KTM 990 Idle Speed Control Stepper Motor Operation
Discussion in 'Dakar champion (950/990)' started by BillyD, Jul 6, 2010.
  1. Stickboy 990
    Stickboy 990 Adventurer
    Jul 13, 2018
    10
    Montreal
    Could the S/M be the reason why I have surge will riding on highway speed?
    The bike 990 Adventure R 2011 has a Roth filter, Akra with db killer.
    Changes the TPS and ajusted, Now doean't hold iddle and still surge on highway..............
    Next step, change the S/M.......
    I hate this, notting seams clear mostly guestimate LOL
  2. Themastermike
    Themastermike Think you caught me in a coma Supporter
    Jan 20, 2011
    3,836
    So Ill
    Ah, no. Stepper touching nothing at that rpm
    Assume you talking idle stepper
    Sent from my XT1585 using Tapatalk
  3. Stickboy 990
    Jul 13, 2018
    10
    Montreal
    Yes the idle stepper, Hight/ low Idle is every where and now it stalls.
    But I've run the beast with the stepper disconnected and it surged again, good for a 30 minutes but came back. I did change fuel filters.......
    When it surge, I just have to blip the trottle and it comes back ok.
  4. Sumi
    Sumi Long timer
    Mar 30, 2010
    2,239
    Hungary
    That's more like a TPS issue IMO
  5. Stickboy 990
    Jul 13, 2018
    10
    Montreal
    TPS is new...........I hate these grimlins
  6. chevtech
    chevtech Long timer
    Jun 14, 2016
    1,220
    Hood River OR
    Pretty well established the surge at cruise is the system responding to O2 sensor inputs. Many remove their O2 sensors for this very reason. However, if they are older, and higher mileage you could also have what we used to call a "lazy O2 sensor" which means is still responds but very slowly, causing the motor to surge even more than normal. O2 sensors are a wear item, they will not last forever. If you have over ~ 50K miles they might be tired. You need a labscope to see the pattern, but occasionally it is slow enough you can catch it with a multi meter.
    Hope that helps!
    Todd
    Benduro and Stickboy 990 like this.
  7. Stickboy 990
    Jul 13, 2018
    10
    Montreal
    Could they be bypass with resistence or just unplug them. Can I unplug them for testing.
  8. mousitsas
    mousitsas Long timer
    Oct 10, 2008
    4,030
    Athens, Greece
    If you have a tuneEcu cable, then better tick them off via the software. If not, unplug them and put resistors.
  9. TonyJenkins
    TonyJenkins Adventurer
    Dec 18, 2013
    69
    Cincinnati, OH
    Hey, new to this thread guys. Have a ‘13 990 Adventure Baja and I’m having trouble with the throttle racing. Was out on gravel roads, wiped out bad because when I let off the throttle, it actually cranked up instead of dropping off. Laid the bike down hard.
    My KTM guy (after checking it out) says the TPS is more than likely bad. KTM told him the TPS cannot be changed out, need a whole new throttle body. Well FM, it’s close to a $2k job? I’ve scanned through here and see that the Triumph TPS is the same motor but my mechanic says that KTM told him the TPS is molded to the throttle shaft, you can’t just change out the TPS.
    Can someone give me the cliff notes to a fix?
    1). Do I need to get a new throttle body or can I get the Triumph part to work? What is the part number of said TPS?
    2) Can anyone point me to a video or step by step to get this corrected?
    3) Help
    Thank you
  10. gefr
    gefr Life is a trip
    Nov 26, 2005
    5,075
    East Med, Greece
    You can buy the TPS separately from KTM as well:
    See here:
    http://www.munnracing.com/
    Main Catalog [​IMG] 2013 [​IMG] 990 ADVENTURE BAJA
    (ENGINE)
    61041077000 $124
    The problem is you need to open a hole to the airbox in order to be able to adjust it, without removing the whole airbox each time.
    You need to measure 0.55V when idling according to manual.
    Have a look in the ktm950info.
    Cheers
    Sorry,. I got confused which TPS is the faulty one. It usually is the right hand side when sitting on the bike, on the front throttle body. The 2 are not identical.
    Cheers
    Crazygreek and Team Vegas like this.
  11. TonyJenkins
    Dec 18, 2013
    69
    Cincinnati, OH
    Sorry, problem is in the stepper motor and gears, not sensor, my bad.
    Mechanic says that the stepper motors have plastic gears and that those gears strip out. Know anything about that? Is the stepper motor replaceable? Anyone know?
    I HAVE to believe that there is a way to change out the stepper motor...changing out the entire throttle body just doesn’t make sense.
  12. paulo.ag.gomes
    paulo.ag.gomes Sr
    Apr 4, 2010
    14
    Braga - Portugal
    0.55Volts ou 0.65Volts ?
  13. paulo.ag.gomes
    paulo.ag.gomes Sr
    Apr 4, 2010
    14
    Braga - Portugal
    Triumph - T1241182
    https://www.worldoftriumph.com/part-search?partnumber=T1241182
    KTM - 61041060000
    https://ktm-versand.de/en/spare-parts/52931/isc-stepper-motor-05
  14. TonyJenkins
    Dec 18, 2013
    69
    Cincinnati, OH
    The mechanic adjusted the tps and throttle body sync at idle...but also he noticed the throttle lock was not locked in the off position (not to mention I’ve dropped in quite a few times on the trail on that side) ...all that and it could have been that the throttle lock was catching just enough of the throttle to mess with it.
    I’ve only got a hundred or so miles on it since he gave it back to me and it’s been running flawlessly....I’ll report if anything else turns up in the future.
  15. TonyJenkins
    Dec 18, 2013
    69
    Cincinnati, OH
    Went to another dealer and they screwed around with it. They actually experienced the unpleasant surprise of downshifting into a turn to have the rpms not drop. They messed with it a little but i ended up putting a new throttle body to the tune of 1100$.
    Good news is that it runs perfectly now.
