Ktm 950A rear shock spring
Discussion in 'Dakar champion (950/990)' started by mountaincadre, Nov 11, 2019.
  1. mountaincadre
    mountaincadre Long timer
    Jul 18, 2012
    1,729
    Mid Calder,Scotland
    I had the standard shock overhauled and set up ,( as much as possible with a standard shock) for my weight , it's better than it was but to be honest on the standard spring I'm just to light,(165lb) does anyone my weight have any idea's what spring I can use, it's a 2003 with 210mm of travel.
  2. alongat
    alongat Fesh Fesh
    Jan 20, 2010
    4,902
    Windsor, United Kingdom
    Try to find a WP spring in the 130/225 instead of your current 155 rate. You’ll be totally happy with that for your weight.
    1coolbanana and mountaincadre like this.
  3. alongat
    alongat Fesh Fesh
    Jan 20, 2010
    4,902
    Here’s the KTM part number for that rate spring: 91210093S
    There’s also a 140 rate if you want to go up a bit but for your weight, the 130 should be perfect.
    1coolbanana, Dusty and mountaincadre like this.
  4. mountaincadre
    Jul 18, 2012
    1,729
    Mid Calder,Scotland
    Thanks Alon, the suspension guy did a great job of what he had but there's only so much polishing a turd you can do.
    1coolbanana and alongat like this.
  5. mountaincadre
    Jul 18, 2012
    1,729
    Mid Calder,Scotland
    Alon what are your thoughts on progressive spring? I'll need to call one of the ktm dealers to try and get an answer to the w/p spring,( cant get anywhere with parts finder) but fleabay has progressive springs but hav'nt heard anything about them myself.
  6. alongat
    alongat Fesh Fesh
    Jan 20, 2010
    4,902
    I don’t have any experience with using a progressive rate spring on the Adv shock.
  7. alongat
    alongat Fesh Fesh
    Jan 20, 2010
    4,902
  8. mountaincadre
    Jul 18, 2012
    1,729
    Mid Calder,Scotland
    #8
    alongat likes this.
