KTm 990/950 ADV Master Cylinder Alternative
Discussion in 'Dakar champion (950/990)' started by VittoXVIII, Jun 17, 2019.
  1. VittoXVIII
    VittoXVIII Adventurer
    Mar 1, 2013
    45
    Switzerland / Italy.
    I've recently bought a KTM 950 ADV S in perfect conditions, it had been sitting in a Car Dealership fro almost 3 years.
    Excellent price, completely stock, and 17k km on it.
    The OEM master cylinder was already leaking, I've bought the kit to change the internal pistons, seeger and everything.
    My first mistake was to buy the kit with the OEM diameter, 10,5mm.
    As soon as I installed it it started leaking again.
    After a few weeks I had to fill mineral oil every 2h of riding.
    I came across and original BMW GS 1200 (2012) Master Cylinder, practically new, I took it home for 59 euros.
    Mounted without any problem, I've shortened the lever (I still have to paint the end, I know)
    This might be useful to everyone who's still in doubt of rebuilding the original mastercylinder/buying an expensive accossato etc.
    WhatsApp Image 2019-06-15 at 15.39.16.jpeg WhatsApp Image 2019-06-15 at 15.39.21.jpeg WhatsApp Image 2019-06-15 at 15.39.16.jpeg WhatsApp Image 2019-06-15 at 15.39.21.jpeg
  2. zedtours
    zedtours Been here awhile
    Jan 17, 2006
    687
    Surrey
    Nice
  3. Bonnie & Clyde
    Bonnie & Clyde Wishing I was riding RTW
    Jan 10, 2006
    3,880
    Gardnerville NV
    That's a good find
  4. Wastedavid
    Wastedavid Been here awhile
    Oct 27, 2013
    162
    Colombia, Cofee paradise
    Well, that's good to know, but does it match exactly or do you have to modify or something???
    What I did is rebuiding with a friend that works in a precission machine shop, bore the hole to a higher ID and them replace with a new bronze sleeve. It's been working fine for some months.
    VittoXVIII likes this.
  5. buaan
    buaan Been here awhile
    Nov 17, 2015
    179
    UK - Yorkshire
    Nice! Did you use the BMW clutch switch or reuse your KTM one? The clutch line, was that easy enough to sort as the BMW looks a banjo type.
    You managed to mount your choke on there too?
    More info on how you managed this would be great :)
  6. PeterKaa
    PeterKaa Been here awhile
    Feb 3, 2015
    448
    Copenhagen
    Magura part MG2700187 is a perfect fit, comes with choke if needed for 950s, a mirror mount and the switch included plugs directly into the harness.
    It also uses the short levers suitable for dirt bikes (and big o'l adv bikes).
    Very happy with it on my 990, it states that it should use dot4, I’m running ATF in mine with no problems so far.
    Bonnie & Clyde likes this.
  7. VittoXVIII
    Mar 1, 2013
    45
    Thanks Excellent! I'd love to have the tools and training to do that. I Know there's a Greek Guy who does that for 135euro.
    Since I would have had to spend 135 for the job + 30 for a new seal cap (since mine leaked) I opted for the cheapest option.
    Yeah I mounted the choke, no predisposed mount but it was easy enough to find a good place for it.
    The clutch line can be mounted on this master cylinder with no modifications.
  8. VittoXVIII
    Mar 1, 2013
    45
    That's true...but i cost 200 Euros :photog
    #8
  9. Rademenes
    Rademenes n00b
    Oct 22, 2018
    2
    Poland
    Hi
    I've also problem with leaking master cylinder in my KTM 990 Adv R 2011. Repair set did not help. I'm looking for replacement of master cylinder another then Magura. But my bike has also electric click sensor. How did you solve this problem. This BMW pump has click sensor ?
    #9
  10. VittoXVIII
    Mar 1, 2013
    45
    I've got a 2005 950. I've just removed the sensor altogether and bridged it.
    #10
  11. Rademenes
    Rademenes n00b
    Oct 22, 2018
    2
    Poland
    OK, thanks.
    #11
  12. schlusi
    schlusi Adventurer
    Jan 4, 2019
    12
    Germany / Switzerland
    If you are looking for a solution to mount the choke-lever, you can use a (Magura) Decompression-Lever.
    I use this on my 500 2-Stroke-Maico. Fits easy on a 22mm bar.
    #12
    Whodatschrome likes this.
  13. COXR650L
    COXR650L Long timer
    Nov 29, 2009
    2,186
    Denver
    That's a good alternative, although I'd be worried about breaking the reservoir in a get off.
    Another solution is to resleeve the MC with a bronze sleeve. It'll last forever then. I think i paid $85 to have mine done.
    #13
  14. PeterKaa
    Feb 3, 2015
    448
    Copenhagen
    I thought I'd update everyone on the status with this.
    Even though brakefluid is nasty stuff, the seals made for it will swell up slightly when in contact with mineral oil, so the dot4 version of the Magura 167 is a no go unless you replace your slave cylinder with one suitable for dot4, both Oberon and Sigutech offers this.
    In the end my new "flashy" master was useless, so I ordered the master repair kit for a mineral oil version of the 167, now everything is working nicely good or better than when the stock was new.
    So if you are going this way and sticking with the stock slave, order Magura part MG2700186 as it will come with the correct seals suitable for mineral oil seals.
    Hope this is usefull.
    #14
    Manakau.KTM likes this.
  15. roookie1
    roookie1 Been here awhile
    Jun 15, 2009
    455
    Denmark
    Im am a bit over 100000 km on my 950 adv. Never had a problem with the master, never done anything to it, other than new oil from time to time. Using fork oil 2,5. Is there a problem on specific model years?
    #15
  16. tomdubz
    tomdubz getting there Supporter
    Jun 29, 2010
    1,298
    87505
    Not a problem per say. It's a wear item. Mine needed a resleeve at around 100k km so maybe you're due.
    #16
    roookie1 likes this.
  17. zeropoint
    zeropoint Been here awhile
    Apr 5, 2012
    405
    UK Wetlands
    Mine was a problem. Started leaking at 16,000 miles . Did two rebuilds which covered the next 10,000. When the second failed I raised it with KTM (well outside the warranty period) and they part warrantied a new M/C....for the 990 they now use the one from the 690 Duke which has a slightly wider bore at 11mm. Holding fine for the last 10,000. I’ll get round to re-sleeving the original one of these days....
    #17
    tomdubz likes this.
  18. Whodatschrome
    Whodatschrome Long timer
    May 4, 2015
    3,018
    North of North Plains
    Do you happen to have a part number for that Magura lever?
    #18
