KTM EXC RFS to Street Scrambler
Discussion in 'Some Assembly Required' started by ghostridergary, Dec 3, 2018.
  1. ghostridergary
    ghostridergary Adventurer
    Nov 23, 2010
    82
    This is my first thread and rebuild, so be gentle with me!
    So I have a couple of EXC RFS’s - these are great bikes, light, quick, handle huge amounts of abuse and keep going and easily repaired.
    I have a 2004 EXC 450 and 2005 EXC 525; one is these (the 525) is my "Adventure Bike":
    And the other was used for the odd enduro but I got too old to do those so decided to convert the 450 for something more suitable for posing around in London!
    I was inspired by this….
    But found out it wasn't real but just a photoshop creation!
    However, one talented guy in the UK (Dan Ridge) had already gone this route and created this masterpiece:
    Dan kindly provided me with some hints and tips on how he had achieved his build so thanks to him.
    So this winter my project is to convert this:
    To something resembling the photoshop creation.
    I'm not rich or a professional mechanic, so I'm not planning on a concours-esque rebuild, but am trying to do it on a tight budget with my limited fabrication facilities and skills!
    So here we go.....
  2. ghostridergary
    Nov 23, 2010
    82
    So before I started in earnest I obtained some cheap parts off ebay which I thought might fit and bolted together some aluminium bar to form a subframe to provide a mock up to see how it all might fit together:
    The tank and fitting around the radiators look like being the tricky bits and the suspension probably needs dropping a bit.
    So having stripped these bikes down a number of times, I had it down to the frame in a couple of hours - as I said, its a great bike to work on!
    The frame had previously been powdercoated black from that "champagne gold" colour the 2004-2007 RFS's originally came in so just needed a touch up. I had good experiences with this Simoniz paint so gave it a few coats to freshen it up:
  3. ghostridergary
    Nov 23, 2010
    82
    Engine out - new piston, cam chain and head work in 2016 so no need for a major update -waterpump seals went this summer so replaced those.
    Got the bike in 2009, but no real idea of previous mileage/ hours but guessing around 2000mls/ 80hrs from previous owners description - since then I've done another 8000mls and 300hrs, so I'm guessing the engine has about 10,000 miles and 400hrs on it.
    Checked valves and clutch but no work needed. Noticed faint mark on end of crankshaft where it fits in seal in clutch cover - can't feel anything but maybe a new seal in the cover?
    Alternator cover had previously been sprayed with the Simoniz paint and seems to have held up well, so plan to do both clutch and alternator cover again
    So out with the spraycans...
    JagLite and rkdwp like this.
  4. Trackster12
    Trackster12 Been here awhile
    Mar 5, 2016
    172
    Davisburg, MI
    I'll be watching, I'm working on a 520 EXC street tracker. Your scrambler looks good.
  5. ghostridergary
    Nov 23, 2010
    82
    So sprayed up the triple clamps, alternator and clutch covers with the Simoniz Tough Paint - no special prep, just clean with soapy water, very light sand with 1200 wet & dry and block up holes and cover surfaces with masking tape
    Before
    After.... might need to buff up the letters a bit more - seems to have highlighted to pock marks on the case, although looks worse in photo than real life
    JagLite, shinyribs and JimVonBaden like this.
  6. CRW
    CRW I dont want a pickle
    Oct 8, 2005
    920
    Cotati Ca. USA
    Looks like a fun build. What are you going to do to promote airflow to radiators with out the tank shrouds?
  7. DiggerD
    DiggerD DougFir from SuperDuke Days
    Mar 14, 2013
    5,620
    Mid Wet Or A Gun
    I 'v had good luck with JB weld to fill small divots and crappy welds before painting.
    Excellent sanding / shaping , mixes up quick and easy in small amounts, cheap and stores well.
    There will be those who dislike the filler...but it has worked for me over the years.
    JagLite likes this.
  8. motomal
    motomal Been here awhile
    Oct 24, 2008
    314
    Somerset, U.K.
    I’m doing exactly the same thing with a 2005 Husqvarna TE250!
    I also have those two bikes as inspiration and I’ve seen the white one in the flesh in a dealer in Bristol too.
    I’m now at the tank stage, which one have you got on there please?
    #8
    JagLite likes this.
  9. ghostridergary
    Nov 23, 2010
    82
    Thanks for the interest, comments & tips.... in response.....
    a) Hadn't thought about the shrouds/airflow. To be honest, one of the issues is the way the rads stick out so I'm pretty sure they will have plenty of cooling ability
    b) Thanks - might give the JB weld a go on another cover I have then respray
    c) Dan's bike was on show at the Excel bike show in London last year so I got to take lots of pics - I think he had it on sale on ebay over the summer! The tank I went with was an chinese ebay one for a Suzuki GN125. I've made a rough bracket which bolts into the top of the main spar and has two rubber grommets which the tank slots into.
    The main problem with this build is getting the tank far enough forward due to the radiators.... and I'm not sure there is much that can be done about that - I've played around a lot with various combinations.
    #9
    JagLite likes this.
  10. FR700
    FR700 Heckler ™©®℗
    May 4, 2007
    18,166
    Your imagination.
    Take a 4" angle grinder followed by a TIG to the tank.
    #10
    villageidiot likes this.
  11. motomal
    Oct 24, 2008
    314
    Somerset, U.K.
    Thanks for the info, I have seen those for little money so will start there. I think just finding a shorter tank is the key to the rad to seat spacing issue?
    #11
  12. villageidiot
    villageidiot Long timer Supporter
    Apr 29, 2010
    13,066
    Orange County, CA
    id be cutting the tank and sliding it forward to get the nose of the tank where it needs to be then welding in corner pieces that clear the radiator.
    #12
    JagLite and FR700 like this.
  13. floydstar
    floydstar n00b
    Dec 10, 2018
    1
    Somerset, England
    #13
    airgord, JagLite and CopyCat like this.
  14. ghostridergary
    Nov 23, 2010
    82
    With regard to the tank - unfortunately I've not got the skills/ mates (or cash!) to think about modifying a tank (I know this was an issue for Dan) so wanted to go with something off the shelf.
    Had the front forks lowered by about 30mm by InChains (Ringwood) and will probably do something to the rear shock to match up the geometry.
    There will be lots of fiddling with the wiring etc at the headstock so started to see how that might pan out. Got a headlamp for £35 from Alchemy Parts in UK and made bracket to fit it to lower triple clamp.
    Need to decide how to mount the speedo - I had an old Vapor which I planned to use and initially thought of mounting it on a bracket with an ignition switch on top of the handlebars
    Thusly
    But will also try attaching to the triple clamps using a different bracket and see what that looks like.
    #14
    JagLite likes this.
  15. ghostridergary
    Nov 23, 2010
    82
    So made up an alternative bracket to fix on the triples (rather than the bars), with the indicator bracket and modified the original bracket for the wiring connectors - gonna be fun tidying that up and making it look decent!
    Indicators are mini-LED ones
    Then headlamp fixed
    Think I'll probably go with this, although might need some sort of shroud to hide the rats nest of wiring!
    #15
    JagLite and invisa-bill like this.
  16. ghostridergary
    Nov 23, 2010
    82
    So tidied up the swing arm at the weekend - checked, cleaned and regreased all the bearings. Removed the stickers and polished up the shiny aluminium with 800 & 1200 grit wet and dry and some aluminium polish - looks ok, although a few gouges are difficult to disguise
    Engine back in frame with new frame protectors and sprayed footpegs
    And Trailtech stand
    #16
  17. ghostridergary
    Nov 23, 2010
    82
    Now wheels.... I've got a 2004 640 Adventure with the soft Behr rims - I'm hopefully off to Morocco in early 2019, so thinking of swapping the blacked rims from that with the EXCEL rims off the EXC - the rear is a cush hub on both and I've done the single disc conversion so no issues there. The rear is a simple replacement but the front will need some work on the spacers to get the clearances OK.
    Unfortunately the black rims are a bit scuffed and the spokes have some rust but hopefully can be cleaned up
    Rear (I know tyre is wrong way round, thats because its just come off the 640 and the disc/sprocket are reversed on that bike!):
    Front
    Then had a play around with the rear shock (minus spring) to see how much to shorten to get the geometry looking right. My suspension man tells me he puts a spacer in to get the required length, which can be removed to take back to normal (or altered) when required. I reckon it needs to be shortened by about
    Will need to shorten/adjust that rear light carrier to stop it hitting the tyre!
    #17
    invisa-bill likes this.
  18. ghostridergary
    Nov 23, 2010
    82
    So trying to minimise the rads are the main issue with a water-cooled scrambler, so started with spraying them black with this..... they do a satin black one but I had this in the shed.
    If you note the filler side, I've had the top hose connector "straightened" to point directly downwards to try a give a bit more flexibility in moving the tank forward - might need to do the same for the non-filler side but we'll see.
    #18
  19. ghostridergary
    Nov 23, 2010
    82
    #19
  20. ghostridergary
    Nov 23, 2010
    82
    A couple more pics with tank in place:
    Happy new year!
    #20
