KTM/Husky/GasGas TPI Fuel Injected Two-Stroke Owners Thread
Discussion in 'Thumpers' started by Lager Meister, Mar 31, 2018.
  1. RideFreak
    RideFreak Torque Junky
    Apr 17, 2009
    16,923
    Out in the NM Dez somewhere
    Added a wde cornering lens, still waiting on a 20W diode to finish it up.
  2. Snake Oiler
    Snake Oiler If the world didn't suck, we would all fall off Supporter
    Apr 22, 2016
    5,897
    Pennsylvania, but living in a toy hauler full-time
    I'm liking your setup. So a rough estimate on your cost and what the total lumen count?
    Bitingdog likes this.
  3. RideFreak
    Apr 17, 2009
    16,923
    So far $50 including the BD wide cornering lens for one of the lights. For output I can only go by the current I measured and the LEDs specs, based on that and in depth review I wouldn't be surprised if it's 2x what a sport puts out and 50~75% of what a pro puts out and that might be conservative. (S2 sport and a S2 Pro) I don't have the equip to come up with measured lumens.
    I did have to make a small bracket and I'm waiting on a 20W diode and a double handlebar switch; it'll be just inboard of the FrBr Mcyl, the switches will be Hi/Lo/off for the lights and the ecu map switch. Low will just be the wide cornering beam and hi will be everything.
    Here's a little video of some testing, it'll be allot better once I can link both beams to hi.
  4. Snake Oiler
    Apr 22, 2016
    5,897
    Not to bad. I'd think once you can have both lite it should be good. Especially for the investment you have into it
  5. satchmo3
    satchmo3 Been here awhile
    May 20, 2008
    288
    Portland, Oregon
    8CD6A35F-9117-4EED-88C2-80AC74132E71.jpeg In case anyone is wondering what orange side panels look like on a 21’ , I never liked the gray. These are Acerbis, great color match. 0FFBBC9B-4FA7-4B41-A0AA-D47EB5371B26.jpeg
  6. guns_equal_freedom
    guns_equal_freedom Long timer
    Jul 1, 2007
    7,608
    I ordered an oversized KTM tank for my 2011 300, I asked Chip what the shipping was and he couldn't tell me.
    When I got it, he didn't charge me. First and only time that happened.
  7. RideFreak
    Apr 17, 2009
    16,923
    Going through KTMT it was cheaper even with the shipping then SLavens or RMATV, not by allot but Chip has always been a good guy to deal with.
    We spent the day giving Bishop's TPI a check out and topend refresh. Compression was down 20psi since when the head was added 140hrs ago so it got a fresh B piston, new clutch rubbers, and the starter checked out and lubricated and fresh fluids.
    The 160hr plug that came out of it.
    It's ready for another 160hrs :clap
  8. Bitingdog
    Bitingdog That's not my dog
    Apr 2, 2015
    19,938
    The bad side of the PNW
    Always good to see you two fast bastages having fun:rofl
    RideFreak and alvincullumyork like this.
  9. alvincullumyork
    alvincullumyork Ol Two Flags Supporter
    Feb 26, 2012
    24,970
    The dry part of the PNW
    Where did you get the Powerparts silencer?
  10. RideFreak
    Apr 17, 2009
    16,923
    Munn racing has a Shop Online from KTMTalk but you must be logged into KTMTalk to get the discount.
    alvincullumyork and SthrnRomr like this.
  11. adv_sacrifice
    adv_sacrifice Been here awhile
    Aug 18, 2017
    578
    pulled the oil tank this morning (baby woke me up). that was a hassle and i definitely should have done it before installing the injector block. especially since i had to rotate the subframe up out of the way again...
    clipped out the ambient sensor plastic and ziptied it up where the oil tank bolted to the frame. i didnt realize the ambient sensor had a filter.
    CCPS pulled out of the bracket entirely and installed into the tokyo offroad machined nipple.
    since i have the JD tuner wiring is a little bit of a mess under the frame but much cleaner overall. ill grab a picture after work today
    Snake Oiler likes this.
  12. Snake Oiler
    Apr 22, 2016
    5,897
    Quick question. Is a cup of coolant enough to drain to install a oem fan? I really don't want to bleed the system if I don't have to
  13. adv_sacrifice
    Aug 18, 2017
    578
    bleeding is super easy, just unthread the temp sensor in the head and fill till it comes out.. id just remove the radiator to do it since you need to access the frame side to attach the bracket.
    also make sure to put the screws that hold the fan on from radiator side. so the head of the screw is facing the radiator otherwise they will fall out
    Snake Oiler and RideFreak like this.
  14. RideFreak
    Apr 17, 2009
    16,923
    I have to agree, your orange side panels look better than the grey ones, I'm not a big fan of the latest gen's slab side look no matter what it's color.
    satchmo3 likes this.
  15. Snake Oiler
    Apr 22, 2016
    5,897
    Thanks. I wasn't sure what it took to bleed. Yeah I knew the screws went in from the rad side. And I thought I could reach the bracket screws from the right side of the bike.
  16. Snake Oiler
    Apr 22, 2016
    5,897
    What was the cost with the discount? I seen it for $161( turbinecore 2. I believe)
  17. adv_sacrifice
    Aug 18, 2017
    578
  18. Snake Oiler
    Apr 22, 2016
    5,897
    What was your reason for removing the oil system?
  19. adv_sacrifice
    Aug 18, 2017
    578
    Just cause. No specific reason
  20. Snake Oiler
    Apr 22, 2016
    5,897
    I just curious, if there's been problems with it.
    On another note. I just read there's a recall on my 2022 for a e clip on the front brake. Anyone else see this?
