KTM/Husky TPI Fuel Injected Two-Stroke Owners Thread
Discussion in 'Thumpers' started by Lager Meister, Mar 31, 2018.
  1. Lager Meister
    Lager Meister Work less, ride more
    Jul 9, 2006
    370
    DFW, Texas
    Are the new two-stroke TPI bikes special enough to deserve a dedicated owner's thread? Maybe they are, maybe they aren't, I don't know, but I'm starting a thread anyway. Let's see where this goes...
    Lewilewi likes this.
  2. Lager Meister
    Jul 9, 2006
    370
    DFW, Texas
    So I just picked up a new KTM 250 XC-W TPI this week and I'm anxious to get it out for the first ride, but first things first... gotta use protection...
    Hand guards...
    Skid plate...
  3. Lager Meister
    Jul 9, 2006
    370
    DFW, Texas
    Rear disk guard...
    Clutch slave / case saver...
    RAZR likes this.
  4. Lager Meister
    Jul 9, 2006
    370
    DFW, Texas
    Radiator guards / braces...
  5. Vegas800XC
    Vegas800XC POS rider
    Sep 10, 2012
    400
    Las Vegas NV
    Looking forward to ride report!
  6. Lager Meister
    Jul 9, 2006
    370
    DFW, Texas
    Spark arrestor end cap...
  7. Lager Meister
    Jul 9, 2006
    370
    DFW, Texas
    At 5’9” with a 32” inseam, the stock seat put me on my tippy toes, which for me with my riding skills means a lot of low speed tip-overs. I’m working on my static balance, but it’s nice to be able to get a foot down and have some leverage when needed. Lowering the suspension isn’t something I’d even consider on a bike like this, but there’s lots of foam in the stock seat to work with so it was time to cut down the seat. I’ve done this on two other dirt bikes with good results, so for me this was a no-brainer mod...
    It’s always a good idea to measure and mark both sides of the foam before you start grinding so the final result is even on both sides and the seat has a smooth contour...
    Here it is after slowly and gently sanding the foam with a variable speed 4-1/2" disc grinder on the lowest speed with a coarse sanding disc...
    natedog39 and SuzyMoto like this.
  8. Lager Meister
    Jul 9, 2006
    370
    DFW, Texas
    Reattaching the seat cover...
    Start by stapling both ends, making sure the cover is centered and slightly stretched...
    Staple each side in the middle making sure it’s centered and stretched tight enough that the cover follows the contour of the foam...
    The finished underside...
    #8
  9. Lager Meister
    Jul 9, 2006
    370
    DFW, Texas
    The finished top side...
    Here it is on the bike...
    I took almost 2" of foam off the lowest part of the seat. This will give me all the leverage I need when I really have to put a foot down and will mean the difference between a dab or a tip-over.
    #9
    cal08 and SuzyMoto like this.
  10. radmann10
    radmann10 Derf Supporter
    Apr 29, 2014
    1,131
    Phoenix, AZ
    I'm following along. It would be nice to pick up a TPI probably a 300 when they hit the states.
    #10
  11. Lager Meister
    Jul 9, 2006
    370
    DFW, Texas
    I thought about waiting for the 300 but decided to just bite the bullet and get the 250 now. I'll ride it for a year and then consider putting a 300 kit on it next year if I feel like I need more low-end grunt.
    #11
    retroone likes this.
  12. Lager Meister
    Jul 9, 2006
    370
    DFW, Texas
    Eagerly awaiting her break-in ride...
    #12
    SuzyMoto likes this.
  13. 1wicked55
    1wicked55 Been here awhile
    Aug 21, 2011
    420
    I’m eagerly waiting for mine to show up from Munn racing.
    #13
  14. Cartera
    Cartera Been here awhile
    Jun 14, 2015
    317
    Milton, Ontario
    Does anyone know how many injected two strokes are coming to the states. Here in Canada there's 9 KTM and 9 Husqvarna. The dealerships can't take down payments for one.
    #14
  15. retroone
    retroone Long timer
    Jan 11, 2006
    2,045
    albq NM
    Loving mine.
    Niiiice job on your seat...........
    #15
  16. ridefire
    ridefire Been here awhile
    Mar 7, 2013
    269
    SL,UT
    I've got a deposit on 1. Supposedly I'm 3rd in line on a 300 husky.
    #16
  17. Lager Meister
    Jul 9, 2006
    370
    DFW, Texas
    Did the dealer give you an ETA for when the 300s will start arriving?
    #17
  18. 1wicked55
    Aug 21, 2011
    420
    None of my local dealers had an idea better then late this year or early next year.
    That’s why I jumped on the husky 250 from Munn
    I do know where 2 ktm tpi bikes are if anyone is interested
    #18
  19. Cartera
    Jun 14, 2015
    317
    Milton, Ontario
    Where are you from though?
    #19
  20. ridefire
    Mar 7, 2013
    269
    SL,UT
    SL UT
    #20
