KTM 790 Adventure
Discussion in 'Parallel World (790/890)' started by 2whlin, Oct 8, 2017.
  1. Quinn Otte
    Quinn Otte Can't really wheelie
    Aug 31, 2015
    301
    Auburn, AL
    Mine has the flathead screw in the middle of that nut. I don't think the 17mm is supposed to be moved?
  2. windblown101
    windblown101 Long timer Supporter
    May 17, 2010
    6,076
    Star Tannery, VA
    The R has the center screw for low speed, a 17mm nut for highspeed, and then an even larger nut (that you most definitely do not want to loosen unless you feel like making a mess...
    SoilSampleDave likes this.
  3. Quinn Otte
    Aug 31, 2015
    301
    Auburn, AL
    Word. I see it now. Thanks.
    I've owned the bike for 2 days. Need to thumb through the manual.
    rsteiger and windblown101 like this.
  4. 1coolbanana
    1coolbanana Long timer
    Aug 25, 2009
    6,580
    NW Sydney, Australia
    Manuel :-)
    Edit: Damn auto correct, meant manual :lol3
  5. a.c.e.
    a.c.e. U Mud, Bro?
    Nov 20, 2018
    451
    Germany
    Eh?
  6. 1coolbanana
    Aug 25, 2009
    6,580
    EvilSteve likes this.
  7. AdvRonski
    AdvRonski They call me......Ronski
    Feb 4, 2007
    1,385
    Finally made it to Fruita!
    So, I just put the Antigravity ATZ-10 Re-start battery in the 790 a few days ago, but today I noticed the battery system voltage constantly climbing up and down between 14V and 16V, just like this post from last year. It did NOT do this with the OEM battery, and it looks like no one ever answered the OP's original post. I'm wondering what's going on here, as the LIFEPO4 batteries don't really like charging voltages much over 14.7V, much less 16V.
    Falco888 likes this.
  8. 1coolbanana
    Aug 25, 2009
    6,580
    Weird, stock charging system should not go over 14.5, anymore is bad.
    Put the stocker back in and see what happens maybe?
  9. Snowq
    Snowq Been here awhile
    Aug 2, 2012
    412
    SWE
    I have a Lithium battery on mine, charge is stable at 14.5 V.
  10. EvilSteve
    EvilSteve Not so evil, not so Steve.
    Jun 30, 2008
    533
    SoCal
    I have checked the FAQ a couple of times and looked around, I'm wondering what short clutch levers people are using. The clutch lever is super long so I'm hoping for something shorter.
  11. 1coolbanana
    Aug 25, 2009
    6,580
    Not anymore, I broke mine off and its a shorty now :lol3
  12. TrailTrauma
    TrailTrauma Nemophilist
    Jan 17, 2012
    5,605
    Ontario .. Superior
    As above, I too snapped one of mine off in a drop. Came home and just wrapped the levers in hockey tape. I should probably take bolt cutters to the other lever so they're both short but I'll have to wait till the snow melts so I can get into the shed to get them. Quick and dirty shorty levers. ;) The tape gives them a nice feel imo.
  13. Quinn Otte
    Aug 31, 2015
    301
    Auburn, AL
    I saw a few people here using Raximo levers. Mine are on order, check in next week
    EvilSteve, alonad and SoilSampleDave like this.
  14. ibgary
    ibgary Long timer
    Oct 18, 2013
    1,737
    Colorado
    My output shaft seal was replaced at the 1st service, July or August of 19. No leaks since then.
  15. ibgary
    ibgary Long timer
    Oct 18, 2013
    1,737
    Colorado
    I put that in mine a couple of weeks ago. I'll look at the voltage when I ride today.
  16. AdvRonski
    Feb 4, 2007
    1,385
    I did some further investigation, and found that, along with the wild voltage swings, the headlamp flickers on and off, and the high beam comes on by itself at times. The voltage spikes must be really playing havoc with the canbus controller. When I put the stock battery back in, I get a nice, even 14.6V charging rate, and the headlamp operation is normal.
    I contacted Antigravity about this, so we'll see what they have to say.
    EvilSteve and windblown101 like this.
  17. 1coolbanana
    Aug 25, 2009
    6,580
    Seems to be quite a few weird things happening I see with Antigravity batteries :dunno
  18. markbxr400
    markbxr400 Been here awhile Supporter
    Sep 26, 2016
    633
    Lower Alabama
    I'm running the ATZ-10 in my R. So far, no issues. Im wondering what else is going on as I lost a brand new battery in a brand new bike in less that 5 months. Maybe something fluky in the charging system on these bikes?
  19. SoilSampleDave
    SoilSampleDave Dr. Zaius was right!
    Jan 21, 2005
    9,840
    The Delta Ghetto, GA (aka PTC)
    I assumed it was the charging system?
  20. AdvRonski
    Feb 4, 2007
    1,385
    That's not a conclusion I would reach. The charging system has been operating normally for 10,000 miles with the stock battery, went right around the bend with the Antigravity battery, and is acting normally again with the stock battery. The ATZ-10 battery with Restart has a whole layer of electronics between the electrical system of the bike and the actual storage cells, to limit over-charging and over-discharging, so it would seem something is going on in that area.
