1. ** Enter to win a $250 gift card! We want to hear from you, please take this survey **
    Take this survey which covers a range of questions about improving the community, the things that interest you and anything else you want to share with us. All responses will remain anonymous.
    Click here to take the survey
    Dismiss Notice
KTM Front Brake Switch Engagement
Discussion in 'Thumpers' started by TipsyMcStagger, Apr 24, 2018.
  1. TipsyMcStagger
    TipsyMcStagger Long timer
    Oct 28, 2006
    1,634
    NYC & NPR, FL
    I just installed the OE front brake micro switch on my XC-W. All of the front brake perch part numbers are common between the XC-W and EXC.
    As you can see in the picture, the brake lever comes nowhere near engaging the switch. Even with the lever adjusted fully away from the bar (which would be too far for me to reach comfortably), there is still air between the lever and the switch. Obviously, applying the front brake pulls the lever further from the switch.
    I know I can use a hydraulic banjo switch but I already bought this OE switch and I wonder if there's an adjustment I'm over looking?
    The picture below is the brake lever at rest.
    TIA.
  2. Tseta
    Tseta Lost
    Nov 30, 2008
    761
    On the road
    It looks like a part of the "paddle" actuating the microswitch has snapped off from the brake lever itself.
    Cheers,
    Tseta
  3. TipsyMcStagger
    Oct 28, 2006
    1,634
    NYC & NPR, FL
    Brilliant! This is a new to me bike so with no basis for comparison, that's quite possibly what's happened.
    Thanks very much.
    EDIT: Looking at a random web pic of the same part number, it doesn't appear to that anything has broken off this lever.
  4. Hohmie
    Hohmie Long timer
    Jan 23, 2013
    2,032
    Bend Or
    I use JB weld to build that little section up, had to on all of them I've installed.
  5. Hohmie
    Hohmie Long timer
    Jan 23, 2013
    2,032
    Bend Or
    IMG_2260.JPG Like this, but when it's cleaner!
  6. TipsyMcStagger
    Oct 28, 2006
    1,634
    NYC & NPR, FL
    Hmmmm...that's definitely one way to skin this cat. But I simply can' t understand why the stock components aren't playing well together?
    With the addition of this switch, all of the brake component part numbers are exactly the same as the EXC, which came from the factory with a front brake switch.
    Thanks for the feedback.
  7. Hohmie
    Hohmie Long timer
    Jan 23, 2013
    2,032
    Bend Or
    Ya, I don't understand it either, it was the same on my 05 450 EXC and a 10 250 xcfw etc. but the JB weld does work, I use tape for a form and fill with JB.
    I'm going to look at a new bike next time I'm at the bike shop and see what's up.
  8. TipsyMcStagger
    Oct 28, 2006
    1,634
    NYC & NPR, FL
    Got it figured out. I took a closer look at the fiche to make sure all of the part numbers are the same between the XCW and EXC (they are) and noticed a note "without spring" for the EXC.
    Spring removed. Lever engages switch.
    #8
    scot_douglas likes this.
