KTM/Husky/GasGas TPI Fuel Injected Two-Stroke Owners Thread
Discussion in 'Thumpers' started by Lager Meister, Mar 31, 2018.
  1. Snake Oiler
    Snake Oiler If the world didn't suck, we would all fall off Supporter
    Apr 22, 2016
    5,897
    Pennsylvania, but living in a toy hauler full-time
    Thanks buddy. I really appreciate the heads up. I'll get the Acerbic. Will the stock fitting work for the fuel line?
  2. RideFreak
    RideFreak Torque Junky
    Apr 17, 2009
    16,923
    Out in the NM Dez somewhere
    Yeah, no problem there.
    Snake Oiler likes this.
  3. keepshoveling
    keepshoveling DNF
    Oct 9, 2014
    5,210
    NYC
    What a damning picture.
  4. RideFreak
    Apr 17, 2009
    16,923
    That's after installing their little BS oil filler which was a PITA.
    keepshoveling likes this.
  5. 911
    911 Been here awhile Supporter
    Mar 16, 2016
    497
    maine
    I don't think rf liked it !!
  6. G-lat
    G-lat Adventurer
    Dec 25, 2017
    27
    Costa Mesa CA
    The TC2 is just at 3lbs and the stock silencer is 3.62.
  7. Grayjet
    Grayjet Ride on!
    Jun 14, 2008
    644
    Va Beach
    Can any of you guys comment on the MotoMinded flex plate vs the Enduroplate to prevent the loss of your license plate? I have lost two in two years from vibes and general mucking about in the woods and need a better solution than just bolting the plate to my rear fender.
    Thanks,
    Lance
  8. Snake Oiler
    Apr 22, 2016
    5,897
    I feel so good waking up with two beautiful girls every morning
  9. Oldbear
    Oldbear Been here awhile
    Jun 16, 2011
    615
    Fin Land
    4th piston change today.
    While I was at it I added a shiny new S3 head to make things look marginally less tired.
  10. thejrod
    thejrod Been here awhile
    Nov 2, 2010
    905
    Arlington, WA
    Thanks again for the tip on these. I ordered a pair and they came in a few days ago. I’m already using one as a helmet light and I was impressed enough for the price that I ordered a second pair.
    If anyone likes to geek out a little bit, it appears they do use the XM-L2 LED, and I’d guess they’re pushing ~1800lm. It’s a spot beam, pretty tight pattern with good distance but not a ton of spill. Color temp is probably 6000k (Bajas are 5000k for more accurate color). They are very close in design to my Baja S2 Pros - not exact, but very close. The Baja lenses may fit, I’m not sure. The S2 Pro uses the Cree XPL led, that’s why they spec at a higher 2375lm.
    For $33, you can do a whole lot worse than these.
    keepshoveling, SthrnRomr and BogeyMan like this.
  11. Emgo
    Emgo Started on a CT70 almost 52 years ago
    Feb 23, 2015
    612
    Gladeville, TN
    Anyone have any other suggestions for this Inmate? Mine is improved after the CCPS replacement but still has a bit of the same problem.
    satchmo3 likes this.
  12. RideFreak
    Apr 17, 2009
    16,923
    I'd count how many turns the air screw is out (to note the factory setting) and try tweaking that, usually turning inward helps the low end but also lowers the idle so you can't go much.
    Emgo, SthrnRomr and satchmo3 like this.
  13. RideFreak
    Apr 17, 2009
    16,923
    Thanks for that info. I just got in the hi/low/off switch so I can finish hooking these up. I've been working on a insert for the stock headlight mask to hold of these pods. Does the pattern look like a pair of these will work ok off road or are they too tight? I haven't lit them up yet.
  14. thejrod
    Nov 2, 2010
    905
    Arlington, WA
    The beam is probably too narrow for tight trails, but should be great for desert and higher speed riding. My Motominded light has 2 S2 Pros - one standard spot, and one with the wide cornering lens, and it’s just right. I’m pretty sure the Baja wide cornering or combo lenses will fit these lights.
    SthrnRomr and RideFreak like this.
  15. RideFreak
    Apr 17, 2009
    16,923
    I just ordered one of the those lenses. Thanks for the tip.
  16. SthrnRomr
    SthrnRomr Southern Roamer
    Aug 13, 2010
    151
    Rural, SC
    I cannot speak for the 2021, but on my 2019 (albeit with an older map obviously) I had to replace one CCPS and it was mostly fine. Also check the tube for any debris. However to get rid of that low stutter 100%, I did upgrade the ECU. Not saying anyone has to, but it completely eliminated the issue for me.
    Emgo and satchmo3 like this.
  17. Dan950ser
    Dan950ser Two Wheeled Addict
    Sep 24, 2010
    2,534
    Olympia, WA
    @RideFreak you said you replaced the relay on our harness with the factory one. Just to clarify the relay we use is the exact same relay(check relay part number) as the oem one, it just doesn’t have the plastic holder. We use a Flexi relay mount instead because ktm has supply issues and it was causing long delays in harnesses to try and get them.
    Snake Oiler and alvincullumyork like this.
  18. RideFreak
    Apr 17, 2009
    16,923
    Hi Dan, the 4 harnesses I got from you were made by cyclops (or at least had their sticker) and had the std cube style automotive relays. I saw a pic recently on your website and the harness in the pic had the small OEM style, I just figured you updated the design but the ones I received were cube style. It's been at least a year since I ordered those from you so it's been awhile. They still worked great but as you know the small relay fits better. I'm very happy with the product.
  19. Dan950ser
    Sep 24, 2010
    2,534
    Olympia, WA
    Got it. You got the old style and since then we make everything in house and use factory relays with mounts. Just wanted to clarify for others. AAA64CD3-0A0A-4011-AF22-4C2DAE78CB27.jpeg
  20. adv_sacrifice
    adv_sacrifice Been here awhile
    Aug 18, 2017
    578
    Committed sacrilege tonight. Filled the tank with premix 60:1
    Going to try tbi (like @Dustodust ) but no oil injection. Sureshot block scheduled for tomorrow.
