. If it gets muddy I'll switch to rain.
  19. PomInOz_
    PomInOz_ Adventurer
    Apr 11, 2016
    55
    Sydney
    That makes sense keeping it in rally mode vs keeping it in off-road as can set off-road throttle response in rally so the power is softer while also adjusting the tc on the fly. I’ll have a play with the tc levels.
    tshansen likes this.
  20. NomorBills
    NomorBills WesternExplorer
    Aug 20, 2010
    295
    Chandler, AZ & Summer in the Pines, Pine, AZ
    There is no Magic Button. No replacement for good rider technique.
    ibgary, Gerst, ramirin and 1 other person like this.
