KTM 790 takes a few tries to start
Discussion in 'Parallel World (790/890)' started by doctorblanco, Sep 10, 2019.
  1. AdvMoto18
    AdvMoto18 NORDO Supporter
    Jun 17, 2013
    2,387
    Coastal SC Low Country / Land of Shrimp & Grits
    Seems like every KTM I've owned with electric start does not want to start if you initially press and hold start button; especially if cold and been sitting more than a day or two.
    But, if you turn on the ignition, allow the fuel pump to build psi, then just bump the starter for a mere second or less...than pause a second...than press the start button it will crank right up. Just seems to be one of those quirks with a KTMs.
    If you have a lithium battery, when parked at home, best to have a lithium specific battery maintainer attached 24/7/365. I have a Shoai Lit battery and maintainer and no issues starting, even when cold. My maintainer died out-of-warranty and Shoai replaced it at no cost. That's customer service!
  2. kubcat
    kubcat Long timer Supporter
    Sep 22, 2016
    1,471
    Upstate NY
    The instructions for my Shorai charger say you can leave it on, but once charged, if it's kept in a temperature controlled environment, it can be detached and left as is for up to a year.
  3. windblown101
    windblown101 Long timer Supporter
    May 17, 2010
    6,299
    Star Tannery, VA
    If there is no parasitic drain from the bike on the battery I'm sure this is true. Lithium batteries have a very low self discharge rate. Problem is that some bikes, especially ones that have alarm systems, always hot USB adapters or other items improperly wired up do discharge the battery of an idle bike in a fairly short period of time.
  4. kubcat
    Sep 22, 2016
    1,471
    Upstate NY
    true, in fact, the instructions did specifically say as long as there is no parasitic drain...
  5. AdvMoto18
    Jun 17, 2013
    2,387
    Interesting...I don't see that info in the maual for the BMS-01 charger. I keep the charger plugged in all the time in the shop and use STORE mode. Charger manual here.
    My shop, while enclosed, is not climate controlled other than a dehumidifier.
  6. kubcat
    Sep 22, 2016
    1,471
    Upstate NY
    Printed right on the charger, but NOT found in the instruction sheet.
  7. AdvMoto18
    Jun 17, 2013
    2,387
    Imagine that! Never thought to look there! Thx for posting!
  8. kubcat
    Sep 22, 2016
    1,471
    Upstate NY
    Being as you're in the coastal low country, I doubt it would ever get cold enough for long enough to worry about the battery if there was no active drain on it. It does seem like the charger is smart enough to just leave it connected all the time, but when I connect mine to the fully charged battery, both lights flash and it doesn't want to go to steady light on storage mode, so that made me nervous and I just disconnected it.
  9. AdvMoto18
    Jun 17, 2013
    2,387
    Whenever I plug mine in, both lights flash and I simply select STORE. I keep it in store 24/7 and the light stays steady. It is pretty rare for us to stay below freezing in winter once the sun is up.
  10. kubcat
    Sep 22, 2016
    1,471
    Upstate NY
    Every time I press store, both lights flash, but if the battery needs a charge and I press charge, the charge light goes steady. Maybe the charger is defective.
  11. AdvMoto18
    Jun 17, 2013
    2,387
    Could be...call Shorai out in CA. I don't recall the guy's name (their only tech support person), but, he was extremely helpful.
  12. CC Ryder
    CC Ryder Adventurer
    May 7, 2013
    89
    Salty City, Utah
    I can confirm that for 2020 they have not addressed this issue.. I picked up my new bike yesterday.. It currently has 0 miles on it. Walked out to the garage this morning (34*F).. it took 4 attempts to start and keep running.. then it surged from 1600 to 2000 rpm until it got to the first bar on the temp gauge.. Is this what everyone is seeing? And the booster plug eliminates BOTH of these problems? This combined with no owners manual.. makes for a not so great first impression.
  13. Toddv
    Toddv Long timer
    Oct 17, 2013
    1,212
    SC
    Haven't had any stalling on mine but it's probably only been down to about 45 in my garage so far. Mine flairs up on start but settles back down pretty much right away.
  14. windblown101
    May 17, 2010
    6,299
    Star Tannery, VA
    Once the adaptive values have had a chance to adjust you may find it gets better. It seems to take some time. Mine almost always starts on the first push now. I seem to recall 1090 owners reporting similar issues when it first came out.
  15. Robinwm
    Robinwm n00b
    Nov 26, 2019
    3
    China
    I
    its not about battery from china. I found its bcz gas pump on ur end of left tank, open it take it out and if u found some white cover ur gas pump ,clean it after that it will fixed I do it twice in 5000KM now its never happen again.
  16. ZiggyInNc
    ZiggyInNc Been here awhile
    Mar 11, 2018
    304
    28722
    My 2020 doesn’t seem to have any problem. Starts right up in even 30 degree weather. Are you all waiting for the screen to boot up and fuel pump to pressurize before hitting the Starter button?
  17. VessG
    VessG n00b
    Feb 9, 2020
    4
    Bulgaria
    I'm late to the party here but want to note that I just bought the 2020 390 Adventure (zero miles) and it also does that, from a cold start. It did it twice in a row. The third time I opened the throttle slightly to have it stay alive.
    Also, I rented a 790 a few months back and it had the same issue too.
    Fuel quality is fine, shell V-power.
    And yes, I always wait for the fuel pump sound to stop.
  18. road_apple
    road_apple Hit the Trail
    Mar 10, 2009
    496
    Sometimes here, sometimes there
    No horse in this game yet...but hopefully soon! I would suggest a crank position sensor if this were a car it is a classic cold start problem symptom. Any way to troubleshoot?
  19. Motopumps
    Motopumps Long timer Super Supporter
    Jan 1, 2007
    3,142
    Beautiful Upstate New York
    They are excessively lean. There is no hardware issue.
    I installed a BoosterPlug I had laying around that I took off my 1290 SA when I did Rottweiler fueling dongles. It has not happened a single time since installing the BoosterPlug. No commercial interest, not a dealer, etc., etc.
    Rob
    TrailTrauma likes this.
  20. windblown101
    May 17, 2010
    6,299
    Star Tannery, VA
    This doesn't surprise me. Though as I mentioned, the bikes do seem to eventually adapt the fueling tables to eliminate the cold start issue, but it takes awhile... 13k (miles) on mine now. Somewhere around the 5k mark was the last time I had to hit the starter button twice. Completely stock motor/intake/exhaust with the exception of an Ozzie UNI airfilter.
