KTM 990 Idle Speed Control Stepper Motor Operation
Discussion in 'Dakar champion (950/990)' started by BillyD, Jul 6, 2010.
  1. chevtech
    chevtech Long timer
    Jun 14, 2016
    1,278
    Hood River OR
    That would work, but there has to be a KTM spec for that idle stop. Best thing to do, would be to figure out what that is!
    :beer
  2. DeepSea
    DeepSea electronically challenged
    Dec 23, 2008
    1,266
    East Bay
    I'll work on those two measurements. My daughters car is broken down in my shop and a few other things in front of it, but will get it as soon as I can.
    Steve
    chevtech likes this.
  3. chevtech
    chevtech Long timer
    Jun 14, 2016
    1,278
    Hood River OR
    I will try to find an idle stop screw spec!
    :beer
  4. Salzig
    Salzig Long timer
    Oct 17, 2008
    1,839
    Cremona, Italy
    Last time I adjusted the TPS, I set it to 0.62V with the throttle forced shut via TuneEcu.
    But yet I screwed the screw :D, so this is likely useless for others.
  5. Themastermike
    Themastermike Think you caught me in a coma Supporter
    Jan 20, 2011
    4,021
    So Ill
    What is the adjustment procedure for the tps?
    Sent from my SCH-I535 using Tapatalk
  6. Salzig
    Salzig Long timer
    Oct 17, 2008
    1,839
    Cremona, Italy
    Who knows?? :D
    I can tell you what works for me.
    I use TuneEcu to force the throttle to fully closed position (under Tests->Adjust throttle cable) and then I adjust the TPS until I read 0.62V.
  7. chevtech
    chevtech Long timer
    Jun 14, 2016
    1,278
    Hood River OR
    Did you check to see what the TPS voltages are at idle after your (great idea) fixed position set against the throttle stop? I'm guessing a touch high, but at least they should be even and set from a fixed point!
  8. Salzig
    Salzig Long timer
    Oct 17, 2008
    1,839
    Cremona, Italy
    Ehm.... I did, but forgot to write it down
  9. Themastermike
    Jan 20, 2011
    4,021
    So Ill
    So the tps is on a slot type arrangement?
  10. chevtech
    chevtech Long timer
    Jun 14, 2016
    1,278
    Hood River OR
    Lol! "Hey got this great way to adjust this thing, but I turned that one screw, and didn't write down that one hugely pertinent voltage info once I was done!"
    You're no help at all!
  11. Salzig
    Salzig Long timer
    Oct 17, 2008
    1,839
    Cremona, Italy
    LOL!
    Yep.
    Benduro likes this.
  12. Salzig
    Salzig Long timer
    Oct 17, 2008
    1,839
    Cremona, Italy
    Seriously, it's not a crucial info. If you use the S³BAP® (Salzig's Set Screw Based Adjust Procedure) you only need to know the voltage at the fully closed position.
    Also if your bike is sound idle wise, you should take this reading for future reference.
  13. chevtech
    chevtech Long timer
    Jun 14, 2016
    1,278
    Hood River OR
    I was just typing, couldn't we just spin the idle stop screw in to set 1450 RPM idle disable stepper motor through tune ECU or pulling the shaft, and then adjust the TPS voltages against that hard stop? Basically what you did, but at target idle RPM, and then back that throttle stop screw off to the factory spec?
    This would be a repeatable and accurate procedure compared to what people are doing now.
    Thinking out loud...
    :hmmmmm
  14. chevtech
    chevtech Long timer
    Jun 14, 2016
    1,278
    Hood River OR
    What kind of royalties will you be charging for this obviously patentable (plus that's a great name!) procedure?!?
    LMAO!
    :photog :clap
  15. Salzig
    Salzig Long timer
    Oct 17, 2008
    1,839
    Cremona, Italy
    I've had that same thought, but don't like the idea of limiting the regulation range of the system.
  16. chevtech
    chevtech Long timer
    Jun 14, 2016
    1,278
    Hood River OR
    Not following you, I was suggesting to put the idle stop screw back to factory spec, after using it as a hard stop to adjust TPS, and RPM at factory target RPM ~ 1,450 with SM disabled...
    If we move the idle stop back to factory spec after adjusting this just looks like a win/win to me...What are you referring to?
    :dunno
  17. Salzig
    Salzig Long timer
    Oct 17, 2008
    1,839
    Cremona, Italy
    I missed the part where you'd set the screw back to stock position.
    But why bother with the screw?
    If your bike is ok, read the voltage and use it for future adjustments.
    If it's having issues, set it to 0.6V see how it goes. With two or three tries you'll find which value is good for your bike and you're gold (unless the TPS it's gone south).
  18. chevtech
    chevtech Long timer
    Jun 14, 2016
    1,278
    Hood River OR
    Just trying to set-up a protocol that is easy to follow and accurate, I think the combination of what you did, and what I suggested would meet that criteria!
    I want 25% of your royalties! ;)
    :beer
    Todd
  19. Salzig
    Salzig Long timer
    Oct 17, 2008
    1,839
    Cremona, Italy
    Done deal :thumb
    :beer
  20. Stmad
    Stmad Adventurer
    Sep 22, 2010
    10
    Athens , Greece
    This is from the service manual ...
    1. Throttle Position Voltage
    System:
    LC8: EFI
    DISPLAY
    Measurement : Throttle Valve PotentiometerUnit: Volts (V)
    TARGET VALUE
    LC8 990 Adv : Device Operation : Fully Closed
    0,56V – 0,64V
    Benduro, Salzig and chevtech like this.
