KTM 790 takes a few tries to start
Discussion in 'Parallel World (790/890)' started by doctorblanco, Sep 10, 2019.
  1. spartanman
    spartanman regret minimizer
    Oct 17, 2009
    2,398
    Land of High Hopes & Low Taxes
    I crack the throttle slightly and give it a touch more when cranking. Starts first time. If there's a factory fix down the road I'll get it, but in the meantime, no big deal.
    #21
    scfrank likes this.
  2. Beshar
    Beshar Adventurer
    Aug 5, 2019
    40
    Sweden
    Can you who have problems check which software version you have? It’s in the settings menu.
    #22
  3. Smashy
    Smashy Been here awhile
    Feb 7, 2014
    423
    Toronto
    1V27
    #23
  4. Some_Dude
    Some_Dude Been here awhile
    Jun 23, 2019
    312
    Edmonton
    I’m on 1V27.
    One thing I’ll point out is that if you kill the engine using the kill switch and leave it in the off position, when you power the bike back up using the key the fuel pump doesn’t turn on until the kill switch is in the on position.
    So... if you start the bike by going from off to start the fuel pump doesn’t have time to prime the line.
    #24
  5. Smashy
    Feb 7, 2014
    423
    Toronto
    I thought I was already doing this, but I guess I was still holding it for too long. Yesterday I tried pressing and immediately letting go for the first start of the morning and it started up and stayed running on the first try. It's been pretty warm the last few days, I'm waiting for a colder morning to properly test this.
    #25
  6. Motopumps
    Motopumps Long timer Super Supporter
    Jan 1, 2007
    3,125
    Beautiful Upstate New York
    I had the same experience, thinking it was my button pushing technique, but it turns out it was pretty random. Cold weather seems to matter. Mine starts the first time about half the time now with 3100 miles on the clock. I am guessing the combustibility of the fuel you are using matters more than how you push the button. Hoping KTM has a software update that addresses this sooner than later. Makes me crabby when it won't start on the first try.
    #26
    dewaynehasty likes this.
  7. Night Crawler
    Night Crawler Beware the beast in black
    Mar 14, 2012
    296
    Portland, OR
    I remember reading this same issue in the 1090 forum. Most people said it went away when they changed the fuel filters.
    #27
  8. Motopumps
    Jan 1, 2007
    3,125
    Doubt that is the problem. This has been an issue from zero miles. The fuel filter and fuel pump problems on the 1090s, 1190s and 1290s is a well documented problem with recalls, etc. The fuel filter and fuel pump on the 790 is a different part number: 63507088000 (790) vs 60307088000 (1290)
    Rob
    #28
  9. [Art]
    [Art] Been here awhile
    Feb 20, 2019
    412
    France
    #29
    Smashy likes this.
  10. Motopumps
    Jan 1, 2007
    3,125
    I believe the fuel filter portion is a red herring.
    I work part time at a KTM dealership and have done a bunch of recalls on the 1090/1190/1290s and the issues there were fuel pumps, not filters. We have never seen a new bike with a clogged filter. There is even confusion on the internet about the color of the filter. They are black when wet (doesn't mean clogged). They turn white again when dried out. Checking the fuel filter on one of these bikes is not trivial.
    Rob
    #30
    Marki_GSA and fiascoj like this.
  11. [Art]
    Feb 20, 2019
    412
    France
    Updated. Is this better?
    If this doesn't start the engine every time, or if the engine stalls right away, check your fuel filter for contamination and the pressure at the fuel pump (or ask your dealer to do it). Note: Filters are black when wet, white when dry: don't assume a dark filter is a dirty one.
    #31
    Motopumps likes this.
  12. Motopumps
    Jan 1, 2007
    3,125
    Looks good. Thanks for creating that FAQ. I have referred to it often.
    Rob
    #32
  13. Smashy
    Feb 7, 2014
    423
    Toronto
    I think the fuel filter contamination is just a guess, and in my opinion it's not the cause. My bike has been doing this since brand new, which rules out fuel filter contamination. My guess is that this is a software issue, and we just need to wait for KTM to come out with a software update to address this.
    #33
  14. Motopumps
    Jan 1, 2007
    3,125
    Agreed. That is what I was trying to communicate. I do not believe the fuel filter has ANYTHING to do with this issue.
    Rob
    #34
    fiascoj likes this.
  15. dewaynehasty
    dewaynehasty Been here awhile
    Sep 30, 2013
    240
    I live in Florida where a cool day is 95 degrees and have the same issue. The funny thing is I took the bike to CO for a week in September at an elevation of 7300 and never had the issue. It started right up every morning. When I got back from CO, trailered the bike, with the same fuel in the tank, the issue happens again.
    It is annoying but not a big deal.
    #35
  16. Thumper Dumper
    Thumper Dumper Been here awhile
    Apr 13, 2016
    334
    Durban South Africa
    Agreed, if it was a fuel filter why would it only happen on the first start of the day.
    #36
  17. windblown101
    windblown101 Long timer Supporter
    May 17, 2010
    6,082
    Star Tannery, VA
    Agreed. I mentioned the other day mine had started on the first attempt for the last couple of weeks. I figured the coldstart adaptation had finally worked itself out. But I was also on a long trip out west at the time... I started it up yesterday morning at the house (70 degrees) and it required three attempts. Today it started on the first attempt at the house (50 degrees).
    I dunno, seems like the cold start is programmed just a tad bit lean. That might explain why it starts better at altitude when cold... Maybe.
    I've gotten pretty numb to it. 11k and change on the bike so far and it has never has never failed to start yet so it doesn't annoy me like it used to.
    #37
  18. Motopumps
    Jan 1, 2007
    3,125
    Yeah, pretty random for me at this point. Started right up this morning at 40 degrees f, then when I went to lunch, it took two tries at 70 degrees. Going to move on at this point. Not a show stopper.
    Rob
    #38
    windblown101 and scfrank like this.
  19. markbxr400
    markbxr400 Been here awhile Supporter
    Sep 26, 2016
    633
    Lower Alabama
    I was having similar issues with starting the bike. Tried the short press of the starter button mentioned above, and it works 90% of the time for me.
    #39
  20. Gordon Bennett
    Gordon Bennett Just you wait
    Mar 24, 2004
    950
    Albion
    The main culprit is the Euro 6 emissions regulations which have banned cold start enrichment routines in all engines.
    So don't expect a fix from KTM.
    #40
